diwasas 0 Opublikowano 15 Lutego 2023 Udostępnij Opublikowano 15 Lutego 2023 Hi, I'm retrofitting exterior door handle lights, but I can not make it work. Tried 4 different leds none of them are working (all of them are not new, bought from two different people) I've measured a voltage in the plug, its ~11.80V when I unlock a car. As I retrofitted to rear passenger door only. I've connected + wire to T20/1, - wire to common ground in door wire harness. In all door modules activated Byte1 Bit0. Any ideas what could be the problem? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
