Skan auta (analiza)
Prośba o analizę logów
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 20 42 46 52 53 55 56 5F
          62 72
Mileage: 200960km-124870miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (MA---CDNB)       Labels:. 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 Q    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0004
   Revision: E1H14---
   Coding: 010C000C02070160
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM20TFSK82907115Q A01006
   ROD: N/A
   VCID: 3D76E2B6ACEAEEAEA1-8068
No ASAM data for: "EV_ECM20TFSK82907115Q" (AU48)
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AA    HW: 0AW 927 156 H
   Component: 0AW 20TFSIRdW H02 0006
   Revision: --H02---    Serial number: 0000001295
   Coding: 000002
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: 72EC018AA53461D68C-8026
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AM    HW: 8K0 907 379 AM
   Component: ESP8 front    H04 0100
   Revision: --------    Serial number: --------------
   Coding: 260D08
   VCID: 0400575287805F66AE-8050
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0321
   Revision: 00002001
   Coding: 010200
   VCID: 010E5E4698924A4E85-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Serial number: 0509000024302014
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000029880003
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0160
   Revision: A1000000    Serial number: 01190520091486
   Coding: 64100000
   VCID: 7DF622B6E46A2EAEE1-8028
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0372
   Revision: 10025001    Serial number: 00000000267440
   Coding: 260050914074AF010001000300001D0D0F1C470800010101000000
   Shop #: WSC 06335 123 12345
   VCID: 3C70EFB2BFF0E7A696-8068
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160509  H06 0070
   Serial number: SWF09050166244
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10476543
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001205092289
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H48 0050
   Revision: 00000014
   VCID: 214E3EC63852AA4EA5-8074
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840913501940
   Coding: 100103
   VCID: 40889B42D3188346CA-8014
Address 15: Airbags (J234)       Labels:. 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD02NTMZ
   Coding: 30343435363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaEUCVWAUDI010 003010
   ROD: N/A
   VCID: 418E9E46D0128A4EC5-8014
   Subsystem 1 - Serial number: 6334MSME476619309
   Subsystem 2 - Serial number: 6344MSME480032764
   Subsystem 3 - Serial number: 6352QSME6528370CK
   Subsystem 4 - Serial number: 6362QSME37293830D
   Subsystem 5 - Serial number: 63732SME1F201628Y
   Subsystem 6 - Serial number: 63832SME22201802H
No ASAM data for: "EV_AirbaEUCVWAUDI010" (AU48)
1 Fault Found
9437979 - ROD - Unknown Error Code
          - 00 [137]
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 200807 km
                    Date: 2017.12.31
                    Time: 12:01:10
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90304IEC000HQ
   Coding: 000017
   VCID: 3D76E2B6A4EAEEAEA1-8068
   Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 B    HW: 8K0 920 930 B
   Component: KOMBIINSTR.   H19 0252
   Revision: 00000000    Serial number: AUM72AF59
   Coding: 0F06100003000008000000
   VCID: 2C50DFF24F90772606-8078
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0101
   Revision: FB800054    Serial number: 5400F09502802E
   Coding: 00C303
   VCID: 00085B42939843468A-8054
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 19078FF7240409
3 Faults Found
03041 - Energy Management Active
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 13
                    Reset counter: 242
                    Mileage: 200438 km
                    Time Indication: 0
                    Date: 2017.12.21
                    Time: 10:50:42
             Freeze Frame:
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 10
03395 - Control Module for High Beam Assistant
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 241
                    Mileage: 200766 km
                    Time Indication: 0
                    Date: 2017.12.28
                    Time: 10:03:46
             Freeze Frame:
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
02001 - Data-Bus Automatic Distance Regulation
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 241
                    Mileage: 200766 km
                    Time Indication: 0
                    Date: 2017.12.28
                    Time: 10:03:47
             Freeze Frame:
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10011
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 8K0 857 511 D    HW: 8K0 857 511
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019164747464545425363E
   VCID: 326CC18A6DB421D64C-8066
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000008873045
   Coding: 011C02205000410001
   VCID: 45868A56CC3AA66EF9-8010
1 Fault Found
02115 - Locking Unit for Central Locking
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 242
                    Mileage: 200609 km
                    Time Indication: 0
                    Date: 2017.12.25
                    Time: 21:41:21
Address 46: Central Conv. (J393)       Labels: Redir Fail!
   Revision: 00002001    Serial number: 0118692382
   Coding: 01000620203900800130020000000000
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000008860246
   VCID: 44809752C7009F66EE-8010
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000368831
   Shop #: WSC 00000 000 00000
   VCID: 3460C79297A02FE65E-8060
Address 55: Headlight Range        Labels: 8K0-907-357.clb
   Part No: 8K5 907 357
   Component: Dynamische LWR  H01 0010
   Revision: 00000001    Serial number:
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77FA309E065604FEBB-8022
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341EX097573590
   Coding: 010003020000000001
   VCID: 25462AD62C7A466ED9-8070
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 652 K    HW: 8T1 035 652 D
   Component: B-BN-EU       H52 0185
   Revision: --------    Serial number: 323EI097508001
   Coding: 010100010006A1ED01000B0E000000030001
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355KJ081011207
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000286636
2 Faults Found
03276 - Please Check Software Version Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 202
                    Mileage: 200807 km
                    Time Indication: 0
                    Date: 2017.12.31
                    Time: 12:11:32
             Freeze Frame:
                    Voltage: 11.50 V
03175 - Invalid Data Set
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 202
                    Mileage: 200807 km
                    Time Indication: 0
                    Date: 2017.12.31
                    Time: 12:11:29
             Freeze Frame:
                    Voltage: 11.50 V
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101121244
   Coding: 010C02204000210001
   VCID: 428C914ADD149156DC-8016
1 Fault Found
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 203
                    Mileage: 200823 km
                    Time Indication: 0
                    Date: 2018.01.04
                    Time: 13:58:07
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101122498
End-------------------------(Elapsed Time: 02:53)--------------------------
Edytowane przez artrem
co cie niepokoi ?   kasowane błedy były ?
Witam. Tak byly kasowane.Auto bylo po delikatnej stluczce ale w kabinie prawie wszystkie poduchy wystrzelily. Poduszka pasazera rozwalila dodatkowo szybe przednia i po wymianie nie dziala sensor deszczu.
Komunikacja z nim jest  mozliwe ze gelu pod nim nie ma
Cytuj
   Coding: 025028
OK po wymianie sensora deszczu na inny zaczęło to działać poprawnie. Pytanie co z innymi błędami które mi tu wypisuje. Jeden na pewno jest związany z tylnymi drzwiami za kierowcą bo nie zawsze idzie je otworzyć od zewnątrz. Dziwią mnie błędy związane z funkcją High Beam Assist bo działa poprawnie.
