[B5 AVG] Czujnik otwartych drzwi 1/2 FIS i pełny FIS
Po lewej licznik 1/2 FIS a po prawej pełny FIS.
Miałem licznik 1/2 FIS czyli jak na zdjęciu poniżej:
Midline-instrument cluster
A - Green 32-pin multi-pin connector
B - Blue 32-pin multi-pin connector
C - Discontinued
D - Black 4-pin multi-pin connector for remote clock (not connected in US)
Czyli posiada on tylko dwa gniazda Zielone i Niebieskie.
I ten licznik sygnalizuje otwarcie poszczególnych drzwi
łącznie z klapą bagażnika. Niestety w opisie pinów
nie ma sygnału z wszystkich drzwi oprócz kierowcy:
connector
for basic functions:
1 - Terminal 15
2 - Brake pad wear
3 - Tachometer output 1
4 - not occupied
5 - Tank sensor
6 - Tank warning OBD 2
7 - Terminal 31 (sensor Ground (GND))
8 - Coolant temperature
9 - Terminal 31 (load Ground (GND))
10 - Oil pressure 2 (high)
11 - RPM signal
12 - A/C shut-off
13 - E-Gas/glow plug control
14 - Level control
15 - Terminal 58d
16 - Trailer turn signal
17 - High beam
18 - Left turn signal
19 - not occupied
20 - Terminal 58s
21 - Driver door contact
22 - Low coolant
23 - Terminal 30
24 - Terminal 31 (load Ground (GND))
25 - Consumption signal
26 - Right parking light
27 - Left parking light
28 - Tachometer input
29 - Brake
30 - S-contact
31 - Tachometer output 2
32 - ESP/ASR
connector
for auxiliary functions:
1 - Door contact (all doors)
2 - Transponder 1
3 - not occupied
4 - not occupied
5 - W-wire
6 - Tailgate
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Stand-still time output
12 - Terminal 61
13 - Parking brake/BRAKE
14 - CHECK
15 - Oil level/oil temperature
16 - not occupied
17 - Transponder 2
18 - CAN high speed (powertrain) (high +)
19 - CAN high speed (powertrain) (low -)
20 - CAN high speed (powertrain) (screen)
21 - ABS
22 - CAN low speed (comfort) (high +)
23 - CAN low speed (comfort) (low -)
24 - CAN low speed (comfort) (screen)
25 - Engine lid
26 - not occupied
27 - Belt buckle
28 - K-wire
29 - Outside temperature -input
30 - not occupied
31 - Selector range display
32 - not occupied
Mam taki licznik czyli pełny FIS:
highlineinstrumentclustcd2.gif w liczniku VDO gniazdo C jest ułożone pionowo
Highline-instrument cluster
C - Gray 32-pin multi-pin connector
Czyli posiada on trzy 32 pinowe gniazda w których są sygnały wszystkich drzwi.
Skąd wziąć sygnał pozostałych drzwi??? ;( Sygnał kierowcy jest w 1/2 FIS...
connector
1 - Terminal 15
2 - Brake pad wear
4 - not occupied
5 - Tank sensor
11 - RPM signal
12 - A/C shut-off
14 - Level control
15 - Terminal 58d
17 - High beam
19 - not occupied
20 - Terminal 58s
22 - Low coolant
23 - Terminal 30
29 - Brake
30 - S-contact
32 - ESP/ASR
connector
2 - Transponder 1
3 - not occupied
4 - not occupied
5 - W-wire
6 - Tailgate
8 - External buzzer
9 - External gong
10 - Airbag
12 - Terminal 61
14 - CHECK
16 - not occupied
17 - Transponder 2
21 - ABS
25 - Engine lid
26 - not occupied
27 - Belt buckle
28 - K-wire
30 - not occupied
32 - not occupied
connector
for multi-function display
1 - Menu selection switch (menu)
2 - Menu selection switch (out A)
3 - Menu selection switch (out B)
4 - Menu selection switch (Enter)
5 - CAN high speed display (high +)
6 - CAN high speed display (low -)
7 - CAN high speed display (screen)
8 - Passenger door contact
9 - Right rear door contact
10 - Left rear door contact
11 - Enable
12 - Clock
13 - Data
14 - Brake light
15 - Windshield washer fluid level
16 - Rear lights/low beams
17 - Left board computer
18 - Right board computer
19 - Board computer, reset
20 - not occupied
21 - not occupied
22 - not occupied
23 - Button branch 1 navigation
24 - Button branch 2 navigation
25 - Button branch Telematic
26 - not occupied
27 - not occupied
28 - not occupied
29 - not occupied
30 - not occupied
31 - not occupied
32 - not occupied
Skąd wziąć sygnał o otwartych drzwiach z licznika 1/2 FIS ??? ;(
  • 7 miesięcy temu...
Trzeba podpiac pod drzwi i odpowiednio piny do szarej wtyczki :decayed:
  • 6 miesięcy temu...
To jak działało gdy nie było tej wtyczki? :mysli:[br]Dopisany: 04 Lipiec 2008, 22:00_________________________________________________odgrzeję temat. może ktoś już to rozpracował?
Odgrzewam kotleta :) ma ktoś jakiś pomysł, które to kabelki są odpowiedzialne?
Mam ori pełny FIS i działa mi tylko sygnalizacja o klapie bagażnika, nie działa sygnalizacja nawet dla drzwi kierowcy.
Styki mam dobre, bo wszystkie światełka reagują poprawnie.
Pozdro
Łukasz
Dobra, w łekend pomajstruję tam troszkę. Z opisu końcówek wynika, że doprowadzenie sygnału jest możliwe. Największy problem może być z kodowaniem. Co z tego, że będzie sygnał, jeżeli FIS nie będzie reagował.
Ma ktoś w ogóle B5 z sygnalizacją tych nieszczęsnych drzwi? Przydało by się kodowanie :)
zobacz czy masz dobrze podpiety zolty kabelek w niebieskiej kostce... jezeli dobrze pamietam :gwizdanie: ale nie jestem pewien.
Mam FIS z sygnalizacją otwartych drzwi. Planuję w niedzielę pogrzebać trochę przy aucie. Pisz co potrzebujesz :-) to lapka też wezmę :decayed:
  • 4 tygodnie później...
Szybko się obudziłem... :polew: whitebox, uderzę do Ciebie na PW, jak będę miał jakieś konkretne pytania. Jak by się udało to rozkminić, to pewnie nie jeden posiadacz B5 był by zadowolony :)
Czy możesz zacząć od sprawdzenia, czy schemat opisany na początku zgadza się z tym co masz u siebie, chodzi o kolorki kabli.
  • 9 miesięcy temu...
