Mrugajaca kontrolka swiec.Brak mocy
Witam
Problem polega na tym ze audi a6 c6 3.0 tdi wpadlo w tryb awaryjny.Mrugaja kotrolki swiec caly czas i auto nie ma mocy.Wczesniej na fisie wyswietlala sie na kontrolka dpf ale zniklo i teraz jet problem.
Address 01: Engine Labels: REDIR FAIL!
Control Module Part Number: 4F9 910 401 B HW: 4F0 907 401 C
Component and/or Version: 3.0L V6TDI G000AG 0020
Software Coding: 0011372
Work Shop Code: WSC 02145 785 00200
VCID: 244CEECED881E93C
3 Faults Found
000260 - Mass Air Flow Sensor (G70): Intermittent
P0104 - 001 - Upper Limit Exceeded
Freeze Frame
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 239314 km
Time Indication: 0
Date: 2012.11.06
Time: 20:24:58
Freeze Frame
RPM: 756 /min
Torque: 54.6 Nm
Speed: 0.0 km/h
Duty Cycle: 50.1 %
Voltage: 13.98 V
Absolute Pres.: 999.6 mbar
(no units): 0.0
000258 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 001 - Upper Limit Exceeded
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 239314 km
Time Indication: 0
Date: 2012.11.06
Time: 20:24:59
Freeze Frame
RPM: 756 /min
Torque: 54.6 Nm
Speed: 0.0 km/h
Duty Cycle: 50.1 %
Voltage: 13.98 V
(no units): 79.9
009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged
P242F - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 239314 km
Time Indication: 0
Date: 2012.11.06
Time: 20:25:28
Freeze Frame
RPM: 756 /min
(no units): 79.9
(no units): 26.0
(no units): 17.5
Temperature: 147.5°C
Absolute Pres.: 0.0 mbar
Pressure: 0 mbar
Readiness: 0 0 1 1 1
Tyle co zdolalem zapisac bo VAG mialem na chwile.
No wlasnie probowalem wypalic DPF jadac okolo 15 min na 3 biegu i nic nie dalo. A jak w vcds wymusic do wypalenia dpf i gzdie sprawdzic na ile procent jest zasyfiony.
