Piotr Czarnojan Opublikowano 18 Lutego 2018 Opublikowano 18 Lutego 2018 Witam koledzy mam problem wymieniałem wiatrak nawiewu bo miał juz dosc i od tego momentu nie działa mi webasto i mam takie błedy błedy udalo sie wykasowac a webasto dalej nie działa Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01131120101699 Coding: 34180000 Shop #: WSC 06335 000 00000 VCID: 800FE68B13F6581E143-80D5 1 Fault Found: 01231 - Right Footwell Vent Temperature Sensor (G262) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 137 Mileage: 204329 km Time Indication: 0 Date: 2018.02.07 Time: 18:59:04 Freeze Frame: Temperature: 4.0°C Speed: 0.0 km/h Voltage: 12.00 V Address 08: Auto HVAC Labels: Redir Fail! Control Module Part Number: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component and/or Version: KLIMA 3 ZONEN H08 0180 Software Coding: 34180000 Work Shop Code: WSC 06335 000 00000 VCID: 800FE68B13F6581E143-80D5 1 Fault Found: 01231 - Right Footwell Vent Temperature Sensor (G262) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 137 Mileage: 204329 km Time Indication: 0 Date: 2018.02.07 Time: 18:59:04 Freeze Frame: Temperature: 4.0°C Speed: 0.0 km/h Voltage: 12.00 V Address 18: Aux. Heat Labels: Redir Fail! Control Module Part Number: 4H0 265 105 A HW: 4H0 265 105 A Component and/or Version: Standheizung H22 0240 Software Coding: 5D2000 Work Shop Code: WSC 06335 000 00000 VCID: 204F060B3336381EB43-8075 1 Fault Found: 01414 - Combustion-Air Blower (V6) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 53 Mileage: 203287 km Time Indication: 0 Date: 2018.01.23 Time: 04:10:12 Freeze Frame: Temperature: -1.0°C Temperature: 2.0°C Voltage: 10.40 V Start Error Code: 21 Temperature: -1.0°C RPM: 0 /min No
wrclaguna Opublikowano 18 Lutego 2018 Opublikowano 18 Lutego 2018 01414 dmuchawa powietrza spalania , zwarcie z potencjałem plus , zwarcie z masą , zablokowana lub brak napięcia , zbyt duża różnica liczby obrotów - Przy usterce ogrzewanie postojowe nie uruchomi się. Ogrzewanie postojowe może zostać ponownie uruchomione dopiero wówczas, gdy nie będzie już usterki. - usterka w przewodzie łączącym biegnącym od komputera sterującego ogrzewania dodatkowego do dmuchawy powietrza spalania - uszkodzona dmuchawa powietrza spalania
