marjan83 Opublikowano 26 Września 2017 Opublikowano 26 Września 2017 Witam, prosiłbym o interpretację loga , dodam ze problem z dpf, podczas jazdy auto zgasło i wszystko się wyłączyło, możliwy jest problem z kluczykiem ? Spoiler Monday,25,September,2017,23:12:20:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: WAUZZZ8K39A223502 License Plate: Mileage: 226710km-140871mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K (8T0) Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 56 62 69 72 77 VIN: WAUZZZ8K39A223502 Mileage: 226710km/140871miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: Sporadic communication error 1000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CGKA) Labels: 059-907-401-CAP.clb Part No SW: 8K1 907 401 K HW: 8K1 907 401 A Component: 2.7TDI EDC17 H01 0008 Revision: 15H01--- Coding: 010C002C18070118 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_ECM27TDI0118K1907401K 001009 ROD: EV_ECM27TDI.rod VCID: 3467FA5B9FCEB4BE40B-8061 4 Faults Found: 4807 - EGR System P0401 00 [096] - Insufficient Flow Intermittent - Not Confirmed - Tested Since Memory Clear 18660 - Start Interruption due to Insufficient Engine Speed P151D 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 32 Mileage: 226689 km Date: 2017.09.23 Time: 17:55:56 5308 - Throttle Body Actuator Bank 1 (J338) P0638 00 [175] - Implausible Signal MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 12 Mileage: 226689 km Date: 2017.09.23 Time: 17:55:59 5418 - Cylinder 6 Glow Plug Circuit (Q15) P0676 00 [109] - Electrical Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 210131 km Date: 2016.09.03 Time: 08:44:38 Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AG HW: 8K0 907 379 AG Component: ESP8 front H04 0240 Revision: -------- Serial number: -------------- Coding: 198D00 Shop #: WSC 47091 141 00222 VCID: 7EF31873E902AEEEE6F-802B No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 M HW: 8K0 907 064 M Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 030200 Shop #: WSC 06335 000 00000 VCID: 3A7BD463B5AA42CE9A7-806F Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H36 0042 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 Subsystem 1 - Part No: 8T0 919 609 Component: E0380 BedienteilH08 0100 Subsystem 2 - Serial number: 00000000254923 Subsystem 3 - Serial number: 0114.03.090000000100010034˙ Subsystem 4 - Serial number: 010034˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01250320090582 Coding: 36000000 Shop #: WSC 06335 000 00000 VCID: 70EF364BA356C89E643-8025 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H24 0253 Revision: 05024001 Serial number: 00000000342905 Coding: 690040B1003400010001000300005F5F0F1C260800000001000000 Shop #: WSC 47091 141 00222 VCID: 306FF64B63D6889E243-8065 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 250309 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 P HW: 8K0 941 531 P Component: E1 - LDS H07 0090 2 Faults Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 254 Reset counter: 211 Mileage: 210125 km Time Indication: 0 Date: 2016.08.31 Time: 18:25:00 02071 - Local Databus 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 202 Mileage: 226430 km Time Indication: 0 Date: 2017.09.20 Time: 16:30:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: None VCID: 55A167DFBCF48DB6975-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140908211015 Coding: 010003 Shop #: WSC 47091 141 00222 VCID: 3C77D27BBF9E7CFE88B-8069 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1EZ73H Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C77D27BB79E7CFE88B-8069 Crash sensor for side airbag; driver side: Serial number: 6334MSME46350B63B Crash sensor for side airbag; passenger side: Serial number: 6344MSME455419024 Crash sensor for side airbag; rear driver side: Serial number: 6352QSME721C5738M Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME621E0F0CS Crash sensor for front airbag; driver side: Serial number: 63732SME5D212F02$ Crash sensor for front airbag; passenger side: Serial number: 63832SME581E4F06A No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90315ICP0002Z Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D71DF7FA48475F6BF5-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 D HW: 8K0 920 900 D Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DT207L39 Coding: 0F04100003000008000000 Shop #: WSC 06335 000 00000 VCID: 2B55E1274AF0EB46111-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 P HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0095 Revision: EB500046 Serial number: 4600E093170144 Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4E9388B31922FE6E56F-801B Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 1 Fault Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 211 Mileage: 210125 km Time Indication: 0 Date: 2016.08.31 Time: 18:25:59 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 8T1 035 110 C HW: 8T1 035 110 C Component: MP3-Changer H43 0390 Revision: 00043003 Serial number: AUZ5ZBI8772991 Shop #: WSC 00000 000 00000 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008686368 Coding: 011C02204000410001 Shop #: WSC 06335 000 00000 VCID: 4189A38FD87C1116DBD-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 M HW: 8K0 907 064 M Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117791138 Coding: 0100062020390040012002 Shop #: WSC 06335 000 00000 VCID: 3A7BD463B5AA42CE9A7-806F No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BAM.clb Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R Component: DSP Basic H08 0300 Revision: S2600000 Coding: 010101 Shop #: WSC 06335 000 00000 VCID: 71E9334FA85CC1966BD-8024 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008693857 Coding: 011C02204000410001 Shop #: WSC 06335 000 00000 VCID: 408FA68BD376181ED43-8015 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 00000000336659 Shop #: WSC 00000 000 00000 VCID: 3365F94792C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000008695095 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 8K0-907-383.clb Part No SW: 8K0 907 383 E HW: 8K0 907 383 E Component: Anhaenger H07 0070 Coding: 0100000000000000 Shop #: WSC 00000 000 00000 VCID: 3663C05381B2A6AE7EF-8063 5 Faults Found: 02562 - Trailer; Brake Lamps 015 - Cannot Be Tested at this Time - Intermittent - MIL ON 02563 - Trailer; Right Tail Lamps (M61) 001 - Upper Limit Exceeded 02564 - Trailer; Left Tail Lamps (M60) 001 - Upper Limit Exceeded - MIL ON 02565 - Trailer; Right Turn Signals (M63) 010 - Open or Short to Plus - Intermittent - MIL ON 02566 - Trailer; Left Turn Signals (M62) 010 - Open or Short to Plus - Intermittent - MIL ON ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000008695119 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H20 1130 Revision: 00000000 Serial number: 00000005309566 Coding: 0020910 Shop #: WSC 06335 000 00000 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. End ---------------------------------------------------------------------
edraven Opublikowano 26 Września 2017 Opublikowano 26 Września 2017 Wygląda że klapa gasząca zacięła się. Zdjemij rurę doprowadzającą powietrze do silnika (obok lampy od strony kierowcy) i rozruszaj klapkę. Jeżeli pomoże i odpali to wyczyść całość, ale bardzo możliwe że nastawnik do wymiany będzię bo sie mogł rozsypać w środku.
