[B6 AVJ] DTC - który odpowiada za aku?
Witam, ostatnio auto zjada mi cały aku w 3-4h postoju. Nie wiem od czego zacząć poszukiwania dla tego na początek sprawdziłem jakie mam błędy:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518
Component: 1.8L R4/5VT G 0001
Coding: 0011501
Shop #: WSC 63351
No fault code found.
Readiness: 0110 1101
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04275
Shop #: WSC 00000
2 Faults Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
00778 - Steering Angle Sensor (G85)
37-10 - Faulty - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 00000
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00041
Shop #: WSC 00672
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 19411
WAUZZZ8E92A101534 AUZ6Z0A0202336
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06720
Shop #: WSC 63351
5 Faults Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
00932 - Electric Window Motor: Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
57-10 - Electric Circuit Failure - Intermittent
01331 - Door Control Module: Driver Side (J386)
37-00 - Faulty
01332 - Door Control Module: Passenger Side (J387)
37-00 - Faulty
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0006
Coding: 00203
Shop #: WSC 63351
2 Faults Found:
00857 - CD Changer Unit (R41)
49-10 - No Communications - Intermittent
00858 - Connection: Radio ZF Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
End -------------------------------------------------------
Może ma ktoś jakiś pomysł czy któryś z powyższych błędów może mieć związek z rozładowywaniem aku?
00943 to błąd przepalenia maty grzewczej w lusterku może tak jakieś małe zwarcie. Widze że ASR nie działa uszkodzony czujnik skrętu ale to nie od tego napewno masz jakieś błędy na module komfortu oraz na klimatroniku ale po wyłączeniu zapłonu chyba nie powinno być napięcia na matach grzewczych klimatroniku jedynie na module może być napięcie bo otwierasz lub zamykasz auto mimo że zgaszone i szybami też można sie bawić pilotem. Może tam coś nie tak, jakieś zwarcie. Bo błędów tam niemało.
Hmm, zastanawiające bo ja nie mam podgrzewanych lusterek... Może w takim razie pójść tym tropem ?
do tego najlepiej przydałby się miernik cęgowy
otwierasz maskę, kluczykiem zamykasz auto następnie miernik cęgowy zakładasz na przewodzie plusowym przy akumulatorze i obserwujesz co się dzieje
przez pierwsze 40 sek po zamknięciu auta pobór prądu powinien wynosić ok 2-4A po tych 40 sek amperaż powinien spaść do 0,4A czyli 40mA
jeżeli okaże się że pobór prądu z aku wynosi ciągle np 4A wtedy wyjmujesz wszystkie bezpieczniki i wkładasz je po kolei zamykając za każdym razem auto i obserwując miernik, przy którymś bezp. (obwodzie) ujawni ci się winowajca
tak jak kolega wyżej opisał,z tym że otwierasz drzwi kierowcy i pokrywę silnika zamykasz ręcznie same zamki(drzwi i macha otwarte)zamykasz teraz kluczem auto,odpinasz aku.klema+ podłączasz miernik odpowiednio ustawiony i patrzysz jaki jest pobór prądu,na sprawnej instalacji jest to 0.02A do 0.05A i teraz masz niby auto zamknięte ale masz dostęp do bezpieczników wyciągaj je pojedynczo i obserwuj wskazania na mierniku a na pewno znajdziesz przyczynę i jeszcze jedno czy aku. masz sprawny?bo jak tak to pobór musi bardzo duży.Kolego krzycho78 0.4A to stanowczo za dużo.
Dzisiaj pogoda pozwoliła mi na szybko dokonać kilku pomiarów. Jedna rzecz mnie nie pokoi, po wyciągnięciu wszystkich bezpieczników miernik wskazywał pobór 0,015A i raz na dwie sekundy skakał na chwilę do 0,008A. Czy to normalne? Czy gdzieś jeszcze jest jakaś "ukryta" tabliczka z bezpiecznikami?
Po włożeniu bezpieczników na górną część tabliczki z bezpiecznikami pobór wzrósł do 0,062A z cyklicznymi chwilowymi skokami do 0.055A.
Po włożeniu bezpieczników z dwóch pierwszych rzędów drugiej części tabliczki pobór wzrósł do 0,072A z cyklicznymi skokami do 0,059A.
Czy ktoś ma jakiś pomysł gdzie dalej szukać lub ewentualnie która, część tabliczki może odpowiadać za "zjadanie aku"?
p.s.: Miałem zamiar kontynuować poszukiwania ale niestety zaczęło się robić coraz ciemniej a drobny deszczyk nie rozpieszczał :P
p.p.s.: Aku roczny Varta Silver czy jakoś tak, sprawdzałem na innym aku i to samo tak wiec myślę, że można go wykluczyć.
Pobor pradu masz dobry.sprawdz jeszcze ladowanie aku powinno byc 14.2V przy zapalonych swiatlach.Na podmienionym aku tez 5 godzin i byl rozladowany?
Sprawdz ladowanie ipobor pradu na zalaczonym alarmie moze alarm ci go rozladowywuje. Inny aku tez rozladuje po 5h ?
