Pomoc w odczycie błędów
Dzisiejszy pomiar.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 08     -------------------------------------------------------
   Controller: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
2 Znalezione:
00710 - Defroster Flap Positioning Motor (V107)
            41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
            30-10 - Open or Short to B+ - Intermittent
Skipping Address 15-Airbags
01:
Address 45     -------------------------------------------------------
   Controller: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   Shop #: WSC 21895
Nie ma błędów :)   .
VAG-COM Version: Release  311.2-N
Control Module Part Number: 8E0 909 518 AA
  Component and/or Version: 1.8L R4/5VT     G   0004
           Software Coding: 0011581
            Work Shop Code: WSC 63351
7 Znalezione:
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
        P0139 - 001 - Upper Limit Exceeded
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
        P1103 - 008 - Implausible Signal - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
        P1479 - 008 - Implausible Signal - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
        P1128 - 001 - Upper Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
        P1602 - 002 - Lower Limit Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
        P0130 - 008 - Implausible Signal
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
        P0140 - 004 - No Signal/Communication
End   -------------------------------------------------------
08:
Control Module Part Number: 8E0 820 043 L
  Component and/or Version:   A4 Klimaautomat   1116
           Software Coding: 00000
3 Znalezione:
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
        30-00 - Open or Short to B+
Nie wiem czy dobrze to wykonałem, na poczatku zrobiłem autoscan. Poźniej wszedłem w silnik i doczytałem błędy(ale na wyłączonym zapłonie i nie wiem czy odczyt jest wiarygodny)
Dzieki za pomoc i pozdrawiam
Wysłane z mojego LG-H815 przy użyciu Tapatalka
