Lukasz eS. Opublikowano 2 Sierpnia 2016 Opublikowano 2 Sierpnia 2016 Witam, nie znam sie na tym, wiec czy mogl by ktos pomoc w analizie logow? Z gory bardzo dziekuje Niestety torche ich jest... Test byl robiony na zaplonie, pozniej na wlaczonym silniku. VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 559 H Component: 3.0L V6/5V G 0003 Coding: 0011751 Shop #: WSC 63351 5 Faults Found: 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High P1114 - 008 - Implausible Signal - Intermittent 17548 - Oxygen (Lambda) Sensor: B2 S2: Internal Resistance too High P1140 - 008 - Implausible Signal - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent 17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136 - 001 - Upper Limit Exceeded - Intermittent 17546 - Fuel Trim: Bank 2 (Add): System too Lean P1138 - 001 - Upper Limit Exceeded - Intermittent Readiness: 0000 0000 Address 02 ------------------------------------------------------- Controller: 8E0 927 156 G Component: AG5 01V 3.0l5V RdW 0808 Coding: 0000001 Shop #: WSC 63351 2 Faults Found: 17125 - Torque Converter Clutch Circuit Performance or Stuck Off. P0741 - 003 - Mechanical Failure 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 003 - Mechanical Failure - Intermittent Address 03 ------------------------------------------------------- Controller: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04497 Shop #: WSC 06435 2 Faults Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 C Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 3 Faults Found: 01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 01142 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 930 K Component: KOMBI+WEGFAHRS. RB4 D28 Coding: 01100 Shop #: WSC 19411 WAUZZZ8E83A007078 AUZ6Z0B0100691 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 8E0 035 192 B Component: RNS 4.2 H06 BNO 0102 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T01 0316 Coding: 06976 Shop #: WSC 63351 2 Faults Found: 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 No fault code found. Address 56 ------------------------------------------------------- Controller: 8E0 035 192 B Component: Radio BNO 0001 Coding: 00205 Shop #: WSC 04000 No fault code found. Address 76 ------------------------------------------------------- Controller: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D07 Coding: 01114 Shop #: WSC 63351 No fault code found. End -------------------------------------------------------
