Pytanie o tapicerkę skórzaną
Witam, czy z wymienionych poniżej kodów, można odczytac jaką skórę posiada auto ? a dokładnie, czy jest to skóra naturalna i jaki kolor ?
1 0CS L AED vehicle class differentiation 8E0
2 0F3 L KRS fuel system for diesel engine
3 0G1 L GES gearshift lever
4 0GE L AGM emissions concept EU 3
5 0JH L GKV weight category front axle weight range 8
6 0LW L SIZ special plates/stickers/ safety certificates for Germany
7 0TD E ZFM front and rear floor mats
8 0VC L BTA information kit in German
9 0W1 L AKZ label for central electric German-speaking countries
10 0YJ L GKH weight category rear axle weight range 9
11 1BA L DAE standard suspension/shock absorption
12 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
13 1D0 L AHV without towing attachment
14 1EX L TYP special identification plate for EC
15 1G3 E RER alloy spare wheel with original equipment tires
16 1KD L BAH disc brakes, rear
17 1LB L BAV disc brakes, front
18 1N1 L LEN power steering
19 1PA L ABR standard wheel bolts
20 1S7 L BOW tool kit and aluminum jack
21 1SA L TWU without additional engine guard
22 1T3 L VBK First aid kit with warning triangle
23 1VG L TWL installation parts for four-cylinder engine
24 1W0 L KBX without refrigerator/glove compartment cooling system
25 1WG L GFW transmission shaft w/ 88mm in diameter
26 1X0 L ATA front wheel drive
27 1YA L GFH without transmission shafts f. rear axle
28 1Z0 L KRM initial standard fuel filling
29 2A4 P UEA delivery equipment for shipment (transitcoating) with thick seat cover
30 2G0 L EBB without insert for the filling up of fuel
31 2K1 L SFS reinforced bumpers
32 2KR L SAU labels/plates in English and German
33 2PV P LRA leather trimmed sports steering wheel
34 2T0 L DAT without double-sized standard (DIN)
35 2V1 L FRI dust and pollen filter
36 2WA L ZBR without additional tires
37 2Z1 L TYZ type sign at rear and "Quattro" nameplates respectively
38 3B9 P ZKV child seat anchor for child seat system ISOFIX front and rear
39 3C7 P SHM 3-point seat belt for center rear seat
40 3CA L TRW without partition
41 3FA L DEI without roof insert (standard roof)
42 3L3 L SIE manual height adjustment for front seats
43 3NZ E HIS rear seat bench unsplit, backrest split folding
44 3Q6 P KOH three rear headrests
45 3S0 L DAR without roof rails/roof load rack
46 3X0 L DLS without load-through provision
47 3Y0 L SSR without roll-up sun screen
48 4A4 P SIH seat heater for front and rear seats separately controlled
49 4E0 L SDH tailgate/trunk lid unlocking from outside
50 4GH L WSS windshield tinted with windshield sunshield
51 4K4 L TKV radio remote controlled central locking operated from inside and separate trunk release
52 4KC L SSH side and rear windows tinted
53 4L2 L IRS dipping breakaway inside rear view mirror
54 4N0 L INT standard dashboard
55 4P2 L PBH rear floor panel module, type 3
56 4R4 E FEH power windows with comfort operation andcircuit breaker
57 4UF P AIB driver's and front passenger airbag with front passenger airbag deactivation
58 4W0 L KBO without cassette and CD storage unit
59 4X4 E SAB side airbag, front and rear with curtain airbag
60 4ZE L ZIE black moldings
61 5C0 L KSA without special body measures
62 5D1 L TRF carrier frequency 433.92 MHz
63 5K1 L LAC paint preservative (wax)
64 5MG E EIH decorative burr walnut inserts
65 5RU L ASR outer right rear view mirror: convex (large viewing field)
66 5SL L ASL outer left rear view mirror: non-spherical
67 6E3 E MAS center armrest front
68 6M0 L GPS without tie down straps/luggage net
69 6PC P HBV leatherette hand brake lever handle
70 6Q2 P SAG leather gearshift knob/handle
71 6R2 P SHV leather gearshift boot
72 6SS L KBB luggage compartment floor covering
73 6U0 L ZTD without additional seals outside
74 6V1 L HEB rear trim panel (ECE)
75 6W5 L KZV front license plate bracket
76 6XC L ASE outer rear view mirrors: powered
77 7A2 E CDW CD changer
78 7AA L EDW electronic vehicle immobilization device
79 7B0 L STD without socket
80 7CA L AKF without label for radio remote control
81 7K0 L RDK without tire pressure warning light
82 7M0 L EIL plastic scuff plates in door apertures
83 7P0 L LOR without lumbar support in front and rear seats
84 7Q0 L NAV without navigation device
85 7QA L CDR without CD ROM
86 7X0 L EPH without park distance control
87 8GU L GEN alternator 140A
88 8JH L HSW ellipsoidal headlight for driving on the right
89 8K0 L FLS without special low beam mode
90 8KA L KUE w/o catalytic converter warning light
91 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
92 8Q1 L LWR headlight-range adjustment
93 8T0 L GRA without cruise control system (CCS)
94 8TC L NEL rear fog light for driving on the right
95 8UD E RAO radio "concert"
96 8X0 L SWR without headlight washer system
97 8Z5 L MKU engine cooling system, type 1
98 9AK L HKA "Climatronic" with impact pressure control free of cfc
99 9M0 L ZUH without auxiliary/parking heater
100 9NX L FAS without electronic logbook
101 9P0 L SGK without seat belt warning light
102 9Q3 L MFA multi-function indicator, without on-board computer and check control
103 9T0 L BWD without heated washer nozzles
104 9VD E LSE speaker (active)
105 9W0 L VTV w/o car phone preparation/installation
106 A00 L SAH no self-collection
107 A8S I AUS standard equipment
108 B0A L BLB component parts set without country-specific design requirement
109 B99 L TPL type approval EC
110 C01 E COC operating permit, alteration 1
111 C1W L RAD forged alloy wheels 7J x 15 type 1, offset 39
112 D3E L MOT 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J
113 E0A L AAU no special edition
114 F0A L FZS no special purpose vehicle, standard equipment
115 FA0 L SVO control of standard production
116 FC0 L IND without customized installation
117 FM0 L MDS basic equipment variant
118 G0C I GSP 5-speed manual transmission
119 H6S L REI tires 195/65 R 15 V
120 J0R L BAT battery 380 A (80 Ah)
121 K8B I KAR notchback
122 L0L L LEA left-hand drive vehicle
123 N1H P SIB leather seat covering
124 P16 G leather-covered sports steering wheel, three spokes
125 PID G ISOFIX child's seat mounting for passenger seat
126 PKA G centre head restraint at the rear
127 PLD G Buffalino leather
128 PSH G seat heating for the front and rear seats
129 Q1A L VOS standard front seats
130 QE0 L ALG without tray areas package/box
131 QH0 L SPR without voice control
132 QQ0 L LCP without add. lights (interior lighting)
133 QV0 L TVE w/o TV reception/digital radio reception
134 SA7 E SNR inventory control model 2
135 T9J I GMO 4-cylinder diesel engine 1.9 L unit 038.K
136 U1A L INS instrument insert with km/h speedometer,clock, tachometer and trip odometer
137 V0A L REL tires w/o specification of tire brand
138 VB0 L ADR without automatic distance control
139 VC0 L GRT w/o remote-controlled garage door opener
140 VR0 L RAM without impact protection measures
141 X0A G national sales program Germany
Dzięki
wiam mam pytanie. mam fotele s-line polskora. chwieja mi sie bo sa wyrobione tulejki i moje pytanie czy bedzie pasowal szkielet z fotela soul o takich samych opcjach. czyli elektryczne ledzwie wysuwany przod i dwie raczki pod fotelem?
