[B6 AVJ] Błędy w kilku modułach
Hi.
Dzisiaj podpiąłem VAGa i przeskanowałem całe auto, wywaliło kilka błędów i nie wiem co one oznaczają.
Łączyłem się VAGiem 311-2, bo wiadomo jak jest z 409.1... :wallbash:
Tutaj LOG:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 A
Component: 1.8L R4/5VT 0002
Coding: 0011581
Shop #: WSC 47236
2 Faults Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 01J 927 156 CP
Component: V30 01J 1.8l5VT RdW 2011
Coding: 00001
Shop #: WSC 44717
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 00006
WAUZZZ8E42A072217 AUZ6Z0A0182920
2 Faults Found:
01320 - Control Module for Climatronic (J255)
49-10 - No Communications - Intermittent
01304 - Radio
Address 37 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06720
Shop #: WSC 63351
1 Fault Found:
Address 56 -------------------------------------------------------
Controller:
End -------------------------------------------------------
Błędy sporadyczne. Pokasuj wszystkie i za jakiś czas sprawdź czy coś powróciło.
Miałeś zmieniany panel klimy? :naughty:
Tak, mam RNS-E, klima z B7 więc musiałem dołożyć przekaźnik )
18010 - Power Supply Terminal 30: Voltage too Low sprawdż najpierw akumulator i ładowanie jak za niskie napięcie przy rozruchu lub na jałowym to różne głupoty ze sterowników wyskakują
