pyczs Opublikowano 28 Lutego 2016 Opublikowano 28 Lutego 2016 Chassis Type: 00 - moje Audi A4 B6 2001 2.0 ALT Scan: 01,02,03,08,09,15,16,17,45,46,56,76 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-907-557-ALT.LBL Controller: 8E0 907 557 F Component: 2.0L R4/5VS G 0007 Coding: 0011581 Shop #: WSC 63351 VCID: 341B9FD31723 No fault code found. Readiness: 0110 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.LBL Controller: 01J 927 156 CR Component: V30 01J 2.0l 5V Mj012011 Coding: 00002 Shop #: WSC 30350 VCID: 7E8F7DFB69EF No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04279 Shop #: WSC 00000 VCID: E5BDB2976C79 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.LBL Controller: 8E0 820 043 A Component: A4 Klimaautomat 0708 Coding: 00000 Shop #: WSC 63351 VCID: 1F31607F8EA5 1 Fault Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Controller: 8E0 907 279 Component: int. Lastmodul RDW 0510 Coding: 00001 Shop #: WSC 00000 VCID: EF91D0BFBE85 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.LBL Controller: 8E0 959 655 Component: Airbag 8.4E 3001 Coding: 0010602 Shop #: WSC 63351 VCID: F49BDFD3D7A3 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Controller: 8E0 953 549 Q Component: Lenksáulenmodul 0801 Coding: 00041 Shop #: WSC 00000 VCID: 41F5C6075891 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Controller: 8E0 920 900 F Component: KOMBI+WEGFAHRS. RB4 D13 Coding: 00001 Shop #: WSC 00000 VCID: 2721789FD6F5 WAUZZZ8EZ1A067707 AUZ6Z0A0107193 2 Faults Found: 01304 - Radio 49-00 - No Communications 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.LBL Controller: 8E0 951 177 Component: Innenraumueberw. 0503 Coding: 00001 Shop #: WSC 30350 VCID: EBA9C4AF8A9D No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8E0 959 433 AH Component: Komfortgerát T9F 0619 Coding: 06730 Shop #: WSC 30350 VCID: 778168DF46D5 7 Faults Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation 01398 - Signal Conductor for Central Locking; Doors Open 28-10 - Short to Plus - Intermittent 00952 - Signal; Drivers Door Open 28-10 - Short to Plus - Intermittent 01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation 01332 - Door Control Module; Passenger Side (J387) 80-00 - Single-Wire Operation 01333 - Door Control Module; Rear Left (J388) 80-00 - Single-Wire Operation 01334 - Door Control Module; Rear Right (J398) 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.LBL Controller: 8D0 035 195 Component: Radio D00 Coding: 00001 Shop #: WSC 40190 VCID: E3B9AC8F624D 1 Fault Found: 00856 - Radio Antenna 36-00 - Open Circuit ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL Controller: 8E0 919 283 A Component: Parkingsyst. A4 RDW D07 Coding: 01104 Shop #: WSC 63351 VCID: 2E2F8DBBF90F No fault code found. End ------------------ Niepokoi mnie moduł centralnej elektryki (46), oraz 01336 - Data Bus for Comfort System w wielu adresach. Pozostałe są do opanowania. Proszę o wskazanie kierunku poszukiwań. Naprawdę nikt nie ogarnia tego tematu ?. Może ktoś z Białegostoku kuma te tematy to bym podjechał.
lukaszooo Opublikowano 28 Lutego 2016 Opublikowano 28 Lutego 2016 To nie logi tylko błędy, nie wkleja sie całego scana tylko numerki błędów. Skasuj błędy i sprawdz które wracają.
pyczs Opublikowano 2 Marca 2016 Autor Opublikowano 2 Marca 2016 To nie logi tylko błędy, nie wkleja sie całego scana tylko numerki błędów. Skasuj błędy i sprawdz które wracają. Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8E0 959 433 AH Component: Komfortgerát T9F 0619 Coding: 06730 Shop #: WSC 30350 VCID: 778168DF46D5 7 Faults Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation 01398 - Signal Conductor for Central Locking; Doors Open 28-10 - Short to Plus - Intermittent 00952 - Signal; Drivers Door Open 28-10 - Short to Plus - Intermittent 01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation 01332 - Door Control Module; Passenger Side (J387) 80-00 - Single-Wire Operation 01333 - Door Control Module; Rear Left (J388) 80-00 - Single-Wire Operation 01334 - Door Control Module; Rear Right (J398) 80-00 - Single-Wire Operation Te właśnie ciągle wracają
