odczyt błędów po kraksie ale z A6
Trzeba pomóc sąsiadowi. Skasowali przód A6 2.5TDI, naprawili to zczytałem błędy:
VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 401 F
Component: 2,5l/4VT EDC 00SG D32
Coding: 01002
Shop #: WSC 02324
2 Faults Found:
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00523 - Intake Air Temp Sensor (G42)
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 H
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 F
Component: A6-Klimavollautomat D55
Coding: 00063
Shop #: WSC 42901
2 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Address 15 -------------------------------------------------------
Controller: 4B0 959 655 J
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02324
2 Faults Found:
01217 - Side Airbag Igniter: Driver Side (N199)
32-10 - Resistance too High - Intermittent
00595 - Crash Data Stored
35-00 - -
Address 17 -------------------------------------------------------
Controller: 4B0 919 880 G
Component: C5-KOMBIINSTR. VDO D03
Coding: 21060
Shop #: WSC 00001
IMMO-IDENTNR: AUZ7Z0W0344100
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 A
Component: Zentralverriegelung D30
Coding: 04672
Shop #: WSC 02324
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01558 - Contact Switch in Locking Cyl: Driver Side: Close (F241)
29-00 - Short to Ground
01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241)
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D000
Coding: 00005
Shop #: WSC 02324
2 Faults Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
00774 - Level Control System Sensor: Left Rear (G76)
End -------------------------------------------------------
---------- Post dopisany at 18:56 ---------- Poprzedni post napisany at 18:15 ----------
Pozwoliłem sobie poszukać znaczenia kodów, ale mało mi one mówią co dalej.
Najpilniejsze rzeczy to świeci kontrolka poduszek (dlaczego błędów stamtąd wykasować się nie da?), jakieś pomarańczowe koło świeci (coś od hamulcy zdaje się), i coś z centralnym porobili, wymienili na koniec baterie w kluczyku i teraz auta zamknąć nie idzie.......
00553 - Mass Air Flow Sensor (G70) //Przepływomierz masowy powietrza MAF lub VAF (G70)
00523 - Intake Air Temp Sensor (G42) //Czujnik temperatury powietrza zasysanego IAT (G42) - wysoka wartość
18265 - Load Signal: Error Message from ECU //Sygnał ładowania - błędna wiadomość z silnika
00792 - A/C Pressure Switch (F129) //Czujnik (włącznik) ciśnienia środka chłodzącego klimatyzacji
01273 - Fresh Air Blower (V2) //Dmuchawa świeżego powietrza (V2)
01217 - Side Airbag Igniter: Driver Side (N199) //Zapalnik bocznej poduszki powietrznej strona kierowcy (N199)
00595 - Crash Data Stored //Zarejestrowane dane powypadkowe
35-00 - -
00779 - Outside Air Temp Sensor (G17) //Czujnik temperatury zewnętrznej (G17)
01366 - Opened Due to Crash Signal //Otwarcie po sygnale zderzenia
35-00 - -
01558 - Contact Switch in Locking Cyl: Driver Side: Close (F241) //Przełącznik kontrolny w zamykaniu DS.-F241 zamknięty
01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) //Przełącznik kontrolny w zamykaniu DS.-F241 otwarty
00668 - Supply Voltage Terminal 30 //Niskie napięcie zasilania ECM
00955 - Key 1 //Klucz 1
01538 - Motors for Headlight Range Adjustment (V48) / (V49) //Napędy regulacji strumienia światła V48/V49
00774 - Level Control System Sensor: Left Rear (G76) //Czujnik poziomu pojazdu tylni lewy (G76)
skasuj to na ubezpieczenie
co? jakie ubezpieczenie?
może chodzi oto by nie kasować błędów do puki ubezpieczyciel ich nie zobaczy
jak skasowałeś błędy to jakie wracają?
Błędy wykasowałem i po krótkiej przejażdżce (3km) znowu zczytałem. I wypluło tak:
Coding: 01002
Shop #: WSC 02324
2 Faults Found:
00575 - Intake Manifold Pressure
11-00 - Control Limit Not Reached
Readiness: N/A
Coding: 00012
Shop #: WSC 02325
No fault code found.
Coding: 00063
Shop #: WSC 42901
Note: Excessive Comm Errors
Coding: 00106
Shop #: WSC 02324
2 Faults Found:
35-00 - -
Coding: 21060
Shop #: WSC 00001
Coding: 04672
Shop #: WSC 02324
3 Faults Found:
00955 - Key 1
Coding: 00005
Shop #: WSC 02324
sprawdź czy kabel do przepływki jest podpięty
sprawdź czy podłączony jest kabel do czujnika na rurze dolotowej
zrób loga 011, statyczny, basic setting i jak dasz rade dynamiczny
boczna poduszka strona kierowcy jeżeli wybuchła kupić drugą, do czasu kupienia by kontrolka nie raziła i reszta poduszek działała można we wtyczkę od poduszki wsadzić rezystor ~1,5ohm, jak poduszka nie eksplodowała - odłącz klemę + akumulatora, odepnij kabelek od poduszki, psiknij sprajem kontakt do styków i złóż, może rezystancja wróci do normy
595 zarejestrowane dane z wypadku, poszukaj w necie jak to z kasować
pozostałe poszukaj co znaczą dokładnie
Zanim zaczniesz naprawiac airbag
Wymien sterownik airbag musisz taki kupic
4B0 959 655 J
Naprawa chyba sie nie oplaci nie jest rowniez bezpieczna,bo przy kolejnym wypadku moga poduchy nie odpalic
Dopiero wtedy na ,,odblokowanym'' sterowniku bedzie wiadomo(pokaze prawdziwe błedy) co uleglo uszkodzeniu napinacze pasow czy czujniki zderzen bocznych itp itd.
Moze sie okazac nawet ze teraz masz blad 01217 a wsadzisz dobry sterownik(czysty) i takiego bledu nie bedzie:decayed:
Jezeli instalacja do przeplywki sprawna i sama przeplywka sprawna,to spalony jest bezpiecznik szukaj po kolei(odpowiada on za przeplywke i swiatla wsteczne)taka glupota.
