[B5 ATJ] Proszę o analizę logów
Witam! Proszę o analizę logów B5 ATJ quattro 2000 r
Auto dużo pali 10l w mieście i 8,2 na trasie.
Basic Settings:
http://img204.imageshack.us/i/bst000.jpg/
http://img204.imageshack.us/i/bst003.jpg/
http://img204.imageshack.us/i/bst011.jpg/
Statyczne:
http://img204.imageshack.us/i/stat000.jpg/
http://img200.imageshack.us/i/stat001.jpg/
http://img204.imageshack.us/i/stat003.jpg/
http://img204.imageshack.us/i/stat004.jpg/
http://img204.imageshack.us/i/stat007.jpg/
http://img204.imageshack.us/i/stat008.jpg/
http://img204.imageshack.us/i/stat013.jpg/
http://img41.imageshack.us/i/stat018.jpg/
http://img29.imageshack.us/i/stat023.jpg/
Dynamiczne:
http://img41.imageshack.us/i/dyn000.jpg/
http://img204.imageshack.us/i/dyn001.jpg/
http://img41.imageshack.us/i/dyn003.jpg/
http://img41.imageshack.us/i/dyn004.jpg/
http://img41.imageshack.us/i/dyn008.jpg/
http://img29.imageshack.us/i/dyn010.jpg/
http://img41.imageshack.us/i/dyn011.jpg/
Umieszczam również wydruk z autotestu. Co to jest za błąd w grupie 35 - 00955:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CC
Component: 1,9l R4 EDC 0000SG 1091
Coding: 00006
Shop #: WSC 06325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D57
Coding: 00043
Shop #: WSC 06325
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 R
Component: KOMBI+WEGFAHRS. M73 D54
Coding: 00140
Shop #: WSC 02976
XXXXXXXXXXXXXXXXX AUZ5Z0B6237121
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13163
Shop #: WSC 02607
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
1 Fault Found:
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
End -------------------------------------------------------
dlaczego w logu 011 dynamiczny jest przeskok z 1300 rpm na 3400 rpm ... ?
lmm slabnie na wyzszych obrotach .. wymien filtr powietrza jak nie pomoze to przeplukanie lmm albo wymiana na nowy ..
poza tym nic zlego nie widac w aucie ...
p.s zrob jescze raz 011 i 008 dynamiczne od 1500 rpm ...
Przeskok bo takie warunki jazdy były chyba nie wiem - żona prowadziła. Zrobię jak tylko się nadarzy okazja. Pozdrawiam[br]Dopisany: 21 Lipiec 2009, 15:14_________________________________________________Nawet się udało zrobić nowe logi wracając z pracy:
008dyn:
http://img161.imageshack.us/i/dyn008nowy.jpg
011dyn:
http://img36.imageshack.us/i/dyn011nowy.jpg
A tutaj logowałem 015 i 006 podczas jazdy żeby zobaczyć ile żre paliwa i przy jakiej prędkości, ale nic mi to nie mówi, może ktoś coś widzi:
http://img161.imageshack.us/i/dyn015006nowy.jpg/
Dodam że auto ma niezłego kopa, może jest chipowany - czy to po czymś widać?
nie mozna otworzyc 008 i 011
jest dobrze :good: i przepływką i z turbiną
lekkie przyciecie gnoju w 008 przy 2400 .... :mysli: mozesz powtorzyc 008 ...
co do spalania to ciezko powiedziec nic w logach zlego nie widac .... a Quattro,PD-ek i Avant troche bedzie palil ... 8 w miescie to spokojnie ...
jakie opony ?
Powtórzyć 008 mogę dopiero w przyszłym tygodniu bo lapka zostawiłem w pracy i dziecko mi zachorowało.
Opony 195/65 r15 2,2 bar.
Wiem że w mieście 8 spokojnie, ale mój pali w mieście dychę , a na trasie przy jeżdzie góra 120 km/h poniżej 8 nie schodzi.
Hamulce nie zapieczone, nie wiem kurde może olej jakiś syfiasty w dyfrach i go wymienić.[br]Dopisany: 23 Lipiec 2009, 12:26_________________________________________________dynnowszy008.th.jpg
Zrobiłem znów 008 na czwartym biegu, auto bardzo płynnie przez żadnych szarpań doszło prawie do 4000 obr wówczas miałem ponad 100 km w mieście
Natomiast, Spanky, ja porównywałem logi z tabelami wartości i znalazłem naforum logi innego silnika ATJ - jak mój - i zauważyłem pewne róznice a mianowicie:
1) grupa 000 statyczna 10 kolumna u mnie pomiar powietrza 120 - 130, natomiast u innego ATJ - 74
2) grupa 003 basic setting przy EGR On pokazuje jego otwarcie na 64%, a czy nie powinno być 100% jak wskazują tabele wartości prawidłowych, podobnie przy EGR Off - 19% zamiast 0%
Co koledzy na to? czy to są pierdoły czy nie?
Pozdrawiam Mikołaj
fatycznie przy 2300 - 2400 jest obciete paliwo
wedlug mnie wszystko jest OK ...
zmien filtr powietrza i jezdzij ...
bardziej zastanawiajace jest to chwilowe obciecie gnoju .... :mysli:
Dzięki! Wymieniłem olej i filtry w maju. POzdrawiam Mikołaj[br]Dopisany: 28 Lipiec 2009, 08:16_________________________________________________W zasadzie podzas jazdy nie czułem że paliwo mi obcina, może zrobić jakieś grupy jednocześnie? POzdrawiam mik
