zonee Opublikowano 27 Lipca 2016 Opublikowano 27 Lipca 2016 Witam. Zrobiłem Auto-scan VCDS Lite 1.2 swojego Passata B5. Przeskanował tylko to co widać i takie tego rezultaty - czy ktoś za wyjątkiem odczytania kodów błędów wie o co chodzi ? Przedewszystkim z AIRBAGS i Central Conv. I czy tylko tyle powinien przeskanować ? Z góry dzięki za pomoc. VCDS-Lite Version: Release 1.2Saturday, 23 July 2016, 12:52:35:0Chassis Type: 3B - VW Passat B5Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Controller: 038 906 018 N Component: 1,9l R4 EDC G00SG 1631 Coding: 00002 Shop #: WSC 00028 VCID: 21356687B8D1No fault code found.Readiness: N/A-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Coding: 0273004281 Shop #: BB 24548 VCID: 5ECF1D7BC92FNo fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 1J0-909-60x-VW3.LBL Controller: 1J0 909 604 A Component: AIRBAG VW3 - V04 Coding: 00065 Shop #: WSC 00028 VCID: 28237BA3DBEB1 Fault Found:00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent-------------------------------------------------------------------------------Address 17: Instruments Labels: 3B0-919-xxx-17.LBL Controller: 3B1 919 860 C Component: B5-KOMBIINSTR. VDO V01 Coding: 04140 Shop #: WSC 00000 VCID: 2A2781ABC5E7 IMMO-IDENTNR: VWZ7Z0W0760512 No fault code found.-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 1J0-959-799.LBL Controller: 1J0 959 799 R Component: 3A Zentral-SG Komf. 0001 Coding: 00257 Shop #: WSC 00028 VCID: 4DEDEA3794C93 Faults Found:00928 - Locking Module for Central Locking; Front Driver Side (F220) 27-00 - Implausible Signal00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - -00944 - Heated Exterior Mirror; Passenger Side (Z5) 35-00 - -End -------------------------------------------------------------------------------------------------- Widzę mały ruch tu wiec tak Błąd poduszki skasowany nie wraca, podgrzewacze lusterek zamówione, jedynie centralny zamek do rozebrania - błąd wraca - ale nie mam pojęcia co z nim nie tak !
ciahciah Opublikowano 29 Lipca 2016 Opublikowano 29 Lipca 2016 a czy centralny zamek nie działa że chcesz go rozbierać? bo sam bład to nie powód do rozbierania
