motogrzech 0 Opublikowano 29 Czerwca 2012 Udostępnij Opublikowano 29 Czerwca 2012 dzis jesze raz przeskanowalem auto i tak pokazalo: Address 26: Auto Roof Labels: 8H0-959-255.lbl Part No: 8H0 959 255 A Component: VSG B6 CABRIO 6792 Shop #: WSC 00672 785 00200 VCID: 346318E32EAB 1 Fault Found: 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermitten z tego co wynika to brak kontaktu z czujnikiem J527 gdzie on sie znajduje??? ---------------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8H0 959 433 K Component: Komfortgerát T3B 5040 Coding: 06799 Shop #: WSC 00672 VCID: 3C7330C306FB Part No: 8H2959802D Component: Tõrsteuer.FS BRM 0205 Part No: 8H2959801B Component: Tõrsteuer.BF BRM 3020 Part No: 8H0959801A Component: Tõrsteuer.HL BRM 0002 Part No: 8H0959802A Component: Tõrsteuer.HR BRM 0002 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - ------------------------------------------------------------------ Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 03111 Shop #: WSC 00672 VCID: 418D41376119 2 Faults Found: 01044 - Control Module Incorrectly Coded 35-00 - - 01303 - Telephone Transceiver (R36) 49-10 - No Communications - Intermittent ---------- Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl Control Module Part Number: 8E0 919 283 D HW: 8E0 919 283 D Component and/or Version: Parkhilfe 4-Kan H06 0010 Software Coding: 0001024 Work Shop Code: WSC 00672 785 00200 VCID: 316D11F7D1B9 2 Faults Found: 01549 - Supply Voltage for Parking-Aid Sensor 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 119 Time Indication: 0 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 7 Reset counter: 91 Time Indication: 0 OBJAWY SA TAKIE ZE JAK WLONCZAM WSTECZNY BIEG DLUGO PISZCZE I POTEM CISZA I WOGOLE NIE DZIALA --------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Control Module Part Number: 8E0 910 115 Q HW: 8E0 907 115 D Component and/or Version: 2.0l R4/4V TFSI 0030 Software Coding: 011C000302070020 Work Shop Code: WSC 00694 210 83224 VCID: 2F69178FC78D 2 Faults Found: 001602 - Sensor Reference Voltage A: Circuit: Low P0642 - 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 142390 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 70.0°C Temperature: 68.0°C Absolute Pres.: 980.0 mbar Voltage: 12.192 V 012599 - Intake Manifold Runner Control: Basic Setting not Completed P3137 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 142390 km Time Indication: 0 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
IDUAL 0 Opublikowano 29 Czerwca 2012 Udostępnij Opublikowano 29 Czerwca 2012 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 004 - No Signal/Communication Czujnik cofania tylny lewy-od środka nie działa. A poza tym to nie są logi tylko błedy. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
motogrzech 0 Opublikowano 29 Czerwca 2012 Autor Udostępnij Opublikowano 29 Czerwca 2012 dziex:) tyle to wiedzialem ale jest taka mozliwosc ze jeden przestal dzialac i calosc nie dziala??? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
michier 0 Opublikowano 30 Czerwca 2012 Udostępnij Opublikowano 30 Czerwca 2012 tak własnie jest jak jeden nie trybi to i reszta nie chodzi Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
motogrzech 0 Opublikowano 30 Czerwca 2012 Autor Udostępnij Opublikowano 30 Czerwca 2012 dziex:) ma ktos pomysl na inne bledy?? SZCZEGOLNIE TE OD SILNIKA :) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
