NoName Opublikowano 28 Listopada 2018 Opublikowano 28 Listopada 2018 Witam, panowie, możecie pomóc w diagnozie Logów? Chodzi mi o głośniki i inne... Któryś jest spalony, że błąd wyskoczył? Sunday,04,November,2018,12:10:08:10074 VCDS Version: Beta 11.6.0 Data version: 20111008 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8T0 Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77 VIN: WAUZZZ8K29A142328 Mileage: 273850km/170162miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: None Part No SW: 03L 906 022 KC HW: 03L 906 022 B Component: R4 2.0l TDI H01 9978 Revision: 11H01--- Coding: 0104002C18072118 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_ECM20TDI03L906022KC A01010 ROD: EV_ECM20TDI03L906022KC.rod VCID: 70EBD4F31863 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AC HW: 8K0 907 379 AC Component: ESP8 front H04 0060 Revision: -------- Serial number: -------------- Coding: 164D00 Shop #: WSC 06335 000 00000 VCID: 7AFFF6DB4E1F No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 N HW: 8K0 907 064 N Component: BCM2 1.1 H80 0143 Revision: 00002001 Coding: 030200 Shop #: WSC 06335 000 00000 VCID: 3B7133DF01A5 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC Component: KLIMA 3 ZONEN H06 0140 Revision: C1000000 Serial number: 0123.09.081328 Coding: 34000000 Shop #: WSC 06335 000 00000 VCID: 72EFDEFB166F 1 Fault Found: 00714 - Centre Right Vent Positioning Motor (V111) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 42 Mileage: 272918 km Time Indication: 0 Date: 2018.10.11 Time: 07:20:24 Freeze Frame: Voltage: 13.40 V Temperature: 12.0°C Temperature: 14.0°C Count: 10000 Count: 9278 Bin. Bits: 00000000 Bin. Bits: 10000001 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 B HW: 8K0 907 063 B Component: BCM1 1.0 H22 0253 Revision: 03022001 Serial number: 00000000223527 Coding: 690040340034AF000001000300005F5F001C060800000141000000 Shop #: WSC 06335 000 00000 VCID: 2E570A8BC2D7 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Component: WWS 290908 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G Component: E1 - LDS H07 0070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1B8T8E Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C7330C304AB Driver's Airbag Crash Sensor: Serial number: 6334MSME402174630 Passenger Side Airbag Crash Sensor: Serial number: 6344MSME400449702 Driver's Rear Airbag Crash Sensor: Serial number: 6352QSME400A57148 Passenger's Rear Airbag Crash Sensor: Serial number: 6362QSME230E4A0EP Driver's Front Airbag Crash Sensor: Serial number: 63732SME7C0A1A084 Passenger's Front Airbag Crash Sensor: Serial number: 63832SME6F070510Y No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90319HIO00094 Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D753DC71FB1 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 C HW: 8K0 920 930 C Component: KOMBIINSTR. H17 0224 Revision: 00100000 Serial number: 9E2602V98 Coding: 0D0D100003000008020000 Shop #: WSC 06335 000 00000 VCID: 2D550D87CFD1 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0094 Revision: 4GB20042 Serial number: 4200G0890580E4 Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4687522B4A67 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000007795296 Coding: 011002204000410001 Shop #: WSC 06335 000 00000 VCID: 408B44336843 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 N HW: 8K0 907 064 N Component: BCM2 1.1 H80 0143 Revision: 00002001 Serial number: 0114942783 Coding: 0100062020390440032002 Shop #: WSC 06335 000 00000 VCID: 3B7133DF01A5 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 179 Mileage: 263700 km Time Indication: 0 Date: 2017.03.04 Time: 19:47:32 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 179 Mileage: 263700 km Time Indication: 0 Date: 2017.03.05 Time: 06:53:05 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S2100000 Coding: 0203010102 Shop #: WSC 06335 000 00000 VCID: 6ED7CA8B0257 1 Fault Found: 02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 58 Reset counter: 35 Mileage: 264261 km Time Indication: 0 Date: 2017.03.20 Time: 14:09:48 Freeze Frame: Voltage: 11.20 V Temperature: 5.0°C Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000007794291 Coding: 011002204400410001 Shop #: WSC 06335 000 00000 VCID: 3F8947CF15BD No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 E HW: 8K0 907 801 E Component: EPB Audi B8 H05 0060 Revision: 00000003 Serial number: 00000000231160 Shop #: WSC 00000 000 00000 VCID: 316D11F7D3E9 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 195 H HW: 8T1 035 195 H Component: Symphony3 H02 0210 Revision: 00000004 Serial number: AUZ5Z4H1051642 Coding: 05020082010285004359070200 Shop #: WSC 06335 000 00000 VCID: 3C7330C304AB Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000006762755 Coding: 010002204000210001 Shop #: WSC 06335 000 00000 VCID: 408B44336843 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000007752199 Coding: 010002204000210001 Shop #: WSC 06335 000 00000 VCID: 3F8947CF15BD No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 335 C HW: 8T0 862 335 C Component: FSE_256x BT H33 0550 Revision: 00000000 Serial number: 00000005034302 Coding: 0010310 Shop #: WSC 06335 000 00000 VCID: 3A7F36DB0E9F No fault code found. End ---------------------------------------------------------------------
wrclaguna Opublikowano 28 Listopada 2018 Opublikowano 28 Listopada 2018 Jesli chodzi o glosnik to tak 1 Fault Found: 02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit do sprawdzenia okablowanie albo głosnik
