juzek114 Opublikowano 18 Grudnia 2011 Opublikowano 18 Grudnia 2011 VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: Note: Can't Synch Baud Rate Address 03 ------------------------------------------------------- Controller: 4D0 907 379 D Component: ABS BOSCH 5 7402 Coding: 0265108005 Shop #: BB 37402 No Faults Found or DTCs not supported by controller or a communication error ocurred Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: Note: Can't Synch Baud Rate Address 25 ------------------------------------------------------- Controller: 4A0 953 234 Component: IMMO AUZ9Z0RN159932 D75 Coding: 00000 Shop #: WSC 00012 2 Faults Found: 01176 - Key 07-00 - Signal to Low 00750 - Warning Lamp 31-10 - Open or Short to Ground - Intermittent End -------------------------------------------------------
danu44 Opublikowano 20 Grudnia 2011 Opublikowano 20 Grudnia 2011 Juzek, sloneczko a gdzie te logi...? A czy Ty aby przypadkiem nie masz silnika na gassss... Pozdrawiam
