pojawiające sie kontrolki ESP i ABS
Witam po odpaleniu i przejechaniu kawałka drogi pojawiają się kontrolki ESP i ABS. Co może byc przyczyną. Poniżej podaje błędy:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01 -------------------------------------------------------
Controller: 8E0 909 552 R
Component: 2.4L V6/5V G 0010
Coding: 0011511
Shop #: WSC 63351
Nie ma błędów :) .
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04495
Shop #: WSC 06435
3 Znalezione:
00778 - Steering Angle Sensor (G85)
37-00 - Faulty
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
37-00 - Faulty
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
1 Błąd Zapis.:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63351
Nie ma błędów :) .
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00041
Shop #: WSC 63351
Nie ma błędów :) .
Address 17 -------------------------------------------------------
Controller: 8E0 920 931
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00001
Shop #: WSC 01708
WAUZZZ8E44A197303 AUZ6Z0C0242179
2 Znalezione:
01304 - Radio
49-00 - No Communications
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37 -------------------------------------------------------
Controller: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0140
3 Znalezione:
00625 - Vehicle Speed Signal
03-00 - No Signal
01317 - Control Module in Instrument Cluster (J285)
00867 - Connection to ABS Control Module
03-00 - No Signal
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AS
Component: Komfortgerát T01 1210
Coding: 06720
Shop #: WSC 63351
3 Znalezione:
00955 - Key 1
35-10 - - - Intermittent
00936 - Electric Window Switch in Front Passenger Door (E107).
27-10 - Implausible Signal - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 22209
1 Błąd Zapis.:
End -------------------------------------------------------
