Skanowanie
Witam
Zeskanowalem auto programem bluetooth i wyskoczylo mi coś takiego. Pogrubilem to co mnie ciekawi.
Mode $06 report generated by Torque for Android
VIN samochodu:WAUZZZ8K9CA078862
Producent:Audi
ID kalibracji pojazdu:8K2907115AF 0002
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1,99882   Min: 0,3499
Test result value: 1,13094
PASS
MID:$01 TID:$84
Max: 0,06997   Min: -0,06997
Test result value: 0,00061
PASS
MID:$02 TID:$81
- O2 Bank 1 Sensor 2
Max: 0,6549V   Min: 0V
Test result value: 0,64514V
PASS
MID:$02 TID:$82
Max: 1,26002V   Min: 0,6549V
Test result value: 0,66466V
PASS
MID:$02 TID:$83
Max: 0,25352V   Min: 0V
Test result value: 0V
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 1,99882   Min: 0,20304
Test result value: 0,49971
PASS
MID:$35 TID:$80
Max: -7,62°   Min: -23,62°
Test result value: -15,16°
PASS
MID:$35 TID:$81
PASS
MID:$3d TID:$80
- EVAP Monitor (0.020")
Test incomplete or dependant test failed
MID:$3d TID:$88
Max: 65 535   Min: 3
Test result value: 5
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1 239,90002°C   Min: 754,90002°C
Test result value: 819,40002°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 1 638Ohm   Min: 0Ohm
Test result value: 138Ohm
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65 535Count   Min: 0Count
Test result value: 2Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 0Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 3Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Test result value: 4Count
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
Edytowane przez Szpunar200
Z tego czegos nie da sie nic wywnioskowac ..
Dokladnie, te chinskie obd2 to tragedia, niby odczytuje, ale zmienia niekiedy nr bledow.. a tlumaczenie bledow nijak ma sie do faktycznego kodu bledu sterownika..
