Kody Błędu A4 B8
Witam,
Ostatnio zakupiłem w/w samochodzik. Niedawno zaopatrzyłem się w przewód diagnostyczny i po sprawdzeniu wyskoczyły błędy.
Jeśli jest możliwe proszę o wyjaśnienie tych błędów:
Address 01: Engine (J623-CAGB) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 019 AT HW: 03L 906 019 AL
Component: R4 2,0L EDC H20 5069
Revision: 25H20---
Coding: 0A194012232403080000
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906019AT A02002
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7DF661DBECE2C9C9059-8028
2 Faults Found:
4902 - Engine Mount Solenoid Valves (N144/N145)
P1586 00 [109] - Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 208530 km
Date: 2016.02.12
Time: 11:39:14
5619 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 208943 km
Date: 2016.03.02
Time: 10:09:22
Readiness: 0 0 0 0 0
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DC HW: 8K0 907 064 DC
Component: BCM2 1.1 H02 0321
Revision: 00002001
Coding: 030100
Shop #: WSC 02399 823 56573
VCID: 74E044FFD7A888817A7-8021
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 60
Mileage: 208636 km
Time Indication: 0
Date: 2016.02.12
Time: 15:16:42
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 M HW: 8K0 907 063 M
Component: BCM1 1.0 H25 0380
Revision: 08025001 Serial number: 00000000271706
Coding: 690040B10034A7000001000300005F5F001C020804000101000000
Shop #: WSC 02391 823 56573
VCID: 397EB5CBB04A35E9691-806C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 300509 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 208614 km
Time Indication: 0
Date: 2016.02.12
Time: 13:33:00
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HR H10 0306
Revision: Serial number: 0000101242297
Coding: 010002204000210001
VCID: 428CD227DD9C763138B-8017
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 22
Mileage: 208614 km
Time Indication: 0
Date: 2016.02.12
Time: 13:52:33
Z góry dziękuję.
Do sprawdzenia poduszki silnika.
00956 - Key 2
Bateria w kluczyku do wymiany.
Przerwa w obwodzie lewej lampy. Żarówka cała? Może ktoś wymienił i nie wykasował kodu?
Zamek z tyłu z prawej do wymiany. Było o tym na forum -->> http://a4-klub.pl/index.php?/topic/269382-problem-z-zamkiem-tylnych-drzwi-008-niezrozumialy-sygnal/
          - 00 [032]
A tutaj masz chyba za słaby kabel.
Edytowane przez sowiq
Ale to kwestia kabla czy bardziej wersji vcds?
a na czym latasz?
Vcds 14.10.2
Wysłane z mojego D5803 przy użyciu Tapatalka
Klon, czy ori?
Klon
Ile się da to napraw (żarówka, poduszka, zamek, kluczyk), błędy wykasuj i zobacz czy coś wróci. Jeśli dajek będziesz miał ten "Unknown Error Code", to podjedź do kogoś z lepszym sprzętem.
Czasami się zdarza, że błąd w jednym sterowniku generuje różne dziwne błędy w kilku innych. Kiedyś miałem źle zakodowany sterownik drzwi, a dostałem też błędy np. z silnika i klimatyzacji.
Witam,
to co mogłem porobiłem wymiana poduszki była nie potrzebna bo ktoś błędu nie skasował tak jak z żarówką.
Po zrobieniu wszystkiego co mogłem i aktualizacji VCDSa pojawił się następujący błąd:
No ASAM data for: "EV_ECM2T0DI03L906019AT" (AU48)
Po wejściu w 01 - Enige a później Advanced wyświetla się tak:
Address 01: Engine
Control Module Part Number: 03L 906 019 AT
Component and/or Version: R4 2,0L EDC H20 5069
Software Coding: 0A194012232403080000
Work Shop Code: WSC 02145
VCID: 7DEFD05BC543A76A5296B79-8028
Advanced Identification/FAZIT
Identification: BPG-810
Revision: 25H20---
Date: 09.05.09
Manufacturer number: 1335
Test stand number: 0309
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(application): 0/0/0
Programming Status: 00000000
Flash Date: 00.00.00
Misc.
Hardware number: 03L 906 019 AL
Workshop System Name: J623
ASAM Dataset: EV_ECM2T0DI03L906019AT
ASAM Dataset Revision: A02002
Car Info
Chassis Number: WAUZZZ8KXAN004582
Engine code: CAGB
VCDS Info:
Readiness: No script available
ROD: ERROR - EV_ECM2T0DI03L906019AT A02002 (AU48)
Ktoś jakieś pomysły?
