[B5 AJM] Błędy immo i inne pomoc
Witam mam pytanko co 2-3 dni nie mogę z rana odpalić autka poniżej logi co z tym zrobić z tym immo i reszta błędów
VAG-COM Version: Release 311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 AN
Component: 1,9l R4 EDC G000SG 1301
Coding: 00002
Shop #: WSC 63351
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04255
Shop #: WSC 06325
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00043
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 00106
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8D0 920 931
Component: B5-KOMBIINSTR. VDO D07
Coding: 00040
Shop #: WSC 05311
˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1196943
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 14913
Shop #: WSC 27341
Address 56 -------------------------------------------------------
Controller: 8D0 035 195
Component: Radio D00
Coding: 00204
Shop #: WSC 05311
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Wygląda na to że pętla zamontowana na stacyjce nie wyłapuje sygnału z pastylki w kluczyku i raczej w tym kierunku szukałbym problemu. Sprawdzałeś na innych kluczach?
na drugim kluczu tak samo ok zajrze pod kiere w wekeend i zobacze co i jak a co z resztą błędów ???
Błędy w adresie 01 oraz 17 to właśnie immo, a błąd w adresie 56 to coś z radiem. Więcej błędów nie masz:)
Witam ponownie sprawdziłem pod kierą wszystko wygląda ok ale co zaobserwowałem błąd immo powraca jak autka nie używam np 1 dzień jak codziennie używam to jest ok wystarczy 1 dzień przerwy i problem powraca
Proszę o jakieś sugestie
Dziękuję
Co prawda nie słyszałem jeszcze o takim przypadku, ale może ma to związek z akumulatorem, może już niedomaga przy odpalaniu i brakuje prądu dla elektroniki immo. Czy rozpinałeś połączenia od modułu immo przy stacyjce? może coś nie łączy.
dzisiaj juz niestety nie odpala pojechałem do rodziców i musiałęm dzwonić po szwagra zeby z lapkiem podjechał ale lapkiem nic nie mogłem zdiałać pomogło odpięcie klemy na min nie wiem o co biega ktoś pomoze ????
po 1 min migania immo zaczyna tez migać kontrolka świec też dziwne
