[B6 AYM] Prosze o analizę błędów
YAMAHA_R1
Witam wszystkich. Jestem nowy w tym klubie. :) Prosił bym o analize bledow z vaga i porade co z nimi zrobic. :wink4:
VAG-COM Version: Release 311.2-N
Viaken
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 907 401
Component: 2.5L V6 TDI 0000SG 0006
Coding: 02012
Shop #: WSC 63351
00003059 130 106JC150_1.V77647224190
2 Faults Found:
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
00522 - Engine Coolant Temperature Sensor (G62)
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04455
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 D
Component: int. Lastmodul RDW 0203
Coding: 00111
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 00010
Shop #: WSC 07777
WAUZZZ8E52A162962 AUZ6Z0A0275861
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AE
Component: Komfortgerát T01 0315
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00060
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0007
Coding: 00001
Shop #: WSC 63351
End -------------------------------------------------------
jeżeli chodzi o silnk : bład poduszki silnika i czujnika temp. płynu wykasuj wszystko i jeszcze raz przeskanuj
wystaczy kod błedu wpisać w szukajkę i masz odpowiedzi multum :cool1:
Skasuj pojezdzij troche i zobacz czy wracają te bledy.
Błedu czujnika temperatury raczej bym nie lekcewazyl.
Malo info jest o nim moze ktos napisac co to za bład.
duże spadki napiecia moga generowac ten blad (slabe AQ)
