Moja NIUNIA- 1.8t 150+ lublin
djdados
A4 1.8t Quattro, przebyte 252tyś. km. kolor LZ5L.
Wyposażenie-QL-
skrzynia biegów -CTF
numer napędu osiowego- 5S
typ handlowy -8D50H5
kolor dachu- Q5
data produkcji 23.03.1996r
model -Audi A4 av.qu. 1,8 A4Q
numer silnika- AEB
1E1-Activated carbon canister
4UE-Air bag for driver and front seat passenger
7AA-Electronic wehicle immobilization device
1C1-Antifreeze up to -25degree Celsius tolerance up to -30 degree C
T8B-4-cylinder gasoline engine 1.8l unit 058.D
J1P-Battery 220A (44Ah)
K8D-Station Wagon Variant/Avant
1LB-Disc Brakes, front
1AH-Elektronic Differential lock (EDL)
2K1-Reinforced bumpers
8KA-W/o catalytic converter warning light
8R1-Center high-mounted stop light
3C3-Lap belt with retractor for the center rear seat
B0A-Component parts set withgout country-specific design requirement
6FB-Body-colored extenor mirror housings
4M6-Cup holder
2A5-Delivery equipment (transit coating) with thin seat cover
4F1-Central Locking system
1X1-Four wheel drive
8Z2-Engine cooling system with heavy-duty fan and radiator
M9L-4-cyl. gasoline engine 1.8L/110kW 20V turbo, MVEG2 base engine is T8B/T8C
A8S-Standard equipment
0TD-Frotn and rear floor mats
6W5-Front license plate carrier
Q1D-Sports front seats
1Z0-Initial standard fuel filling
6R2-Leather gearshift boot
6Q2-Leather gearshift knob/handle
C03-Operating permit, alteration
8GD-Alternator 90A
FA0-Control of standard production
8TC-Rear fog light for driving on the right
3NZ-Rear seat bench unsplit, backrest split folding
6V1-Rear trim panel (ECE)
5RD-Right exterior mirror, aspherical (india)
4TB-Vanity mirror right
3S2-Black roof rails
0LK-Special plates/stickers/safety certificates for italy
3L3-Manual height adjustment for front seats
1BE-Sports suspension/shock absorption
3X1-Load-through provision with ski bag
1G3-Alloy spaer wheel with original equipment tires
8RE-4 speakers (passive)
E0A-No special ediotion
0SK-Labels/plates in Italian
8CC-Speedometer sensor whitout seal
L0L-Left-hand drive vehicle
2PV-Leather trimmed sports steering wheel
9W0-W/o car phone preparation/instalation
H6U-Tires 205/55 R16 91W
G0G-5 speed manual transmission for four-wheel drive vehicle
0G1-Gearshift lever
B99- Rype approval EC
2Z1-Type sign at rear and "Quattro" nameplates respectively
8BB-Halogen headlight for driving on the right
8Q1-Headlight-range adjustment
9X6-Heated door lock cylinder left with micro switch
9T1-Heated washer nozzles, front
9AK-Climatronic with impact pressure control free of cfc
1EX-Special identification plate for EC for M1 passenger vehicle
2G1-Insert for the filling up of unleaded fuel
5MS-Decorative burr walnut inserts
1VG-Installation parts four-cylinder engine
U1A-Instrument insert with km/h speedometer, clock, tachometer and trip odometer
0W1-Label for central electric German-speaking countries
3BK-Left exterior mirror: electrically adjustable/heated, electrically foldable, flat
4SB-Vanity mirror left
1PC-Wheel bolts with anti-theft protection (unlockable)
7P4-Manually adjustable lumbar suport in front seats
4ZE-Black moldings
0VG-Information kit in Italian
5K1-Paint preservative (wax)
8NB-Parking light indicator light
8AV-Radio
8S4-Two reading lights front, two rear
0DY-Instalation differentiation for build status of vehicle class B5 (AUDI) unit components
F0Y-Vehicle with optional features
C1L-Alloy Wheels 5,5Jx15
4R3-Power windows with comfort operation
4GH-Windshield in heat-insualting glass with sunshield
Plany
czerwone obszycia kierownicy plus nowa skórka-zrobione
czerwony mieszek i gałka własnego pomysłu-zrobione
czerwone przeszycia na siedzeniach i obszycie czerwoną nitką
wstawiony zegar ładowania turbo-zrobione
nowe hamulce w oryginale-klocki textar-tarcze gerling w ori rozmiarze-zrobione
zawieszka z S4-zrobione-do wymiany łączniki stab i wahacze dolne-wiosna mam nadzieje wymienię całość
zmieniona tapicerka-wstawione kubełki materiałowe czarne i boczki drzwiowe z S4 z carbonową listwą
Lampy z przodu ori S4 z kierunkami, ksenon, aktualnie szukam zdarzaka chcę przed lift ze spryskami
Felgi mam pięcioramienna gwiazdka jak na foto-planuję zmienić kolor pewnie grafit i czerwone kopytka, Szukam felg ori Audi ROTOR 18", były na forum ale sprzedane Ech...
wstawić ori radio CD Concert II,
wymiana panela klimy, nie świeci część i nie podświetla guziczków, poza tym działa
osłony silnika i skrzyni-zrobione
podłączenie światełek dziennych-ewentualnie wyrzucenie ich w ogóle-jeszcze myślę nad tematem,
czarna podsufitka i słupki z RS, dymione wewnętrzne lampki i reszta z tej wersji,
nowe siłowniki klapy bagażnika szt. 2-zrobione
folia carbon na dach, lusterka i grill, może jeszcze progi i ramki szyb z zewnątrz,
wydech 3" stal, rurka jest będzie wiosna będzie wydech,
stożek (już leży),
większe turbo- np. k04
zamontowana instalacja gaz Stag 4eco, reduktor ACR 01 wtryskiwacze zielone HANA,
Nowy sterownik po wirusie- zakupiony czeka na montaż ok.180 kucyków powinno być.
marzenie - siedzenia z RS4 -
---------- Post dopisany at 20:00 ---------- Poprzedni post napisany at 11:09 ----------
obiecane fotki na razie skromnie
światełka
mieszek new
kierowniczka
mieszek i gałeczka na miejscu
tapicerka siedzonek
Dzisiaj nieco brudne autko ale daje radę zrobiłem kilka fotek
[/color]znaczek na błotniku wyszedł o tak sobie
podświetlenie działa polutowane oczyszczone i świeci wszystkie elementy oryginał
mały dodatek a cieszy audi a4 cabrio
ciepełko autku w zimie i chłodno latem taki mały miejski garażyk ale zawsze nie leje się na głowę
Kolego więcej zdjęć by się przydało i jakieś plany co do A4 masz?
Bezawaryjności:wink:
zdjęcia zapodawaj w pierwszym poście by nie robić misz maszu :D by mieć porządek.
także zimno i brak miejsca w garażu ogrzewanym czas stanął narazie w miejscu
---------- Post dopisany 06-01-2014 at 21:11 ---------- Poprzedni post napisany 05-01-2014 at 21:11 ----------
Mimo utrudnień dzisiaj zrobione podświetlenie tablicy z tyłu i wymienione żaróweczki w trzecim świetle stop. Wszystko działa i w oryginale tak jak było.
---------- Post dopisany 07-01-2014 at 18:00 ---------- Poprzedni post napisany 06-01-2014 at 21:11 ----------
Ktoś się nie bał i zaje...ał znaczki z moich bocznych błotników z nazwą audi? ciekawe po cóż one komu potrzebne, chyba na złom na aluminium he he... Jutro podczepię coś w zamian i porobię foteczki zobaczymy jak wyjdzie wiec do jutra...
Wymieniony olej w tylnym dyferku MObil 75w90 i śmigamy dalej,
te znaczki to lancuchowo ida ktos ci podj.. i ten komu podj... podj... nastepnemu :grin:
czaję i tak miałem zamiar je usunąć ale nie w tym miesiącu he he.... Na razie zastąpiłem je czym miałem czyli znaczkiem @ zobaczycie jutro jak strzele fotki wyszło na razie wystarczająco do wiosny pojeżdżą a potem się ori wstawi. Dodałem pełny opis wyposażenia jak ktoś ciekaw zapraszam mogę pomóc w jego ustaleniu po nr VIN, mam kolege w warsztacie i ma odpowiedni program ja się na tym nie znam za bardzo więc skorzystałem
---------- Post dopisany 08-01-2014 at 14:25 ---------- Poprzedni post napisany 07-01-2014 at 18:56 ----------
---------- Post dopisany at 14:54 ---------- Poprzedni post napisany at 14:25 ----------
witam ponownie i jeszcze mam takie oto felgi z latem 215/45 R17 Good Year na razie srebrne ale będzie ciemny grafit + czerwone zaciski:)
czy dobrze pacze ?
wytłoczenia w galce zmiany biegow potraktowales czerwonym ??????????:shock3:
tak czeronym tak sobie umyśliłem, a znaczki może i faktycznie wiocha ale na razie będą z braku laku
---------- Post dopisany 11-01-2014 at 19:20 ---------- Poprzedni post napisany 10-01-2014 at 20:47 ----------
Witam jako że nieco rysuję sobie czasem różne rzeczy postanowiłem sobie narysować RS4 w takiej fajnej wersji i wskoczyła ona na mój avatar. a oto jej normalny rozmiar
---------- Post dopisany at 19:21 ---------- Poprzedni post napisany at 19:20 ----------
Przepraszam, że jest boczkiem zawsze można pobrać - zapisać fotkę i przekręcić. Pozdro.
---------- Post dopisany at 19:28 ---------- Poprzedni post napisany at 19:21 ----------
A i najważniejsza sprawa właśnie zakupiłem sterownik do swojego wozu z wgranym wirusem na nieco ponad 180km, nie wiem ile ma Nm ale ciśnienie ładowania turbo oscyluje na poziomie nieco powyżej 0,8bara a nie jak w moim seryjnym przypadku 0,5-0,6bara. Wkładam w poniedziałek i dam znać jak zbiera się bryczka. Na pewno doleci mi drugi parownik bo mam obecnie ACR 01 czarny, wtryski pociągną bo mam hana zielone i sterownik Stag 4eco, ale wystarczy ciśnienie na parowniku nie wyrobi znając życie więc dorzucić mam plan drugi. Sterownik leży i czeka na montaż. Zdecydowanie poprawić się powinno odejście z piwnicy no ale się zobaczy.
---------- Post dopisany 12-01-2014 at 16:48 ---------- Poprzedni post napisany 11-01-2014 at 19:28 ----------
Dzisiaj autko umyłem i wieczorkiem dojdą nowe wlepki klubowe zdjęcia : ot taka mała sesyjka wieczorna po kąpieli
---------- Post dopisany 13-01-2014 at 23:36 ---------- Poprzedni post napisany 12-01-2014 at 16:48 ----------
Dzisiaj doszło wygłuszenie, zabawne ale koszt w ASO kołeczków tudzież spinek montażowych przewyższył koszty jego zakupu he he... już siedzi na aucie jutro wrzucę fotki...
---------- Post dopisany 14-01-2014 at 00:07 ---------- Poprzedni post napisany 13-01-2014 at 23:36 ----------
A tu pochwalę się czym kiedyś śmigałem...
zwał się mik mik córka tak go nazywała, miał ori hella przód, bez znaczków gwint MTS Technik, wydech z nierdzewki, motor 1.8 monowtrysk, miło go wspominam.
Później było Audi A6 C5 2.4V6 Quattro automat, biały skórzany środek, granatowe,
takie skromne mało ją widać ale coś tam znalazłem.
---------- Post dopisany at 22:50 ---------- Poprzedni post napisany at 00:07 ----------
dzisiaj zamontowano zawirusowany sterownik ładowanie wzrosło do 0,8bar a i dół zrobił się wyraźnie mocniejszy.... także pozytywnie. mam nadzieje, że wiosna się zhamuje ten wózek gdzieś na spocie.
Dzieki rysowane na szybko węgiel plus pastele. Jak Ci Twoje 2.6 się sprawuje?
---------- Post dopisany at 11:38 ---------- Poprzedni post napisany at 11:36 ----------
A w ogóle to mam pytanie co myślicie na temat czerwonych felg i znaczków bo środek czarny z czerwonymi obszyciami ma być jak wam się wydaje. Może ma ktoś zdjęcia jakiejś furki w takim zestawieniu. Dzięki za odpowiedzi
---------- Post dopisany 19-01-2014 at 14:43 ---------- Poprzedni post napisany 15-01-2014 at 11:38 ----------
ponawiam zapytanie co sądzicie o czerwonych felgach do mego wozidła czy raczej ciemny grafit i czerwone hample...
No to ciekawe właśnie myślę o ściągnięciu wszystkich chromów z niej a zostały już tylko grill i znaczki więc i felgi pewnie pójdą w ciemny i czerwone zaciski zobaczymy. W lutym grill idzie do oklejania wybrałem zamiast carbonu popularny coraz bardziej ostatnio czarny połysk, znaczki folią też pociągnę z tyłu pewnie tylko kółeczka zostaną reszta zniknie. Ciemno będzie he
---------- Post dopisany 20-01-2014 at 21:56 ---------- Poprzedni post napisany 19-01-2014 at 23:58 ----------
postaram się niebawem zdemontować znaczki, jednak zastanawiam się czy w zimie to jest dobry pomysł żeby połowa klapy razem nie odstała. Może z modami zaczekam do wiosny. Jutro zdemontuję jakoś grill i porozbieram na części żeby koledze było łatwiej okleić i zobaczymy jak to wyjdzie. Ciekawe czy da się ściągnąć samą to chromową ramkę żeby czarne pozostało czy są tam jakieś mocowania czy da radę ją oderwać i zzostanie ładne czarne plastikowe robił to ktoś może
---------- Post dopisany 22-01-2014 at 23:00 ---------- Poprzedni post napisany 20-01-2014 at 21:56 ----------
witam jutro wrzuce foto ale dzisiaj podczas jazdy dmuchnęło benzyną z nawiewów i sieę okazało, że pękł przewód więc improwizowałem na mroze i zastąpiłem ori zacisk zwykłą opaską i na razie działa.
---------- Post dopisany 11-02-2014 at 08:42 ---------- Poprzedni post napisany 22-01-2014 at 23:00 ----------
Witam po długiej przerwie oto mały upgrade jaki sobie wykonałem w niedzielne popołudnie ale znaczek jednak wróci w srebro bo za ciemno wyszło
---------- Post dopisany at 08:44 ---------- Poprzedni post napisany at 08:42 ----------
Jak myślicie zostawić na czarno czy działać na chroma jak było obwódkę bym zostawił a znaczek folie zdjąć i chyba będzie ok co sądzicie
szukać polifta w dobrej kasie bo i tak kiedyś zmienisz :wink:
Witam po długiej przerwie. Więc tak ostatnio ściągnąłem okleinkę ze znaczka z przodu, wygląda lepiej także dzięki darek995 poza tym w sobotę 22.03.2014r zamontowałem nowe zawieszenie MasterSport włącznie z drążkami kierowniczymi LMO. Fotorelacja z zakładania poniżej. Dołożłem pilocik do centralki zamka pneumatycznego bo miałem tylko kluczyk. Działa świetnie. Odszczurzyłem nieco felgi na sezonik i wyszło fajnie bo wystarczyło je dobrze umyc i zostało mi jeszcze położyć na nie wosk. Do wymiany pozostała mi łapa tylnego dyfra i podpora wału w tym nowy wał wrzucam już wszystko razem. Malowanie lamp na czarno z przodu żółte długie w odblasku taki mam plan.
---------- Post dopisany at 17:43 ---------- Poprzedni post napisany at 17:35 ----------
ponadto wymieniłem zbiorniczek spryskiwacza z tyłu po peknięty był i teraz działa. Zamierzam pokryć dach czarna folią jeszcze a i dopasowano osłonę pod silnik i skrzynię, klima nabita, zostało odpływy posprawdzać jeszcze czy drożne bo nie wiem, Nabyłem też za niebagatelną kwotę 150zł oryginalny bagażnik dachowy do swojej laleczki z kluczem i w idealnym stanie. Wymienione też zostały świece na BERU Z188 Platin.
---------- Post dopisany 06-04-2014 at 00:35 ---------- Poprzedni post napisany 25-03-2014 at 17:43 ----------
dzisiaj na szybko wpadł nowy wał napędowy, uszczelniacze dyfra poduszka tylna i przenia dyfra, wyprostowano łapę mocowania bo ktoś zaczepił i wygiął podwozie ale dało rade. Teraz w końcu w aucie ciszaaaaa i jest zaje...fajnie. aktualnie poszukuję gwintu jakiegoś do mojej niuni. Jak ktoś cos słyszał proszę o info.
---------- Post dopisany 23-05-2014 at 09:16 ---------- Poprzedni post napisany 06-04-2014 at 00:35 ----------
witam dawno mnie nie było ale dzisiaj dodaję nowe foteczki z zakupionych felg 18" z oponkami 225/40 początkowo były takie ale zmieniłem na ROTA
---------- Post dopisany at 09:18 ---------- Poprzedni post napisany at 09:16 ----------
---------- Post dopisany at 09:21 ---------- Poprzedni post napisany at 09:18 ----------
mam do was prośbę może jakieś pomysły odnośnie koloru tych felg czy są ok, czy może np śrubki pociągnąc w inny kolorek czy środek czy coś czy może po prostu zostawić jak są. Mi sie w sumie nawet podobają.
no znaczek w końcu lepszy :)
co do podpory to jaką kupiłeś ? coś z allegro? i czemu wymieniałaś jaki był objaw ?:wink:
Felgi bym zostawił jak są bo moje zdanie jest takie by bawić się z kolorem felg jest sens gdy auto jest zrezane "grubo" a teraz to może zapodaj znaczek audi w dekielki i będzie ok.
A jakie mają et? bo wydaje mi się że trochę się chowają i można by dystans dać :decayed:
podorę dyfra czy wału bo w dyfer ktos zaje... al kiedys i tak zostawił była zgięta łapa więc wszystko wymieniłem od razu trafiło się bo kumpel rozwalił swoje b5 więc było jak znalazł a niedawno zmieniał więc podeszło wszystko od niego objaw to stukanie z lekkim przesuwaniem dyfra na poduszce. A felgi czy ja wiem może tył delikatnie poszerzę tez nad tym myslałem ale narazie tak zostanie może a dekielki fakt mogą być chociaż te też są fajne bo niewiele widziałem takich felg
---------- Post dopisany at 00:04 ---------- Poprzedni post napisany at 00:02 ----------
et mam 35 inne nie wejdzie w serii w quattro
