Błedy 1.8T AVJ
Witam
Moze mi ktos powiedziec co ta bledy ??
Cytuj
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 AQ    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0010
   Coding: 0011711
   Shop #: WSC 87119 806 641192
   VCID: 7F15158FB7FD89CA669AAD1-515E
1 Fault Found:
18010 - Power Supply Terminal 30
            P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0004871
   Shop #: WSC 06335 000 00000
   VCID: 2941EBD719F9D74A68FE139-807C
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 34
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x0198
                    Hex Value: 0x0001
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   Shop #: WSC 00000
   VCID: 6BCDD1DFD385006ADA52491-5140
No fault code found.
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 01001
   Shop #: WSC 65536
   VCID: 3B6D219FE36550EA0A32591-4B00
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M007THVT
   Coding: 0033622
   VCID: 3B6D219FE36555DA0A32591-806E
   Subsystem 1 - Serial number: 6332DRB402195193D
   Subsystem 2 - Serial number: 6342DRB4021DD0B0O
   Subsystem 3 - Serial number: 6352ARB4009603FBQ
   Subsystem 4 - Serial number: 6362ARB40095FF4D1
   Subsystem 5 - Serial number: 63729RB400AF26ED0
   Subsystem 6 - Serial number: 63829RB400AF2755S
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Time Indication: 0
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 03041
   Shop #: WSC 06335
   VCID: 4191537781893A3A50EE1B9-4B1A
2 Faults Found:
01303 - Telephone Transceiver (R36)
            49-00 - No Communications
01304 - Radio
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
   Component: KOMBI+WFS 4     H14 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0023041
   Shop #: WSC 12345 345 34567
   VCID: 3D692F87FD715BDA3406779-5140
3 Faults Found:
01304 - Radio
            004 - No Signal/Communication
01300 - Control Module for Navigation with CD-Rom (J401)
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0023041
3 Faults Found:
01304 - Radio
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BQ
   Component: Komfortgerát T01    3332
   Coding: 06752
   Shop #: WSC 02391
   VCID: 01119377C109FA3A106EDB9-4B1A
   Subsystem 1 - Part No: 8E1959801H
   Component: Tőrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802B
   Component: Tőrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801E
   Component: Tőrsteuer.HL BRM 0506
   Subsystem 4 - Part No: 8E0959802E
   Component: Tőrsteuer.HR BRM 0506
1 Fault Found:
00955 - Key 1
            35-10 -  -  - Intermittent
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020526
   Coding: 0000104
   VCID: 317103B73129AFBAA08ECB9-5140
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 6
                    Time Indication: 0
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 187
                    Reset counter: 170
                    Time Indication: 0
