autoscan audi a4 b5
witam serdecznie!
poproszę o wytłumaczeniu mi blędów w samochodzie.
co mam zamienić?
Address 01: Engine       Labels: Redir Fail!
   Controller: 4B0 906 018 K
   Component: 1.8L R4 5VT         0005
   Coding: 05001
   Shop #: WSC 06335
   VCID: 29257EA7C0E1
1 Fault Found:
16486 -  Mass Air Flow Sensor (G70): Signal too Low
            P0102 - 35-00 -   -
Readiness: 0010 1101
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
   Controller: 8E0 614 111 B
   Component: ABS/EDS 5.3 FRONT   D00
   Coding: 0273004283
   Shop #: BB 24332
   VCID: 1D4D5A7784A9
No fault code found.
Address 08: Auto HVAC       Labels: 8D0-820-043-1D.LBL
   Controller: 8D0 820 043 P
   Component: A4     KLIMAAUTOMAT D53
   Coding: 00040
   Shop #: WSC 06335
   VCID: 2D2D8AB7F409
Address 15: Airbags       Labels: 8D0-959-655-AI8.LBL
   Controller: 8D0 959 655 J
   Component: Airbag Front+Seite 0001
   Coding: 00104
   Shop #: WSC 06335
   VCID: 3D0DBAF72469
Address 17: Instruments       Labels: 8D0-919-xxx-17.LBL
   Controller: 8D0 919 861 H
   Component: B5-KOMBIINSTR. VDO D15
   Coding: 00042
   Shop #: WSC 00000
   VCID: 361FA5DB015F
   IMMO-IDENTNR: AUZ7Z0W0850142
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ssu
   Component: e 17 eingeben
   VCID: CFD1703F1EC5
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
   Controller: 8D0 862 257 C
   Component: ZV-Pumpe            D12
   Coding: 00001
   Shop #: WSC 06325
   VCID: 2D2D8AB7F409
2 Faults Found:
01367 -  Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 -   -
00991 -  Interior Lights
            28-00 -  Short to Plus
W silniku przepływomierz albo jego okablowanie do sprawdzenia lub wymiany.
Centralny zamek albo ciśnienie w układzie zamka za niskie albo pompka centralnego zamka ma usterkę.
