lestat2244 Opublikowano 16 Września 2023 Opublikowano 16 Września 2023 (edytowane) Tudja valaki, hogy mi a hiba? A hőmérséklet érzékelőt már kicseréltem, és nem lehet megszüntetni a hibát -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: Redir Fail! Control Module Part Number: 8W0 907 063 DG HW: 8W0 907 063 BG Component and/or Version: BCM1 MLBevo H13 0313 Software Coding: 07501143E11800CD0545571818AC80B9110B310C000000000000000020001A810A450122025601 Work Shop Code: WSC 00046 000 00000 ASAM Dataset: EV_BCM1BOSCHAU736 019008 (AU49) ROD: EV_BCM1BOSCHAU736_019.rod VCID: 03538F112B96E6C2129-8056 2 Faults Found: 66657 - Local Databus 5 U1506 00 [009] - No Communications Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 33 Mileage: 85524 km Date: 2023.09.16 Time: 06:25:09 average_Voltage_terminals: 11.60 V Outside air temperature sensor-Resistance: 0.00 kOhm Outside air temperature sensor-Outside air temperature on CAN: 18.00 °C interior_temperature: 25.00 °C Vehicle speed: 0.00 km/h Terminal activation-Terminal 75 status: On Terminal activation-Terminal 15 status signal: On Terminal activation-Terminal 15 via CAN: On Terminal activation-Term 75: qualification: OFF 66658 - Local Databus 6 U1507 00 [009] - No Communications Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 33 Mileage: 85524 km Date: 2023.09.16 Time: 06:25:09 average_Voltage_terminals: 11.60 V Outside air temperature sensor-Resistance: 0.00 kOhm Outside air temperature sensor-Outside air temperature on CAN: 18.00 °C interior_temperature: 25.00 °C Vehicle speed: 0.00 km/h Terminal activation-Terminal 75 status: On Terminal activation-Terminal 15 status signal: On Terminal activation-Terminal 15 via CAN: On Terminal activation-Term 75: qualification: OFF Edytowane 16 Września 2023 przez lestat2244
Muskel1 Opublikowano 16 Września 2023 Opublikowano 16 Września 2023 (edytowane) Wrzucamy pełny auto-scan a nie wycinek, na którym nawet nie widać z jakiego sterownika odczytane Wróżek tu nie ma. Edytowane 16 Września 2023 przez Muskel1
lestat2244 Opublikowano 16 Września 2023 Autor Opublikowano 16 Września 2023 11 minut temu, Muskel1 napisał(a): Teljes auto-scan-t töltünk fel, nem egy töredéket, ahol nem is látszik, hogy melyik vezérlőről olvasták ki az adatokat Itt nincsenek tündérek. teraz jest dobrze?
Muskel1 Opublikowano 16 Września 2023 Opublikowano 16 Września 2023 (edytowane) Nie jest. Pełny auto-scan ze wszystkich sterowników, nie tylko z 09. Edytowane 16 Września 2023 przez Muskel1
lestat2244 Opublikowano 19 Października 2023 Autor Opublikowano 19 Października 2023 Thursday,12,October,2023,16:38:41:16365 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4 Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: WAUZZZF50KA License Plate: Mileage: 87661km-54470mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: F5-AU49 (8W5) Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 47 52 5F 6D 81 A5 AC BB BC CA D6 D7 VIN: WAUZZZF50KA016293 Mileage: 87661km-54470miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 29-Left Light -- Status: OK 0000 39-Right Light -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 AC-Reductant Control -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CA-Sunroof -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 026 QA HW: 04L 907 309 L Component: R4 2.0l TDI H36 6344 Revision: B1H36--- CVN: 1B5485E7427F2E01500CA509500CA509 Coding: 0A2540322324050834080000000000000000000000000000 Shop #: WSC 06314 790 00001 ASAM Dataset: EV_ECM20TDI01104L906026QA 005005 ROD: EV_ECM20TDI01104L906026PP.rod VCID: 79AFEDF9595AAC12485-802C VINID: 9D196AAAA58501B4400460890CD234A47D No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb Part No SW: 8W2 927 155 EB HW: 0HK 927 156 B Component: 0CK 20TDI RdW H01 0002 Revision: --H01--- Serial number: 0000002751 CVN: B6299DAA Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMDL382021 002031 ROD: EV_TCMDL382021_AU49.rod VCID: 0557910925A2D8F23CD-8050 MTF pump: Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L Component: V553 MTFP 003 0576 Serial number: 75145041180291003936 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb Part No SW: 8W0 907 379 Q HW: 8W0 907 379 J Component: ESP9 Plus H10 0775 Dataset Number: 8W2909504F 0006 CVN: 140A545A Coding: 0CAA489A10A30A9C11A0489A00805292E5B592301208508812004A49A7AD49 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_ESP9BOSCHCMP 002013 ROD: EV_ESP9BOSCHCMP_004_AU49.rod VCID: 53F37F519B76B642E29-8006 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:* Redir Fail! Part No SW: 8W0 820 043 T HW: 8W0 820 043 T Component: Klima Zone 3 H60 0251 Coding: 141804295544400D02000100080000000000000000000000000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirCondiBHTCAU491 001013 ROD: EV_AirCondiBHTCAU491.rod VCID: 44D14C0D6E1821FA6B3-8010 Fresh air blower control module (front): Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B Component: J126 FLuftV H09 0003 Serial number: 00000000000002941208 Humidity sensor: exterior: Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A Component: AQ_Hum_Sensor H02 0007 Serial number: 2401965900PAG0MUFU02 Rear air conditioning block 1: Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158 Component: E265 Kli Fond H40 0080 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:* Redir Fail! Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG Component: BCM1 MLBevo H13 0313 Dataset Number: 8WD909514A 0010 Coding: 07501143E11800CD0545571818AC80B9110B310C000000000000000020001A810A450122025601 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_BCM1BOSCHAU736 019008 ROD: EV_BCM1BOSCHAU736_019.rod VCID: 03538F112B96E6C2129-8056 Wiper motor control module: Subsystem 1 - Part No SW: 8W6 955 119 B HW: 8W6 955 119 Component: 494 LL 061018 036 0481 Serial number: 00000001810010308443 Coding: FFC7F7 Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555 Component: G397_RLFSS H06 0002 Serial number: 21999445X81A955555A0 Coding: 02005D Light switch: Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG Component: E1 - LDS H06 0008 Serial number: 23 06 2018 01515135 Automatic dimming interior mirror: Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511 Component: Y7_Innenspieg H09 0002 Serial number: GX1CE115081823811854 Coding: 030000 Interior Light Module: Subsystem 5 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L Component: Dachmodul H42 0413 Serial number: B00970453 Coding: 0D0104 Control head for driving and comfort functions: Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC Component: SL-B9/Q5NF H17 0010 Serial number: 2818000117950003 Coding: 000000 Valve block 1 in front seat driver side: Subsystem 7 - Part No SW: 8W0 907 182 HW: 8W0 907 182 Component: J873 MKS_FSv H03 0036 Serial number: 7008174235B184182870 Coding: 1E0500 Valve block 1 in front seat passenger side: Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182 Component: J872 MKS_BFSv H03 0036 Serial number: 7008174235B184080174 Coding: 120500 2 Faults Found: 66657 - Local Databus 5 U1506 00 [008] - No Communications Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 7 Reset counter: 117 Mileage: 87628 km Date: 2023.10.11 Time: 21:06:49 average_Voltage_terminals: 11.90 V Outside air temperature sensor-Resistance: 0.00 kOhm Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C interior_temperature: 21.00 °C Vehicle speed: 0.00 km/h Terminal activation-Terminal 75 status: On Terminal activation-Terminal 15 status signal: On Terminal activation-Terminal 15 via CAN: On Terminal activation-Term 75: qualification: OFF 66658 - Local Databus 6 U1507 00 [008] - No Communications Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 7 Reset counter: 117 Mileage: 87628 km Date: 2023.10.11 Time: 21:06:49 average_Voltage_terminals: 11.90 V Outside air temperature sensor-Resistance: 0.00 kOhm Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C interior_temperature: 21.00 °C Vehicle speed: 0.00 km/h Terminal activation-Terminal 75 status: On Terminal activation-Terminal 15 status signal: On Terminal activation-Terminal 15 via CAN: On Terminal activation-Term 75: qualification: OFF ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8W0-959-655.clb Part No SW: 8W0 959 655 F HW: 8W0 959 655 F Component: Airbag10.44 H03 0107 Serial number: 003UP00LCV1. Dataset Number: 8W2909602AE 0004 Coding: AACCF0C00C800000585400F3D04C00000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirbaAU10BPAAU736 006016 ROD: EV_AirbaAU10BPAAU736_006.rod VCID: 4CC1642D4648E9BAA33-8018 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 442 060 710 18 Component: SideSensor_Df 1E2 0887 Serial number: 3577Y00C12C58C00D32/ Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 442 060 710 18 Component: SideSensor_Pf 1E2 0887 Serial number: 3587Y00AF2C0ABB2453D Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 442 0B1 609 18 Component: SideSensor_Dr 1C7 0148 Serial number: 3517700B52D101C0326- Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 442 0B1 609 18 Component: SideSensor_Pr 1C7 0148 Serial number: 35277009F2D1B0F0F30M Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 442 0C0 810 18 Component: FrontSensor_D 1C5 014A Serial number: 35575009B2D09FD3033K Coding: 2D2D2D Crash sensor for front airbag: front passenger side: Subsystem 6 - Part No SW: ----------- HW: 442 0C0 810 18 Component: FrontSensor_P 1C5 014A Serial number: 35675009B2D09FD682E% Coding: 2D2D2D Center pedestrian protection crash sensor: Subsystem 7 - Part No SW: ----------- HW: 442 0C0 810 18 Component: PedP_Sensor_C 1C5 014A Serial number: 2307500A92D09FD4A31K Coding: 2D2D2D Driver's side crash data pedestrian protection 2: Subsystem 8 - Part No SW: ----------- HW: 442 430 410 18 Component: PedPSensor_D2 256 0887 Serial number: I0M9M00C929973E523EV Coding: 2D2D2D Passenger's side crash data pedestrian protection 2: Subsystem 9 - Part No SW: ----------- HW: 442 430 410 18 Component: PedPSensor_P2 256 0887 Serial number: I0N9M00BD29973E2D31U Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb Part No SW: 4N0 907 129 S HW: 4N0 907 129 S Component: Lenks.Modul H03 0005 ASAM Dataset: EV_SMLSKLOAU736 007012 ROD: EV_SMLSKLOAU736_007_AU49.rod VCID: 41DF4519710A34D2405-8014 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2 Part No SW: 8W5 920 790 E HW: 8W5 920 790 E Component: FBenRDW H19 0417 Coding: 05A440C6288000080020E9601000000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DashBoardAU736 001032 ROD: EV_DashBoardAU736_AU49.rod VCID: 44D14C0D6E1821FA6B3-8010 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:* None Part No SW: 8W5 907 468 H HW: 8W5 907 468 G Component: Gateway H43 0144 Revision: AS000001 Serial number: 018AS780318A19 Dataset Number: 8W2909515F 0049 Coding: 0301000100000640410700000059001248180007100000000175078E10000000 Shop #: WSC 06335 790 00001 GVL: 01503C0008040000408C08000000C80010080000000000000000000000000000 ASAM Dataset: EV_CGateCONTIAU491 003170 ROD: EV_CGateCONTIAU491_003_AU49.rod VCID: 4EC56E25B054DBAACD7-801A Multifunction steering wheel control module: Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F Component: J453 MFL H04 0004 Serial number: 20181016114649 21576 Battery Monitoring Control Module: Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C Component: J367-BDMHella H10 9070 Serial number: 6957129304 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light (J1018) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909519B 0003 ASAM Dataset: EV_LCMLeftHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 77ABEBC16F4EBA623E1-8022 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light (J1023) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909520B 0003 ASAM Dataset: EV_LCMRightHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 77ABEBC16F4EBA623E1-8022 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:* None Part No SW: 8W0 959 593 H HW: 8W0 959 593 F Component: TSG FS 005 0130 Serial number: 0000347224547 Dataset Number: 8W2909872D 0026 Coding: 00544B624000000000001400 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod VCID: 4FFB7321B75ED2A2C61-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:* None Part No SW: 8W0 909 144 H HW: 8W0 909 144 B Component: EPS_MLBEVO_ZF H08 0410 Dataset Number: 8W2909852Q 0032 Coding: 09000380008000 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_EPSZFAU49X 003023 ROD: EV_EPSZFAU49X_003.rod VCID: 42DD4A15740C2FCA59F-8016 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:* None Part No SW: 8W0 907 064 GC HW: 8W0 907 064 DC Component: BCM2 MLBevo 025 0424 Dataset Number: 8W2909501G 0039 Coding: 01340000002000E06301A0006C00080211024000804306502F0400000504803F001F0001000010 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BCM2HellaAU736 016016 ROD: EV_BCM2HellaAU736_016_AU49.rod VCID: 03538F112B96E6C2129-8056 Rear lid opener control module: Subsystem 1 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H Component: GEB.F.Heckoef H16 0905 Serial number: 12094668 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:* None Part No SW: 8W0 035 465 HW: 8W0 035 465 Component: MIB2_amp_P_B9 H11 0420 Revision: 00000001 Serial number: AUZ8ZAJJA04ZA8I Dataset Number: 8W2909510C 0010 Coding: 0194030800AFAAAFAA0000010000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012 ROD: EV_AMPMst16C2Gen2ALPI.rod VCID: 76B5E6C56844C36A257-8022 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:* None Part No SW: 8W0 959 592 H HW: 8W0 959 592 F Component: TSG BFS 005 0130 Serial number: 0000348125486 Dataset Number: 8W2909873D 0026 Coding: 00544B224000000000001400 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod VCID: 4EC56E25B054DBAACD7-801A No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb Part No SW: 8W5 035 036 C HW: 8W5 035 036 Component: MU-P-LN-EU 035 1329 Serial number: A795J0JB118744 Dataset Number: 8W2909545P 0039 Coding: 019403010000000053110002000A00332F000DE501700100DE Shop #: WSC 06335 790 00001 ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 ROD: EV_MUHig6C3Gen2HBAS_AU49.rod VCID: 382928FD22D0751AF7B-806C Data carrier: Subsystem 1 - Part No SW: V03 959 802 TK HW: ----------- Component: ECE 2021 --- 0189 Serial number: -------------------- Multimedia System 1: Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605 Component: DU High AU49x H32 0170 Serial number: TPO00101091800820036 Multimedia system control head: Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T Component: ControlUnit_H H30 0206 Serial number: APVAK128081800020060 Compact disc data bank: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1017 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 8W8 959 107 D HW: 8W8 959 107 Component: HDSG-Modul H13 0170 Revision: -------- Serial number: A2-C744-8781-0 Dataset Number: 8W2909541D 0009 Coding: 0630 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DeckLidCONTIAU736 001016 ROD: EV_DeckLidCONTIAU736_AU37.rod VCID: 4ACD62354C3CF78A91F-801E No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb Part No SW: 8W1 713 041 N HW: 8W1 713 041 K Component: GSM-LL H10 0077 Revision: 0L0D5012 Serial number: 18102349798483 ASAM Dataset: EV_GSMWaehlZFAU736 001017 ROD: EV_GSMWaehlZFAU736_AU49.rod VCID: 3E253EE500F44B2A3D7-806A No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail! Part No SW: 8W6 907 217 B HW: 8W6 907 217 A Component: BVS H17 0052 Dataset Number: 8W2909466C 0019 Coding: 0404090300000401022023A0A50000FC00F0C020C000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026 ROD: EV_BVSMLBevKOSTAAU736_AU49.rod VCID: 41DF4519710A34D2405-8014 No fault code found. ------------------------------------------------------------------------------- Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb Part No SW: 4M0 907 355 D HW: 4M0 907 355 B Component: SCR-Stg-G3H05 0006 Dataset Number: 8W2909571D 0005 ASAM Dataset: EV_RDCMINERGAU736 005012 ROD: EV_RDCMINERGAU736_AU49.rod VCID: 323D1AD5C4AC9F4AC9F-8066 No fault code found. ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 8W0 959 395 H HW: 8W0 959 395 F Component: TSG HFS 005 0130 Serial number: 0000336429111 Dataset Number: 8W2909897D 0026 Coding: 000049220000000000001000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005 ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod VCID: 4FFB7321B75ED2A2C61-801A No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 8W0 959 395 H HW: 8W0 959 395 F Component: TSG HBFS 005 0130 Serial number: 0000336430677 Dataset Number: 8W2909896D 0026 Coding: 000049220000000000001000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005 ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod VCID: 4FFB7321B75ED2A2C61-801A No fault code found. ------------------------------------------------------------------------------- Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb Part No SW: 4M0 907 594 J HW: 4M0 907 594 Component: SAD_STG_1 014 0005 Dataset Number: 8W2909469C 0009 Coding: 428000049301 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_SunRoofCONTIAU736 006008 ROD: EV_SunRoofCONTIAU736_006.rod VCID: 3D2739E90DF2503224D-8068 No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1L H09 0008 Dataset Number: 8W2909471A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModLeftMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A62DE1-8042 No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1R H09 0008 Dataset Number: 8W2909472A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModRightMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A62DE1-8042 No fault code found. End----------(Elapsed Time: 01:49, VBatt start/end: 12.0V/12.1V)----------- Czasem pozwala to usunąć, czasem nie, ale zawsze wraca
Muskel1 Opublikowano 19 Października 2023 Opublikowano 19 Października 2023 Co było przy aucie robione? Zmieniałeś coś w kodowaniach?
lestat2244 Opublikowano 21 Października 2023 Autor Opublikowano 21 Października 2023 W dniu 2023. 10. 19. o 17:46, Muskel1 napisał(a): Mit csináltak az autóval? Változtattál valamit a kódoláson? Nie, nic nie kodowałem
Muskel1 Opublikowano 21 Października 2023 Opublikowano 21 Października 2023 Czy robiłeś coś przy instalacji/wiązkach?
