Joel52 0 Opublikowano 6 Sierpnia 2017 Udostępnij Opublikowano 6 Sierpnia 2017 Cześć, wymieniałem gatewaya i pozostały mi takie błędy - moge prosić o pomoc w diagnozowaniu ich i usunięciu? Mileage: 192990km-119918miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CDHA) Labels: 06H-907-115-CAB.clb Part No SW: 8K1 907 115 C HW: 8K1 907 115 Component: 1.8l R4/4V TF H10 0003 Revision: A5H10--- Coding: 0104000C18070058 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM18TFS8K1907115C A01004 ROD: EV_ECM18TFS_AU48.rod VCID: 2E5364DE71D66F3202-807A 1 Fault Found: 2886 - Catalyst System; Bank 1 P0420 00 [096] - Efficiency Below Threshold Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT Component: ESP8 front H04 0010 Revision: -------- Serial number: -------------- Coding: 010D00 Shop #: WSC 06325 000 00000 VCID: 0C17CE56AF8A7D22CC-8058 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 BC HW: 8K0 907 064 C Component: BCM2 1.1 H80 0249 Revision: 00002001 Coding: 030100 Shop #: WSC 06325 000 00000 VCID: 72EBB0AEAD6E0BD2A6-8026 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000048933001 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0209000064844009 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM Component: KLIMA 1 ZONE H08 0171 Revision: A0000000 Serial number: 01090920090237 Coding: 64000000 Shop #: WSC 06325 000 00000 VCID: 7CF79E96FF2A4DA2FC-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 K HW: 8K0 907 063 K Component: BCM1 1.0 H25 0380 Revision: 06025001 Serial number: 00000000344186 Coding: 690000B1013400010001000000005F5F001C020800000001000000 Shop #: WSC 06325 123 12345 VCID: 377D41BA868CAEFA51-8062 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 140909 H06 0070 Serial number: SWF09090145683 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK Component: E1 - LDS H08 0090 Serial number: 00000000000809091653 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD05HD93 Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 41892F62D048E04AEF-8014 Crash sensor for side airbag: driver side: Serial number: 6334MSME4A12197EL Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4B412C67L Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME483A2714G Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME6C3A4012G Crash sensor for front airbag: driver side: Serial number: 63732SME54371F26% Crash sensor for front airbag: front passenger side: Serial number: 63832SME32382B36 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 D HW: 8K0 953 568 D Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90319IHK00013 Coding: 000002 Shop #: WSC 06325 000 00000 VCID: 3B755D8ABAA48A9AB5-806E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 B HW: 8K0 920 900 B Component: KOMBIINSTR. H20 0255 Revision: 00000000 Serial number: CIJ25T799 Coding: 0F05080003000008010000 Shop #: WSC 06325 123 12345 VCID: 295997C24038080AD7-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 S HW: 8T0 907 468 J Component: GW-BEM 6CAN H06 0105 Revision: HB600050 Serial number: 5000H09B058044 Coding: 00C300 Shop #: WSC 06335 123 12345 VCID: 51A91F22082810CA7F-8004 3 Faults Found: 03041 - Energy Management Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 121 Mileage: 192996 km Time Indication: 0 Date: 2017.08.06 Time: 12:46:24 Freeze Frame: Bin. Bits: 10111 Voltage: 11.60 V Count: 6 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 161 Mileage: 192996 km Time Indication: 0 Date: 2017.08.06 Time: 12:46:25 Freeze Frame: Bin. Bits: 10111 Voltage: 11.60 V Count: 6 Bin. Bits: 10000 Time: 25.40 s 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 121 Mileage: 192996 km Time Indication: 0 Date: 2017.08.06 Time: 12:46:25 Freeze Frame: Bin. Bits: 10111 Voltage: 11.60 V Count: 6 Bin. Bits: 10000 Time: 25.40 s ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 J HW: 8K0 959 793 E Component: TSG FA H11 0306 Revision: Serial number: 0000101863547 Coding: 011002204000410001 Shop #: WSC 06325 123 12345 VCID: 479D317AF66CDE7A21-8012 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 BC HW: 8K0 907 064 C Component: BCM2 1.1 H80 0249 Revision: 00002001 Serial number: 0117605705 Coding: 011E0620003900400330010000000000 Shop #: WSC 06325 123 12345 VCID: 72EBB0AEAD6E0BD2A6-8026 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 J HW: 8K0 959 792 E Component: TSG BF H11 0306 Revision: Serial number: 0000101857830 Coding: 001002204C00410001 Shop #: WSC 06325 123 12345 VCID: 46833C7EF166C772DA-8012 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 191007 km Time Indication: 0 Date: 2017.06.24 Time: 20:46:09 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000445733 Shop #: WSC 00000 000 00000 VCID: 346776B697FA45E274-8060 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 P HW: 8T1 035 186 P Component: Concert3 H05 0310 Revision: 00000008 Serial number: AUZ5Z6I1308714 Coding: 000204000101000D0179070003 Shop #: WSC 06335 123 12345 VCID: 44872676C75AF562C4-8010 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display 1 Fault Found: 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 121 Mileage: 192996 km Time Indication: 0 Date: 2017.08.06 Time: 12:51:39 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000101835656 Coding: 010002204000210001 Shop #: WSC 06325 000 00000 VCID: 428B206EDD4EFB52F6-8016 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000101834133 Coding: 010002204000210001 Shop #: WSC 06325 000 00000 VCID: 428B206EDD4EFB52F6-8016 No fault code found. End-------------------------(Elapsed Time: 02:42)-------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 6 Sierpnia 2017 Udostępnij Opublikowano 6 Sierpnia 2017 W LIŚCIE INSTALACYJNEJ TRZEBA WYKODOWAC 01771 - Control Module for Headlight Range (J431) 01327 - Control Module for Parking Aid (J446) Czyli adres 55 xenon oraz 10 PDC Dodatkowo masz słaby AKU Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Joel52 0 Opublikowano 6 Sierpnia 2017 Autor Udostępnij Opublikowano 6 Sierpnia 2017 Ale gdzie mam znaleść listę instalacyjną? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 6 Sierpnia 2017 Udostępnij Opublikowano 6 Sierpnia 2017 2 godziny temu, Joel52 napisał: Ale gdzie mam znaleść listę instalacyjną? w sterowniku gateway 19 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
