[B5 AFN] Prośba o analizę błędów.
O to bledy ktore mi wyskoczyly. Jezeli chodzi o imobiliser to objawy byly takie ze auto odpalalo i gaslo i tak pare razy ale nie wiem jaka jest tego przyczyna.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 028 906 021 CE
Component: 1.9l R4 EDC 00SG 0803
Coding: 00002
Shop #: WSC 30011
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
1 Fault Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 035 Q
Component: B5_KOMBIINSTRUMENT D09
Coding: 00440
Shop #: WSC 00003
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T6861016 D77
Coding: 00000
Shop #: WSC 55555
3 Faults Found:
01176 - Key
07-10 - Signal to Low - Intermittent
00750 - Warning Lamp
28-00 - Short to B+
31-10 - Open or Short to Ground - Intermittent
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 A
Component: ZV-Pumpe, DWA
Coding: 01416
Shop #: WSC 65535
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
End -------------------------------------------------------
Wykasuj i zobacz co powróci... co do immo to jest tego pełno na forum, problem dotyczy cewki przy stacyjce... :szukaj:
Czy ten blad z kluczem i immo moze byc tez spowodowany slabym akumulatorem?
