[B6 AWX] 1-sze testy ||| Prośba o analizę błędów
Witam.
Pierwszy raz mam styczność z vagiem itp. w vagu wciśnięciu opcji AUTO SCAN wykazało chyba parę albo i więcej błędów. Proszę Was jako ekspertów a o ich analizę. Z góry dziękuję ! :hi:
oto logi:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00002
Shop #: WSC 63351
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 30188
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0912
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00100
Shop #: WSC 19411
WAUZZZ8E72A216973 AUZ6Z0A0337219
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AE
Component: Komfortgerát T01 0315
Coding: 06720
Shop #: WSC 63351
4 Faults Found:
01331 - Door Control Module: Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01803 - Door Warning Lamp: Rear Left (W37)
57-10 - Electric Circuit Failure - Intermittent
01562 - Right Rear Door
End -------------------------------------------------------
[br]Dopisany: 18 Lipiec 2011, 21:35_________________________________________________może dzięki tych błedów dowiem się co nie co u moim audi (a4 b6 sedan)
czy przyczynę mogę sprawdzić vag'iem
tak,powinno wyświetlić rodzaj usterki w sterowniku modułu komfortu
a jakiś schemat jakie kable odpowiadają za otwieranie klapy bagażnika???
najpierw zeskanuj sterownik,to może być problem mikrostyku w przycisku-więc po co Ci teraz schemat?
1274-nastawnik klapy spiętrzającej V71
604-potencjometr w V71
1331-sterownik drzwi kierowcy(J386)
1561-tylne lewe drzwi
1562-tylne prawe drzwi
1803-lampka ostrzegawcza drzwi lewy tył
pokasuj te błędy i zobacz czy się beda powtarzac
ten błąd może być tego przyczyną???
nie nie ma związku z bagażnikiem-
rozumiem,że taka konfiguracja klucza w zamku została przetestowana
co do sposobu ktory podałeś domjenick niestety nie działa... :gwizdanie: a jeszcze pytanie co do tego błędu : 1331-sterownik drzwi kierowcy(J386) wyczytałem ze przyczyną tego może być przerwany kabelek pomiędzy drzwiami a słupkiem to prawda?
prawda i sądząc po błędach-będziesz mieć problem z tymi kablami z tyłu po obu stronach-opisałem dokładnie w "Warsztat,zrób to sam" jak i co naprawić,co do problemu z bagażnikiem-najpierw sprawdziłbym sam przycisk-tam może coś nie stykać i dlatego nie otwiera
po wykasowaniu błędów został jedynie błąd przepalonej żarówki bodajże po lewej stronie (tył)... i tylko jeden związany z klimą. co do błędu 1331 nie występuje już. co do tego bagażnika to rozbierałem ten siłownik w klapie i rzeczywiście blaszka straciła swoje właściwości ale dałem nową i niby powinno być ok... przycisk od otwierania też cały rozebrałem przy okazji naprawiłem niedziałającą zarówkę przy rejestracji... po poskładnaniu nic nie zaskakuje zostaje tylko kluczyk. wydaję mi się ze kabelek gdzieś się przerwał i tyle... będę musiał rozkopać auto...[br]Dopisany: 20 Lipiec 2011, 11:39_________________________________________________
przycisk nie działa ale powinno chociaż działać otwieranie klapy z przycisku kluczyka a tak niestety nie jest.... :wallbash:
więc nie dochodzi prąd do zamka
