prosba o analize
Wednesday,18,September,2013,18:49:08:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E72A068257 Mileage: 257450km/159972miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
VCID: 6ADFC69B3EBF
WAUZZZ8E72A068257 AUZ6Z0A0181603
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5C535A757A1
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 A
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
VCID: 1F49E74FB57D
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0102
Coding: 00001
Shop #: WSC 63351
VCID: 326F1EFBD6EF
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4E358E3EC7B
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
VCID: 366722EB3A87
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01044 - Control Module Incorrectly Coded
35-10 - - - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 49972
VCID: 285BFC93E033
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 63351
VCID: 73E1DBFF6975
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 4.11
1 Fault Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0008
Coding: 00000
Shop #: WSC 01059
VCID: E4C328A35C9B
1 Fault Found:
End ---------------------------------------------------------------------
Błędy nie są poważne, pokasuj je i zobacz które zostają.
Jak chcesz mieć obraz kondycji silnika zrób logi statyczne i dynamiczne wg. schematu.
napewno zostaje jakis od silniczka nawiewów czy regulacji strumienia nadmuchu tzntylko nie wiem o który tutaj chodzi ja nie mam na codzien dostepu do VAG ale dziekuje bardzo kolego że odpowiedziałes na moj post
