[ALL B6] 1.9 tdi 130ps jakie silniki ?
lechu73
interesuje się b6 1.9 130 ps ale słyszałem że są 2 lub 3 kody tego silnika i różnią się momętem obrotowym czy ktoś wie jakie jeszcze różnicewystępują np.skrzynia 5 lub 6 biegów na co zwracać uwagę dziękuję za pomoc.
moze to coś pomoże?
AVF
Do tego skrzynia 6-biegowa ELN FRK GVS HHQ i bezstopniowa FWL GHQ GMW HPN HSS
ENGINE CODE AVF
TYPE TDI
FUEL DIESEL
DESCRIPTION Pumpe-Duese
CAPACITY 1.9 litres / 1896 CM3
POWER 96 KW / 130 HP
CYLINDERS 4 CYLINDERS
VALVES 8 VALVES
COMPRESSION 19.000:1
BORE 79.5
STROKE 95.5
MAIN BEARINGS 5
ENGINE BLOCK DESIGN STRAIGHT
FUEL MIXTURE FORMATION DIRECT INJECTION
CHARGER TURBO INTERCOOLER
CYLINDER HEAD DESIGN SOHC/OHC
COOLING TYPE WATER-COOLED
MAKE YEARS 2001 - 2008
SERVICE DATA FOR AUDI A6 (4B, C5) 1.9 TDI ENGINE: AVF
CAPACITIES AND SPECIFICATIONS
Engine oil with filter 3,60 litres
Engine oil specification Longlife VW 506 01
Engine oil specification VW 505 01
Manual gearbox 2,25 litres
Transmission oil specification SAE 75 W 90
Automatic gearbox with Multitronic, New filling 7,50 litres
Automatic gearbox with Multitronic, Amount to change 4,75 litres
Automatic gearbox oil specification with Multitronic VW G 052180A2 (Original oil)
Front axle differential 1,30 litres
Front axle oil specification G 052 190 A2 (Original oil)
Power steering 0,85 litres
Power steering oil specification G 002 000
Coolant 7,50 litres
Cooling fluid specification G12 Plus
Brake fluid when changing 1,25 litres
Brake fluid specification DOT 4
Air-conditioning system refrigerant 600 - 650 Gram
Refrigerant specification R 134a
Air-conditioning system oil 245 - 265 cm³
Cooling oil specification G 052154A2
Tank capacity 70 litres
CHANGE INTERVALS
Engine control toothed belt change interval up to 2003 every 90.000 km (including replacement of the tensioning roller)
Engine control toothed belt change interval from 2004 every 120.000 km (including replacement of the tensioning roller)
Engine control toothed belt test mode not prescribed by the manufacturer
Power unit belt change interval not prescribed by the manufacturer
Air filter change interval every 60.000 km
Fuel filter change interval every 60.000 km
Brake fluid change interval every 2 years
Automatic gearbox oil change interval with Multitronic every 60.000 km
Engine oil and filter change interval during each service according to interval display
Battery emergency call system change interval every 4 years
Interior filter change interval every 30.000 km
AWX
Do tego skrzynia 5 biegów FHN i GGB
ENGINE CODE AWX
TYPE TDI
FUEL DIESEL
VALVES 8 VALVES
BORE 79.5
STROKE 95.5
MAIN BEARINGS 5
CHARGER EXHAUST TURBO CHARGER
SERVICE DATA FOR AUDI A6 (4B, C5) 1.9 TDI ENGINE: AWX
Coolant 7,50 litres
CHANGE INTERVALS
szukaj AWX-a z 6 skrzynią, nie pchaj sie w automat
no i oczywiście dokładnie sprawdz stan auta, Vag, czujnik do lakieru itp
AWX ma 5,AVF 6 biegów... :gwizdanie: to jedyna różnica.Wszystko było na ten temat :szukaj:
kilka dni temu miałem na warsztacie A4 w AWX :confused4:
czyżby jakaś przekładka? :kox:
a4 w AWX wystepuje w 1,9L 96KW/130HP
co Ty powiesz......
Gość
