Chudy112 Opublikowano 6 Kwietnia 2016 Opublikowano 6 Kwietnia 2016 (edytowane) Witam prosze o analize bledow auto od kolegi VCDS-Lite Version: Release 1.2Wednesday, 06 April 2016, 19:26:35:0Control Module Part Number: 8E0 909 518 AA Component and/or Version: 1.8L R4/5VT 0004 Software Coding: 0011501 Work Shop Code: WSC 00165 VCID: 6F9150BF3E858 Faults Found:16891 - Idle Control System RPM: Higher than Expected. P0507 - 001 - Upper Limit Exceeded16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 002 - Lower Limit Exceeded17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136 - 001 - Upper Limit Exceeded16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - Upper Limit Exceeded - Intermittent16687 - Cylinder 3: Misfire Detected P0303 - 001 - Upper Limit Exceeded - Intermittent16688 - Cylinder 4: Misfire Detected P0304 - 001 - Upper Limit Exceeded - Intermittent17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High P1114 - 008 - Implausible Signal - Intermittentstały nie da sie usunaćVCDS-Lite Version: Release 1.2Wednesday, 06 April 2016, 19:29:05:0Control Module Part Number: 8E0 909 518 AA Component and/or Version: 1.8L R4/5VT 0004 Software Coding: 0011501 Work Shop Code: WSC 00165 VCID: 6F9150BF3E851 Fault Found:16985 - Internal Control Module: Memory Check Sum Error P0601 - 001 - Upper Limit Exceeded Wysłane z mojego Xperia SP przy użyciu Tapatalka Edytowane 6 Kwietnia 2016 przez Chudy112
