[B6 ALT] Prośba o ponowne sprawdzenie błędów
Witam ponownie. Proszę o sprawzenie logów. Szczególnie w grupie ABS/ESP. Wymieniłem czujnik pedału hamulca. Po wymianie błąd zniknął, ale pojawił się problem abs.
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 907 557
Component: 2.0L R4/5VS 0006
Coding: 0011501
Shop #: WSC 63351
1 Fault Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0110 0001
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04275
Shop #: WSC 00491
2 Faults Found:
01486 - System Function Test Activated
35-00 - -
01435 - Brake Pressure Sensor 1 (G201)
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AL
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
No fault code found.
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0302
Coding: 00001
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D12
Coding: 00400
Shop #: WSC 00001
WAUZZZ8EZ1A058441 AUZ6Z0A0082933
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0503
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AC
Component: Komfortgerát T9F 0313
Coding: 06858
Shop #: WSC 00491
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01331 - Door Control Module: Driver Side (J386)
80-00 - Single-Wire Operation
End -------------------------------------------------------
Dzięki za odpowiedź. Już poprawiłem temat :) Strasznie mnie zastanawia ten ABs. Na starym czujniku było wszystko OK. MIałem tylko, że błąd światła stopu i zapalała się kontrolka od ESP. Po wymianie czujnika zapala się przy starcie silnika kontrolka ABS i ESP...i nie chcą zgasnąć ;/
