YAMAHA_R1 0 Opublikowano 4 Lutego 2011 Udostępnij Opublikowano 4 Lutego 2011 Witam wszystkich. Jestem nowy w tym klubie. Prosił bym o analize bledow z vaga i porade co z nimi zrobic. VAG-COM Version: Release 311.2-N Viaken Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 907 401 Component: 2.5L V6 TDI 0000SG 0006 Coding: 02012 Shop #: WSC 63351 00003059 130 106JC150_1.V77647224190 2 Faults Found: 01375 - Valves for Engine Mounting: Stage 1 38-10 - Output won't Switch or Short to B+ - Intermittent 00522 - Engine Coolant Temperature Sensor (G62) 30-10 - Open or Short to B+ - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04455 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 65535 - Internal Control Module Memory Error 00-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 D Component: int. Lastmodul RDW 0203 Coding: 00111 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00002 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D25 Coding: 00010 Shop #: WSC 07777 WAUZZZ8E52A162962 AUZ6Z0A0275861 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T01 0315 Coding: 06976 Shop #: WSC 63351 1 Fault Found: 01366 - Opened Due to Crash Signal 36-10 - Open Circuit - Intermittent Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D06 Coding: 00060 Shop #: WSC 63351 No fault code found. Address 56 ------------------------------------------------------- Controller: 8E0 035 186 Component: concert II GRO 0007 Coding: 00001 Shop #: WSC 63351 No fault code found. End ------------------------------------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wojtekce 1 Opublikowano 4 Lutego 2011 Udostępnij Opublikowano 4 Lutego 2011 jeżeli chodzi o silnk : bład poduszki silnika i czujnika temp. płynu wykasuj wszystko i jeszcze raz przeskanuj wystaczy kod błedu wpisać w szukajkę i masz odpowiedzi multum Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
YAMAHA_R1 0 Opublikowano 4 Lutego 2011 Autor Udostępnij Opublikowano 4 Lutego 2011 Tak wiem bo przegladalem forum. Tylko nie wiem czy to cos powaznego, i czy mozna to zignorowac. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
przemik 2 Opublikowano 5 Lutego 2011 Udostępnij Opublikowano 5 Lutego 2011 Skasuj pojezdzij troche i zobacz czy wracają te bledy. Błedu czujnika temperatury raczej bym nie lekcewazyl. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
YAMAHA_R1 0 Opublikowano 5 Lutego 2011 Autor Udostępnij Opublikowano 5 Lutego 2011 Ok. Dzienki za odpowiedz. Błedy skasowalem i wyglada ze wszystko jest ok. Zostal tylko ten: 65535 - Internal Control Module Memory Error Malo info jest o nim moze ktos napisac co to za bład. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
leo... 0 Opublikowano 6 Lutego 2011 Udostępnij Opublikowano 6 Lutego 2011 65535 - Internal Control Module Memory Error Malo info jest o nim moze ktos napisac co to za bład. duże spadki napiecia moga generowac ten blad (slabe AQ) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
YAMAHA_R1 0 Opublikowano 6 Lutego 2011 Autor Udostępnij Opublikowano 6 Lutego 2011 No to juz wiem co go boli Auto stoi prawie cala zime bez jazdy. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
