3.0i ANS - Long hot starts
Hello,
i have problems with my Audi A4 B6 3.0i ASN Quattro.
When is engine cold, car start absolutely without problems. After first turn engine running smoothly.
When is engine hot (operating temperature) and car stand more than 30 minuts and I want start, car dont wont start easily.
Engine is turning and car start circa after 4 seconds.
When i give full thortle car starts sooner.
Where can i find mistake? Throttle body? Adapation?
One of my underpressure pipe leaking (When car is running I can hear hissing)
Thank you very much.
jakies błędy ? jaka jest temperatura gorącego silnika ale na kompie nie na zegarach ?
Hello,
diagnostic show only:
01073 - Clutch pressure system - but this error code can show because oil and sealing in defferentiel were changed
Other code: nothing.
wymien czujnik wody na nowy z serwisu audi
Hello,
today I check engine measuring block 1 ...
Temperature on the CLOCK and measured you can seen on the screen below.
I have one finding:
when car is cold (after one night), outside temperature -7°C and I turn the key in the second position, needle on the temperature gauge little bit move, circa on the 50°C.
Tomorrow I order new temperature sensor and I will test it further.
jakie wartosci są na zegarach i na VAGu gdy silnik jest nagrzany do temperatury roboczej ?
today morning
Outside temperature cca: -8°C
Engine coolant temperature: -3°C
On the clock: down
after 20 minuts driving
outside temperature: -8°C
Engine coolant temperature on the diag: 96°C
On the clock: 90°C
Edytowane przez DamFo
pictures
jakie wartosci masz na VAGu gdy silnik nie chce odpalić ?
