elvis1 Opublikowano 10 Lutego 2018 Opublikowano 10 Lutego 2018 Czy ktoś może mi pomóc w dodaniu modułu haka w komputerze? Mam program VAG 4,9 ale za nic nie moge tam znaleźć jak dodać hak holowniczy.
salamon Opublikowano 10 Lutego 2018 Opublikowano 10 Lutego 2018 (edytowane) Kodowanie MCE 09 dla A4 B7 Coding 07 ?xxxx: Chassis 0 = Limousine (PR-K8B) 1 = Avant (PR-K8D) 2 = Cabriolet (PR-K8K) x?xxx: Driving Light Switch 0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4) 1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9) xx?xx: Trailer Hitch 0 = Trailer Hitch not installed (PR-1D0) 1 = Trailer Hitch installed (PR-1D2) xxx?x: Headlights 0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7) 1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7) 2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4) 3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7) 4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3) xxxx?: Country 1 = Rest of World/Nordic Countries/Denmark/Croatia/Baltic Countries with Bi-Xenon 2 = Nordic Countries/Denmark/Croatia/Baltic Countries without Bi-Xenon 3 = USA/Canada with Bi-Xenon 4 = Canada without Bi-Xenon 5 = Special Vehicles Jeśli posiadasz PDC to jeszcze PDC 76 dla sterownika 4 kanałowego : Coding ?xxxx: Trailer Hitch 0 = Not Installed 1 = Installed x?xxx: Transmission 0 = Manual Transmission 1 = Automatic Transmission xx?xx: Confirmation Sound 0 = No 1 = Yes xxx?x: Chassis 0 = Limousine (Sedan) Rest of World 1 = Avant (Wagon) Rest of World 2 = Limousine (Sedan) North America 3 = Avant (Wagon) North America 4 = S-Variant Limousine (Sedan) Rest of World 5 = S-Variant Avant (Wagon) Rest of World 6 = S-Variant Limousine (Sedan) North America 7 = S-Variant Avant (Wagon) North America 8 = allroad xxxx?: Model 2 = Audi A2 (8Z) 4 = Audi A4 (8E) 5 = Audi A4 Cabrio (8H) 6 = Audi A6 (4B) PDC 76 dla sterownika 8 kanałowego : Coding 07 ?xxxx: Trailer Hitch 0 = Not Installed 1 = Installed x?xxx: Transmission 0 = Manual Transmission 1 = Automatic Transmission xx?xx: Confirmation Sound 0 = No 1 = Yes xxx?x: Chassis 0 = Limousine (Sedan) Rest of World 1 = Avant (Wagon) Rest of World 2 = Limousine (Sedan) North America 3 = Avant (Wagon) North America 4 = S-Variant Limousine (Sedan) Rest of World 5 = S-Variant Avant (Wagon) Rest of World 6 = S-Variant Limousine (Sedan) North America 7 = S-Variant Avant (Wagon) North America 8 = allroad xxxx?: Model 4 = Audi A4 (8E) 5 = Audi A4 Cabrio (8H) 6 = Audi A6 (4B) Edytowane 10 Lutego 2018 przez salamon
jarcoj Opublikowano 10 Lutego 2018 Opublikowano 10 Lutego 2018 (edytowane) musisz dodać kodowanie do kilku modułów The following Activations are necessary to ensure that the newly fitted parts are properly recognized and are ready to use. Update the Installation List in the Instrument Cluster (J285 / #17). Using the Adaptation Function, select Channel 061 (Installation List: CAN-Databus Comfort). Now add the Value 64 to your existing Value (i.e. 3331+64=3395) Further Information will be displayed once you access the Adaptation Channel. Update the Engine Control Module (J623 / #01) Coding. Make sure that the Engine is NOT running, otherwise the new Coding will be rejected. Models equipped with Start/Stop System do have a Shutoff Switch/Button which will deactivate the Start/Stop Function. For Engines with a 2nd Engine Control Module (J624 / #11) this needs to be coded as well. As a Rule of Thumb, If the Engine uses conventional Short Coding (Coding is 7-digits like 0011312) the Long Codding Assistant does NOT apply. Modules using Short Coding typically do NOT support or require Trailer Configuration Coding. If the Engine Control Module uses a Long Coding the Activation is done in (Long) Coding itself through via Coding Assist. Please also note that there are different Coding Variants for Long Coding. Due to different Control Modules and Equipment in the Car the actual Coding Table is not shown here but will automatically be used by the Long Coding Assistant once you access the Function using VCDS. Update the Central Electronics (J519 / #09) Coding, if installed. Due to different Control Modules and Equipment in the Car the actual Coding Table is not shown here but will automatically be shown once you access the Function using VCDS. Update the Parking Aid (J446 / #76) Coding, if installed Due to different Control Modules and Equipment in the Car the actual Coding Table is not shown here but will automatically be shown once you access the Function using VCDS. to kodowania z vcds ale analogicznie musisz wprowadzić kodowania w VAG Jeśli masz dostęp do internetu przy aucie to mogę pomóc. Edytowane 10 Lutego 2018 przez jarcoj
elvis1 Opublikowano 10 Lutego 2018 Autor Opublikowano 10 Lutego 2018 Jarcoj...super by było. Mam dostęp do neta.
jarcoj Opublikowano 11 Lutego 2018 Opublikowano 11 Lutego 2018 Dzwon na skypa: jarcoj lub pisz na whatsupp 503565643 i będziemy walczyć
elvis1 Opublikowano 13 Lutego 2018 Autor Opublikowano 13 Lutego 2018 W dniu 11.02.2018 o 14:03, jarcoj napisał: Dzwon na skypa: jarcoj lub pisz na whatsupp 503565643 i będziemy walczyć Czekam na nowy kabel, bo ten co mam obsługuje tylko vcds lite. Jak przyjdzie to bede dzwonił:)
