Prośba o weryfikację
Witam, kolega upatrzył B6 ale po odczytaniu błędów sie zastanawia. to jest 2003 3.0 quattro , tiptronic, po skasowaniu błędów w silniku już sie nie poajwiły, ale nie siedziałem za długo .
VCDS-Lite Version: Release 1.2
Wednesday, 18 December 2013, 11:57:46:0
Control Module Part Number: 8E0 909 559 M
Component and/or Version: 3.0L V6/5V 0010
Software Coding: 0011751
Work Shop Code: WSC 00999
VCID: 3FF1C0FF2E65
10 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 002 - Lower Limit Exceeded
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 001 - Upper Limit Exceeded - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 008 - Implausible Signal - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 008 - Implausible Signal – Intermittent
Skrzynia:
Wednesday, 18 December 2013, 11:59:05:0
Control Module Part Number: 8E0 927 156 G
Component and/or Version: AG5 01V 3.0l5V RdW 0809
Software Coding: 0000001
Work Shop Code: WSC 63251
VCID: 321799CBED37
1 Fault Found:
17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
P0741 - 003 - Mechanical Failure – Intermittent
Skanowanie:
Scan
Wednesday, 18 December 2013, 12:07:41:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 06C-909-559-ASN.LBL
Controller: 8E0 909 559 M
Component: 3.0L V6/5V 0010
Coding: 0011751
Shop #: WSC 00999
VCID: 3FF1C0FF2E65
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8E0 927 156 G
Component: AG5 01V 3.0l5V RdW 0809
Coding: 0000001
Shop #: WSC 63251
VCID: 321799CBED37
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04497
Shop #: WSC 06435
VCID: 263F759BD1FF
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
VCID: 63B92C8FE24D
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
16-10 - Signal Outside Specifications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63251
VCID: 341B9FD31723
1 Fault Found:
01495 - Bulb for High-Beams; Left (M30)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63251
VCID: 361FA5DB015F
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 01112
Shop #: WSC 63251
VCID: 3E0FBDFB296F
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 01100
Shop #: WSC 00186
VCID: 2D2D8AB7F409
WAUZZZ8E24A045438 AUZ6Z0C0207196
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBA9C4AF8A9D
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 08042
Shop #: WSC 00400
VCID: 73995CCF52AD
7 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01334 - Door Control Module; Rear Right (J398)
80-10 - Single-Wire Operation - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
VCID: 047B0F130703
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Controller: 8E0 035 195 P
Component: symphony II NP2 0152
Coding: 01201
Shop #: WSC 00400
VCID: 341B9FD31723
End --------------------------------------------------------------------------------------------------
  • 4 lata później...
Witaj, i kolega kupił ta A4 ?
