NoName Opublikowano 4 Marca 2018 Opublikowano 4 Marca 2018 Sunday,04,March,2018,19:38:29:10074 VCDS Version: Beta 11.6.0 Data version: 20111008 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8T0 Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77 VIN: WAUZZZ8K29A142328 Mileage: 263700km/163855miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: None Part No SW: 03L 906 022 KC HW: 03L 906 022 B Component: R4 2.0l TDI H01 9978 Revision: 11H01--- Coding: 0104002C18072118 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_ECM20TDI03L906022KC A01010 ROD: EV_ECM20TDI03L906022KC.rod VCID: 70EBD4F31863 3 Faults Found: 4984 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault P0671 00 [109] - Implausible Signal Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 262867 km Date: 2018.02.05 Time: 07:07:24 4986 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault P0673 00 [109] - Open or Short to Plus Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 262867 km Date: 2018.02.05 Time: 07:07:24 4987 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault P0674 00 [109] - Open Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 263563 km Date: 2017.02.28 Time: 13:57:42 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC Component: KLIMA 3 ZONEN H06 0140 Revision: C1000000 Serial number: 0123.09.081328 Coding: 34000000 Shop #: WSC 06335 000 00000 VCID: 72EFDEFB166F 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 205 Mileage: 262952 km Time Indication: 0 Date: 2008.05.27 Time: 00:01:31 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0094 Revision: 4GB20042 Serial number: 4200G0890580E4 Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4687522B4A67 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 1 Fault Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 9 Reset counter: 205 Mileage: 262920 km Time Indication: 0 Date: 2018.02.07 Time: 04:28:00 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 N HW: 8K0 907 064 N Component: BCM2 1.1 H80 0143 Revision: 00002001 Serial number: 0114942783 Coding: 0100062020390440032002 Shop #: WSC 06335 000 00000 VCID: 3B7133DF01A5 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 262867 km Time Indication: 0 Date: 2018.02.04 Time: 12:58:39 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 262867 km Time Indication: 0 Date: 2018.02.04 Time: 15:18:50 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S2100000 Coding: 0203010102 Shop #: WSC 06335 000 00000 VCID: 6ED7CA8B0257 1 Fault Found: 02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 179 Mileage: 262867 km Time Indication: 0 Date: 2018.02.04 Time: 12:20:09 Freeze Frame: Voltage: 13.80 V Temperature: 23.0°C Bin. Bits: 00000001
NoName Opublikowano 7 Marca 2018 Autor Opublikowano 7 Marca 2018 Te błędy na cylindrach to świece do wymiany?Wysłane z mojego ALE-L21 przy użyciu Tapatalka
