Tomas213 0 Opublikowano 15 Kwietnia 2015 Udostępnij Opublikowano 15 Kwietnia 2015 Czy ktoś może mi pomóc i powiedzieć ,rozszyfrować te błędy?? Od czego mogą wynikać i jak je naprawić ?? Z góry dziękuję za pomoc:) VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . 36-00 - Open Circuit Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 1 Fault Found: 00819 - High Pressure Sensor (G65) 07-10 - Signal to Low – Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00001 Shop #: WSC 06335 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 06335 1 Fault Found: 01218 - Side Airbag Igniter: Passenger Side (N200) 001 - Upper Limit Exceeded Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01001 Shop #: WSC 06335 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00401 Shop #: WSC 00001 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 06335 7 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 00955 - Key 1 35-10 - - - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01001 Shop #: WSC 06335 No fault code found. End ------------------------------------------------------- VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . 36-00 - Open Circuit Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 1 Fault Found: 00819 - High Pressure Sensor (G65) 07-10 - Signal to Low – Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00001 Shop #: WSC 06335 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 06335 1 Fault Found: 01218 - Side Airbag Igniter: Passenger Side (N200) 001 - Upper Limit Exceeded Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01001 Shop #: WSC 06335 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00401 Shop #: WSC 00001 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 06335 7 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 00955 - Key 1 35-10 - - - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01001 Shop #: WSC 06335 No fault code found. End ------------------------------------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 15 Kwietnia 2015 Udostępnij Opublikowano 15 Kwietnia 2015 kasowane były błedy ? ktore wracaja ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Tomas213 0 Opublikowano 15 Kwietnia 2015 Autor Udostępnij Opublikowano 15 Kwietnia 2015 Tak , były kasowane...jeśli chodzi o te pierwsze błędy Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . Zostały prawdopodobnie usuniętę ponieważ po żarówki miałem spalone stopu , po wymianie już mi się nie paliła lampka Glow plung system... Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 15 Kwietnia 2015 Udostępnij Opublikowano 15 Kwietnia 2015 czujnik stopu do wymiany pewnie . Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Tomas213 0 Opublikowano 15 Kwietnia 2015 Autor Udostępnij Opublikowano 15 Kwietnia 2015 Co z resztą błędów ? Jeśli chodzi o alarm dodatkowo zacina mi się bagarznik kiedy chce go otworzyć automatycznie, kiedy włożę kluczyk i przekręcę to otworzy się ale po chwili zaczyna wyć alarm ...? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
DragonGTI 0 Opublikowano 18 Kwietnia 2015 Udostępnij Opublikowano 18 Kwietnia 2015 (edytowane) Co z resztą błędów ? Jeśli chodzi o alarm dodatkowo zacina mi się bagarznik kiedy chce go otworzyć automatycznie, kiedy włożę kluczyk i przekręcę to otworzy się ale po chwili zaczyna wyć alarm ...? a co z innymi drzwiami? otwierają się normalnie z pilota? i czy jak je otworzysz kluczykiem mechanicznie to włącza się alarm czy nie ? W klapie pewnie krańcówka i mikrowłącznik pierdzieli, polecam tam zajrzeć. Edytowane 18 Kwietnia 2015 przez DragonGTI Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
