Blad B201A00
Witam,
Jest mi ktos w stanie rozszyfrowac blad:
Sprawdzanie ukladu zarzadzania wersja oprogramowania
Kod bledu:B201A00
Blad jest statyczny/nieusuwalny
Nic mi sie raczej nie dzieje z autem ale blad jest wykrywany zawsze.
Z gory dzieki za pomoc.
Moze chociaz napisz w jakim sterowniku ..
Elektronika ukladow informacyjnych
  • 4 miesiące temu...
We enter the 5F
Adaptations
Confirmation of installation change
We copy the value that shows us (XXXX)
We use a calculator that has XOR ( Bitwise calculator for example)
In hexadecimal we put the value that we have.
We give XOR.
We put these values C9D2 and give the = symbol to calculate it.
The value that you put us, we put in Confirmation of the modification of assembly and We accept.
After accepting we will see that the value has not changed with respect to what we had at the beginning. IT IS NORMAL.
If you do it with VagCom leave a space between. (XX XX) when inserting it again.
Once done, do the scan again and clear the bug definitively.
