Ocena skanu Vagiem 409.1
Witam. Mam tutaj skan ze swojego autka. Pomoże ktoś rozszyfrowac błędy? :)
Address 01: Engine Controller: 8E0 ABT 518 M Component: 1.8L R4/5VT G A002 Coding: 0011501 Shop #: WSC 63351 No fault code found. Readiness: 0110 1101
-------------------------------------------------------------------------------Address 03: ABS Brakes Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04275 Shop #: WSC 00070 No fault code found.
-------------------------------------------------------------------------------Address 08: Auto HVAC Controller: 8E0 820 043 A Component: A4 Klimaautomat 1012 Coding: 00000 Shop #: WSC 63351 3 Faults Found: 01810 - Actuating Motor for Temperature Flap: Right (V159) 41-10 - Blocked or No Voltage - Intermittent 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 09-00 - Adaptation Limit Surpassed 00819 - High Pressure Sensor (G65) 30-00 - Open or Short to B+
-------------------------------------------------------------------------------Address 09: Cent. Elect. Controller: 8E0 907 279 D Component: int. Lastmodul RDW 0203 Coding: 00011 Shop #: WSC 63351 No fault code found.
-------------------------------------------------------------------------------Skipping Address 15-Airbags
C:\Users\Kamil\AppData\LocalLow\Temp\Mic
Address 16: Steering wheel Controller: 8E0 953 549 P Component: Lenksáulenmodul 0711 Coding: 01042 Shop #: WSC 47708 No fault code found.
VAG-COM Self-Diagnosis Log Friday, 17 March 2017, 15:11:08 Page 2
VIN Number: WAUZZZ8EX2A279887 License Plate:
-------------------------------------------------------------------------------Address 17: Instruments Controller: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00000 Shop #: WSC 36209 WAUZZZ8EX2A279887 AUZ6Z0B0049044 No fault code found.
-------------------------------------------------------------------------------Address 46: Central Conv. Controller: 8E0 959 433 AE Component: Komfortgerát T01 0316 Coding: 06752 Shop #: WSC 63351 6 Faults Found: 01801 - Door Warning Lamp: Drivers Side (W30) 57-10 - Electric Circuit Failure - Intermittent 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent 01331 - Door Control Module: Driver Side (J386) 52-10 - Supply Voltage Too High - Intermittent 01559 - Drivers Door 61-10 - Won't De-Safe - Intermittent 00932 - Electric Window Motor: Drivers Side (V147) 62-10 - No or Incorrect Adjustment - Intermittent 01561 - Left Rear Door 61-00 - Won't De-Safe
-------------------------------------------------------------------------------Address 55: Xenon Range Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 No fault code found.
-------------------------------------------------------------------------------Address 56: Radio Controller: 8E0 035 186 Component: concert II GRO 0008 Coding: 00001 Shop #: WSC 63351 No fault code found.
VAG-COM Self-Diagnosis Log Friday, 17 March 2017, 15:11:09 Page 3
End -------------------------------------------
                                                     Address 46 -moduł komfortu
01801 - Światło ostrzegawcze drzwi; strona kierowcy (W30)   Usterka w obwodzie elektrycznym
01705  -   Przełącznik wyboru przestawianego lusterka (E48).   Niezrozumiały sygnał
01331 -   Komputer sterujący drzwiami po stronie kierowcy (J386).   Uszkodzony. Brak sygnału. Brak komunikacji
01559 -   Drzwi kierowcy.   Nie zabezpiecza. Nie odbezpiecza. Usterka w obwodzie elektrycznym
01561 -   Drzwi tylne lewe.   Nie odbezpiecza. Nie zabezpiecza. Nie odryglowuje
Do sprawdzenia przewody w gumowej przelotce między drzwiami a karoserią w po stronie kierowcy i tylnych lewych.Po naprawie przeskanuj jeszcze raz i zobacz czy coś powróciło
Dzięki wielkie!
