Prośba o analizę logów - A4 B6
Hej,
Wysypało mi parę błędów.
Jestem po zalaniu i naprawie modułu komfortu.
Od jakiegoś czasu radio słabo łapie fale.
Prośba o analizę:
VCDS-Lite Version: Release 1.2
Wednesday, 20 September 2017, 19:01:26:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: 038-906-019-AJM.LBL
   Controller: 038 906 019 JT
   Component: 1,9l R4 EDC 0000SG  1572
   Coding: 00002
   Shop #: WSC 63351
   VCID: 729759CB2DB7
   WAUZZZ8EX3A284167     AUZ6Z0B0454745
No fault code found.
Readiness: N/A
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       1729
   Coding: 04255
   Shop #: WSC 06435
   VCID: E5BDB2976C79
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 J
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 28237BA3DBEB
7 Faults Found:
01272 -  Positioning Motor for Central Flap (V70)
            41-10 -  Blocked or No Voltage - Intermittent
01810 -  Actuating Motor for Temperature Flap; Right (V159)
01842 -  Potentiometer/Actuator for Temperature Flap; Right (G221)
            30-10 -  Open or Short to Plus - Intermittent
            09-00 -  Adaptation Limit Surpassed
00716 -  Air recirculation Flap Positioning Motor (V113)
00735 -  Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00101
   Shop #: WSC 63351
   VCID: 341B9FD31723
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0010702
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00012
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 K
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00000
   Shop #: WSC 11111
   VCID: 2C2B87B3CF13
Address 46: Central Conv.       Labels: 8E0-959-433-MIN.LBL
   Controller: 8E0 959 433 BA
   Component: Komfortgerát TA7    1310
   Coding: 06976
   Shop #: WSC 63351
   VCID: 719556C728B1
8 Faults Found:
01699 -  Motor for Central Locking; Hatch/Trunk (V53)
            29-10 -  Short to Ground - Intermittent
01561 -  Left Rear Door
            61-10 -  Won't De-Safe - Intermittent
01562 -  Right Rear Door
            59-10 -  Can't Unlock - Intermittent
01366 -  Opened Due to Crash Signal
            36-10 -  Open Circuit - Intermittent
01702 -  Footwell Lighting; Left (W9)
            28-10 -  Short to Plus - Intermittent
01703 -  Footwell Lighting; Right (W10)
01696 -  Footwell Lighting; Rear Left (W45)
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 152
   Component: chorus II   GRO    0008
   Coding: 01202
   Shop #: WSC 63351
   VCID: DDCD9A774429
1 Fault Found:
00856 -  Radio Antenna
            36-00 -  Open Circuit
End   --------------------------------------------------------------------------------------------------
Kasowałeś błędy ? Wszystkie wróciły ?
Jeśli chodzi o radio to pokazuje ze masz przerwany obwód - więc kabel gdzieś nie domaga i jest lipa z zasięgiem.
Na klimatroniku wszystkie potencjometry klap do czyszczenia.
Błąd z radiem wraca. Dziś po wymianie modułu komfortu i zrobieniu ustawień podstawowych klimy błędy wyglądają tak jak poniżej.
Jak widać doszły nowe :/
   Coding: 00000
   Shop #: WSC 63351
   VCID: 28237BA3DBEB
3 Faults Found:
            41-00 -  Blocked or No Voltage
   Coding: 00012
   Shop #: WSC 63351
   VCID: 361FA5DB015F
1 Fault Found:
01330 -  Central Control Module for Central Convenience (J393)
            49-10 -  No Communications - Intermittent
   Controller: 8E0 959 433 BD
   Component: Komfortgerát TBF    1511
   Coding: 06890
   Shop #: WSC 63351
   VCID: 749B5FD357A3
3 Faults Found:
01134 -  Alarm Horn (H12)
            49-00 -  No Communications
            61-00 -  Won't De-Safe
   Coding: 01202
   Shop #: WSC 63351
   VCID: DDCD9A774429
1 Fault Found:
Klimatyzacja -> Jak wcześniej - flapy do czyszczenia i 1 do sprawdzenia (V113)
Moduł komfortu -> Jak nie masz alarmu to zmień kodowanie, jak masz to sprawdź syrenę - pozostałe to błędy mikrostyków albo kabli między słupkiem a drzwiami
Radio -> Tak jak pisalem, przerwany obwod do anteny - dlatego problemy z radiem
