Check enige
Witam.
Wyskoczyl mi blad wiec podlaczylem VCDSa i odczytalem bledy. Problem w tym ze po angielsku i nie moge za bardo sie polapac o co chodzi. Dodam ze bledy usunalem lecz na drugi dzien znowu to wyskoczylo. Moglby ktos pomoc?
Dzieki za odpowiedzi.
Cytat
                Address 01: Engine       Labels: 03L-906-019-CAG.clb
Control Module Part Number: 03L 906 022 NN    HW: 03L 906 019 AL
  Component and/or Version: R4 2.0l TDI   X21 9980
           Software Coding: 12194012232403080000
            Work Shop Code: WSC 26214 051 00000
              ASAM Dataset: EV_ECM20TDI03L906022NN A02016 (AU48)
                       ROD: EV_ECM20TDI03L906022NN.rod
                      VCID: 7EF348F9E1F772BAA7-802A
7 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.920 V
                    Unlearning counter according OBD: 28
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    CCS status-Bits 0-7: 40
                    Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255
                    Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255
                    Cr Ctl v Des Dspl: 0.00 km/h
                    Sig Reset Env x Id-Bits 0-7: 0
                    Cr Ctl st Shut Offirev-Bits 0-7: 0
4698 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
4699 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
5231 - Fuel Rail/System Pressure
          P0087 00 [032] - Too Low
5555 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246F 00 [068] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Mileage: 213385 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Vehicle speed: 255 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.580 V
                    Unlearning counter according OBD: 40
                    Accelerator position: 0.00 %
                    Coolant temperature at radiator outlet: actual value: 78.1 °C
                    Ct T t Diff Radiator: -273.1 °C
                    Ambient temperature: 22.0 °C
                    Fl Sys dvol Fl Cons All Tot: 0.00 l/h
                    Fuel temperature: 48.9 °C
                    Engine oil temperature: 99.9 °C
7859 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [168] - Implausible Signal
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 222172 km
                    Date: 2021.02.05
                    Time: 14:07:44
                    Coolant temperature: 31 °C
                    Intake air temperature: 4 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 13.080 V
                    Actual air mass: 0.0 mg/stroke
                    Intake manifold Runner Control (IMRC): activation: 100.00 %
                    Intake manifold Runner Control (IMRC): acknowledgment: 100.51 %
                    V Sw Vlv r Drft Clsd mp: 4.80 %
                    V Sw Vlv r Drft Opn mp: 11.55 %
                    V Sw Vlv st Mon-Bits 0-7: 55
                    V Sw Vlv st Mon-Bits 0-7: 0
                    V Sw Vlv st Mon-Bits 0-7: 2
                    V Sw Vlv u Raw: 0.0 mV
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Co Eng st: COENG_STANDBY
                    Co Eng st-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1 1 0 0 0
Wrzuć pełny autoscan ze wszystkich sterowników. W sterowniku silnika jest informacja, żeby odczytać błędy z innych sterowników.
Cytat
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 3C 42 46 52 53 55 56 5F 62
          72
VIN: WAUZZZ8K3AA087280   Mileage: 222260km-138105miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA)       Labels:. 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 NN    HW: 03L 906 019 AL
   Component: R4 2.0l TDI   X21 9980
   Revision: 25X21---
   Shop #: WSC 26214 051 00000
7 Faults Found:
          U1113 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
          U1113 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
          U1113 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Mileage: 217612 km
                    Date: 2020.11.01
                    Time: 12:20:06
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Mileage: 213385 km
                    Date: 2000.00.00
                    Time: 00:00:00
          P2015 00 [172] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 222172 km
                    Date: 2021.02.05
                    Time: 14:07:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Revision: --------    Serial number: --------------
   Coding: 160504
   Shop #: WSC 06325 000 00000
   VCID: 020B3C099D0F165AC3-8056
2 Faults Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 53
                    Reset counter: 109
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:21:58
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0027
                    Hex Value: 0xB999
                    Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 50
                    Reset counter: 109
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:21:58
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x2782
                    Hex Value: 0x002E
                    Hex Value: 0x0299
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0326
   Revision: 00002001
   Coding: 032200
   VCID: 0109330598090D42DA-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Serial number: 0509000064325009
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H37 0042
   Serial number: 0209000084477008
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 57
                    Reset counter: 109
                    Mileage: 222242 km
                    Time Indication: 0
                    Date: 2021.02.09
                    Time: 14:05:42
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
   Component: KLIMA 1 ZONE  H08 0171
   Revision: A1000000    Serial number: 01051120090835
   Coding: 34300000
   VCID: 77FD5DDDC6CD43F2E4-8022
2 Faults Found:
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 222058 km
                    Time Indication: 0
                    Date: 2021.02.02
                    Time: 13:42:46
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 222058 km
                    Time Indication: 0
                    Date: 2021.02.02
                    Time: 13:42:46
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000385060
   Coding: 260050904174AF000001000300001D0D0F1C070804010101000000
   Shop #: WSC 06325 123 12345
   VCID: 3C7782F1BF6BA0AAC9-8068
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 021109  H06 0070
   Serial number: SWF09110025714
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10665430
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002810090570
No fault code found.
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840931406032
   Coding: 100203
   VCID: 408FF601D383C44A95-8014
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 100
                    Mileage: 218526 km
                    Time Indication: 0
                    Date: 2020.11.30
                    Time: 17:54:11
             Freeze Frame:
                    Temperature: 6.0°C
Address 15: Airbags (J234)       Labels:* 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD0740P
   Coding: 30343435363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
   VCID: 4189F305D089CD429A-8014
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME4B24195FO
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME4D0128507
   Crash sensor for side airbag: rear: driver side:
   Serial number: 6352QSME24412F34C
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 6362QSME31420E2EI
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME73422130L
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME63425014P
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90315IK6000IS
   Coding: 000017
   VCID: 3D718FF5A471A9A2FE-8068
   Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
   Component: KOMBIINSTR.   H20 0255
   Revision: 00000000    Serial number: CIY75K2C9
   Coding: 030D10000A000008000000
   VCID: 2E53B8B97917423A77-807A
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 44
                    Reset counter: 107
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:21:58
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09A2600CC
   Coding: 00CF07
   VCID: 000F36019303044AD5-8054
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790767411
   Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Component: J532_DCDCStab  H14 0037
   Serial number: 09291000019011200180
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 109
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:21:58
             Freeze Frame:
                    Bin. Bits:    00111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
01312 - Powertrain Data Bus
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 109
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:22:03
             Freeze Frame:
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 7
                    Bin. Bits:    10011
Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019164747464545425363E
   VCID: 3365A9CD92356FD218-8066
Address 3C: Lane Change        Labels: None
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000102
   VCID: 3C7782F17F6BA0AAC9-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F06.11.0900H010003C320419ÿ
   Subsystem 4 - Serial number: 320419ÿ
2 Faults Found:
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 42
                    Reset counter: 94
                    Mileage: 208825 km
                    Time Indication: 0
                    Date: 2020.06.29
                    Time: 08:32:29
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 93
                    Mileage: 218928 km
                    Time Indication: 0
                    Date: 2020.12.14
                    Time: 13:52:26
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009602280
   Coding: 011C02205000410001
   VCID: 4581E715CCA1E162A6-8010
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0123582399
   Coding: 01000620203904C00220023680000000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 57
                    Reset counter: 109
                    Mileage: 222242 km
                    Time Indication: 0
                    Date: 2021.02.09
                    Time: 14:05:42
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009586004
   Coding: 011C02205C00410001
   VCID: 4487FA11C79BD86AB1-8010
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0100
   Revision: 00000003    Serial number: 10000000361832
   Shop #: WSC 00000 000 00000
   VCID: 3467AAD1973B68EA01-8060
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 60
                    Reset counter: 109
                    Mileage: 213443 km
                    Time Indication: 0
                    Date: 2020.08.31
                    Time: 11:21:58
             Freeze Frame:
                    Voltage: 12.40 V
                    Count: 64
                    Speed: 0.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 222242 km
                    Time Indication: 0
                    Date: 2021.02.09
                    Time: 14:05:43
             Freeze Frame:
                    Voltage: 13.30 V
                    Count: 58
                    Speed: 0.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0102
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 B    HW: 8H0 907 357 B
   Component: AFS 1           H01 0030
   Revision: 00000001    Serial number:
   Coding: 0000019
   Shop #: WSC 06324 000 00000
   VCID: 3169A3C5A8295DC26A-8064
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H02 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH02 S001
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 198581 km
                    Time Indication: 0
                    Date: 2020.02.01
                    Time: 15:32:32
02071 - Local Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 188746 km
                    Time Indication: 0
                    Date: 2019.08.14
                    Time: 11:40:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 219183 km
                    Time Indication: 0
                    Date: 2020.12.22
                    Time: 00:49:15
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342KR097720412
   Coding: 010003020100000001
   VCID: 1F4D557D0EBDDBB2CC-804A
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 652 D    HW: 8T1 035 652 D
   Component: B-BN-EU       H52 0048
   Revision: --------    Serial number: 323K0097536991
   Coding: 01010001000681ED11000F0E000000030001
   VCID: 366390D981477AFA3F-8062
   Subsystem 1 - Part No: 4G0 919 884 F
   Component: EUR 2010  1005
   Subsystem 2 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355KS091046414
   Subsystem 3 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000398760
Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102240418
   Coding: 010C02204000210001
   VCID: 428BFC09DD8FD65A83-8016
Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102240447
End-------------------------(Elapsed Time: 03:28)--------------------------
Robiłeś coś przy aucie? Dokładałeś coś lub wgrywałeś softa (chip)?
Tak, chip był robiony prawie dwa lata temu. 2L 143 na 177 km
Edytowane przez Silus
Dokładałeś coś przy elektryce ostatnio?
Hmm..  nie. Ale akumulator jakieś dwa miesiące temu wymieniałem na nowy. Kodowany też był.
Jest kilka błędów:
Błędy świadczące o niezrozumiałym sygnale, który odbiera sterownik silnika to 4695, 4698, 4699. Jakieś urządzenie podaje niwełaściwe, niezrozumiałe dane do sterownika.
Błąd za niskiego ciśnienia paliwa na szynie rail to 5231.
Błąd czujnika temperatury spalin 5555 podaje niezrozumiały sygnał)
Błąd klapek w kolektorze ssącym 7859 (niezrozumiały sygnał)
Błąd przekaźnika 4629 błąd przekaźnika J271 odpowiedzialnego za sterownik silnika.
