boss_kk 0 Opublikowano 18 Czerwca 2011 Udostępnij Opublikowano 18 Czerwca 2011 Statyczne: http://vaglog.rtnet.pl/kfcyron_48334.html http://vaglog.rtnet.pl/kfcyron_48335.html http://vaglog.rtnet.pl/kfcyron_48355.html Dynamiczne: http://vaglog.rtnet.pl/kfcyron_48356.html http://vaglog.rtnet.pl/kfcyron_48357.html http://vaglog.rtnet.pl/kfcyron_48358.html No i błędy: Address 01: Engine Labels: 03G-906-016-BLB.lbl Part No SW: 03G 906 016 FC HW: 028 101 217 2 Component: R4 2,0L EDC G000SG 9621 Revision: 12345678 Serial number: Coding: 0000072 Shop #: WSC 00481 211 85020 VCID: 69D2A1207F23F454 2 Faults Found: 17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus P1586 -- 000 -- - Freeze Frame: RPM: 882 /min Torque: 32.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 13.98 V Bin. Bits: 00001100 Torque: 161.0 Nm Torque: 0.0 Nm 17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault P0674 -- 000 -- - Freeze Frame: RPM: 840 /min Torque: 56.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.69 V Bin. Bits: 00001100 Temperature: 16.2°C Bin. Bits: 10110000 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004401 Shop #: WSC 50733 142 86308 VCID: 2648EA1CAEBD1B2C No fault code found. Saturday,11,June,2011,16:30:14:36838 VCDS Version: Release 10.6.2 Data version: 20101123 Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Control Module Part Number: 8E0 920 931 D HW: 8E0 920 931 D Component and/or Version: KOMBI+WFS 4 H12 0040 Software Coding: 0006101 Work Shop Code: WSC 08277 001 00001 VCID: 2952E120BFA33454 2 Faults Found: 00779 - Outside Air Temp Sensor (G17) 010 -- Open or Short to Plus - Intermittent 00471 - Control Module for Elect. Regulated Dampers (J250) 012 -- Electrical Fault in Circuit Błąd cylindra został usunięty, klocki hamulcowe zmienione więc błędu nie ma. Interesuje mnie - czy turbo przeładowuje? dodam, że auto ma typowe dla tego silnika- telepanie. Wałek jest sprawdzony - OK. Zastanawiam się nad zbierakiem pompy. Dwumas też jest ok. Z logów widze , że pompki jeszcze daja rade- no 1 trochę gorzej. Jakieś pomysły? Gdzie znajdę czujnik temp zbłędów? Pozdro Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lukjar7 0 Opublikowano 18 Czerwca 2011 Udostępnij Opublikowano 18 Czerwca 2011 kiedy filtr paliwa byl wymieniany ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
boss_kk 0 Opublikowano 19 Czerwca 2011 Autor Udostępnij Opublikowano 19 Czerwca 2011 jakies 10 tys temu. Cos nie tak z dawką paliwa? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
