seba_gniezno Opublikowano 29 Sierpnia 2018 Opublikowano 29 Sierpnia 2018 Wednesday,29,August,2018,20:45:44:00001 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.1.0 Data version: 20171130 DS276.6 www.Ross-Tech.com VIN: WAUZZZ8K49A130780 License Plate: Chassis Type: 8K-AU48 (8T0) Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 VIN: WAUZZZ8K49A130780 Mileage: 217900km-135396miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGC) Labels:| 03L-906-022-CAG.clb Part No SW: 03L 906 022 HW: 03L 906 022 B Component: R4 2,0L EDC H01 3177 Revision: 11H01--- Coding: 0104002C18072018 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TDI03L906022 A01005 ROD: EV_ECM20TDI03L906022.rod VCID: 62CA9214754FB056E7-8036 1 Fault Found: 4984 - Cylinder 1 Glow Plug Circuit (Q10) P0671 00 [109] - Electrical Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 217851 km Date: 2018.08.22 Time: 08:56:24 Engine speed: 896.00 /min Normed load value: 54.5 % Vehicle speed: 0 km/h Coolant temperature: 15 °C Intake air temperature: 14 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 11.880 V Unlearning counter according OBD: 40 Crankshaft speed (RPM): 896.0 /min Vehicle speed: 0.00 km/h Vehicle voltage terminal 30: 11960 mV Coolant temperature: 15.0 °C Glow status-Bit 0: 00000000 Glow status-Bit 8: 00000000 Preheat time: 1000 ms Fuel temperature: 14.0 °C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA Component: ESP8 front H04 0060 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 06325 000 00000 VCID: 78FED07CCBD34A86A9-802C 1 Fault Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 66 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:48:47 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x00A2 Hex Value: 0x0013 Hex Value: 0x0296 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H80 0141 Revision: 00002001 Coding: 031100 Shop #: WSC 06325 000 00000 VCID: 306E285C632352C621-8064 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Serial number: 0508000049969001 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0208000048006011 2 Faults Found: 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 14 Reset counter: 66 Mileage: 216496 km Time Indication: 0 Date: 2018.08.09 Time: 08:13:35 01328 - Convenience System Data Bus 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 5 Reset counter: 66 Mileage: 217830 km Time Indication: 0 Date: 2018.08.19 Time: 16:57:44 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 8T2 820 043 Q HW: 8T2 820 043 Q Component: KLIMA 1 ZONE H06 0140 Revision: B0000000 Serial number: 0130.08.081503 Coding: 34040000 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 2 Faults Found: 00256 - A/C Pressure/Temperature Sensor (G395) 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 220 Mileage: 214233 km Time Indication: 0 Date: 2018.07.25 Time: 17:56:31 Freeze Frame: Temperature: 43.0°C Temperature: 81.0°C Load: 0.0 % Absolute Pres.: 1.0 bar RPM: 840 /min Speed: 0.0 km/h Current: 0.000 A Temperature: 46.0°C 01328 - Convenience System Data Bus 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 236 Mileage: 214956 km Time Indication: 0 Date: 2018.08.01 Time: 16:57:12 Freeze Frame: Temperature: 18.0°C Voltage: 12.90 V Output: 36 W Output: 34 W Temperature: 24.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 HW: 8K0 907 063 Component: BCM1 1.0 H22 0253 Revision: 01022001 Serial number: 00000000121532 Coding: 690040B1003400000001000000005F5F001D020800000001000000 Shop #: WSC 06325 000 00000 VCID: 6CD6FC2C8F8BF6265D-8038 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 110908 H05 0070 Serial number: SWF08090110404 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 B HW: 8K0 941 531 B Component: E1 - LDS H07 0070 Serial number: 00000000002908080254 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 6 Reset counter: 66 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:46:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:. 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1AVTTE Coding: 30363435363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbeACUVWAUDI010 A02007 ROD: N/A VCID: 3C760C6CB76BA6A68D-8068 Subsystem 1 - Serial number: 6334MSME40260930/ Subsystem 2 - Serial number: 6344MSME40253441/ Subsystem 3 - Serial number: 6352QSME3E0D4E38- Subsystem 4 - Serial number: 6362QSME010C2E0CJ Subsystem 5 - Serial number: 63732SME4A0B4124Z Subsystem 6 - Serial number: 63832SME0E084136- No ASAM data for: "EV_AirbeACUVWAUDI010" (AU48) No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 D HW: 8K0 953 568 D Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90304HI50008I Coding: 000002 Shop #: WSC 06325 000 00000 VCID: 3B740F70BA65A19E84-806E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 C HW: 8K0 920 950 C Component: KOMBIINSTR. H14 0216 Revision: 00000000 Serial number: 7VN160628 Coding: 2F04080002002600010000 Shop #: WSC 06325 000 00000 VCID: 2F6C2B207E1D4D3E38-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0094 Revision: 4GB20042 Serial number: 4200G0882285EB Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 46826E84F1A7EC76EB-8012 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 Serial number: 180405FD260808 3 Faults Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 177 Reset counter: 31 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:48:06 02080 - Checking Adjustment 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 4 Reset counter: 31 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:48:55 03040 - Headlamp Range Adjustment Signal 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 66 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 22:16:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000007738181 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 2 Faults Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 64 Mileage: 217830 km Time Indication: 0 Date: 2018.08.19 Time: 16:57:43 01328 - Convenience System Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 66 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:46:34 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H80 0141 Revision: 00002001 Serial number: 0114310145 Coding: 011B062200390040002001 Shop #: WSC 06325 000 00000 VCID: 306E285C632352C621-8064 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 7 Faults Found: 03177 - Relay for Power Outlets (J807) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 3 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:55:33 00832 - A/C Control Head (E87) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:55:33 01120 - Camshaft Adjustment 1 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:55:37 01504 - Bulb for License-Plate Light (X) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:56:05 00192 - Rear Left Door Handle Touch Sensor (G417) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 22:12:42 02608 - Front Axle Stabilizer Decoupling Switching Valve; in Hydraulic Unit; Pulsed 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 22:18:31 02608 - Front Axle Stabilizer Decoupling Switching Valve; in Hydraulic Unit; Pulsed 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 22:18:34 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000007741740 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 3F8C7B60AE7DBDBEA8-806A 1 Fault Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 64 Mileage: 217830 km Time Indication: 0 Date: 2018.08.19 Time: 16:57:48 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 E HW: 8K0 907 801 E Component: EPB Audi B8 H05 0060 Revision: 00000003 Serial number: 10000000095399 Shop #: WSC 00000 000 00000 VCID: 31682D5868295BCE2E-8064 1 Fault Found: 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 66 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 21:48:41 Freeze Frame: Voltage: 12.10 V Count: 68 Speed: 0.0 km/h Hex Value: 0x0263 Hex Value: 0x0001 Hex Value: 0x1010 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-152-56.clb Part No SW: 8T2 035 152 A HW: 8T2 035 152 A Component: Chorus3 H03 0031 Revision: 00000001 Serial number: AUZ1Z2H2876103 Coding: 00000480040108000159070000 Shop #: WSC 06325 000 00000 VCID: 2F6C2B207E1D4D3E38-807A Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603 Component: Display H09 X017 Serial number: AUZ1Z2H5097072 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 168 Reset counter: 31 Mileage: 217846 km Time Indication: 0 Date: 2018.08.20 Time: 22:12:10 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000007704018 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000007683933 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 3F8C7B60AE7DBDBEA8-806A No fault code found. End-------------------------(Elapsed Time: 02:55)--------------------------
Hohe Opublikowano 29 Sierpnia 2018 Opublikowano 29 Sierpnia 2018 Najlepiej zmień auto. A serio mówiąc, ja skasował bym te błędy i zobaczył co zostanie.
seba_gniezno Opublikowano 30 Sierpnia 2018 Autor Opublikowano 30 Sierpnia 2018 po skasowaniu wyglada to tak Wednesday,29,August,2018,20:51:39:00001 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.1.0 Data version: 20171130 DS276.6 www.Ross-Tech.com VIN: WAUZZZ8K49A130780 License Plate: Chassis Type: 8K-AU48 (8T0) Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 VIN: WAUZZZ8K49A130780 Mileage: 217900km-135396miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGC) Labels:. 03L-906-022-CAG.clb Part No SW: 03L 906 022 HW: 03L 906 022 B Component: R4 2,0L EDC H01 3177 Revision: 11H01--- Coding: 0104002C18072018 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TID03L906022 A01005 ROD: N/A VCID: 62CA9214754FB056E7-8036 No ASAM data for: "EV_ECM20TID03L906022" (AU48) No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA Component: ESP8 front H04 0060 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 06325 000 00000 VCID: 78FED07CCBD34A86A9-802C No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H80 0141 Revision: 00002001 Coding: 031100 Shop #: WSC 06325 000 00000 VCID: 306E285C632352C621-8064 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Serial number: 0508000049969001 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0208000048006011 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 8T2 820 043 Q HW: 8T2 820 043 Q Component: KLIMA 1 ZONE H06 0140 Revision: B0000000 Serial number: 0130.08.081503 Coding: 34040000 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 1 Fault Found: 00256 - A/C Pressure/Temperature Sensor (G395) 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 31 Mileage: 217900 km Time Indication: 0 Date: 2018.08.29 Time: 20:47:48 Freeze Frame: Temperature: 23.0°C Temperature: 55.0°C Load: 0.0 % Absolute Pres.: 0.8 bar RPM: 0 /min Speed: 0.0 km/h Current: 0.000 A Temperature: 18.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 HW: 8K0 907 063 Component: BCM1 1.0 H22 0253 Revision: 01022001 Serial number: 00000000121532 Coding: 690040B1003400000001000000005F5F001D020800000001000000 Shop #: WSC 06325 000 00000 VCID: 6CD6FC2C8F8BF6265D-8038 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 110908 H05 0070 Serial number: SWF08090110404 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 B HW: 8K0 941 531 B Component: E1 - LDS H07 0070 Serial number: 00000000002908080254 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1AVTTE Coding: 30363435363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 3C760C6CB76BA6A68D-8068 Crash sensor for side airbag: driver side: Serial number: 6334MSME40260930/ Crash sensor for side airbag: front passenger side: Serial number: 6344MSME40253441/ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME3E0D4E38- Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME010C2E0CJ Crash sensor for front airbag: driver side: Serial number: 63732SME4A0B4124Z Crash sensor for front airbag: front passenger side: Serial number: 63832SME0E084136- No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 D HW: 8K0 953 568 D Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90304HI50008I Coding: 000002 Shop #: WSC 06325 000 00000 VCID: 3B740F70BA65A19E84-806E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 C HW: 8K0 920 950 C Component: KOMBIINSTR. H14 0216 Revision: 00000000 Serial number: 7VN160628 Coding: 2F04080002002600010000 Shop #: WSC 06325 000 00000 VCID: 2F6C2B207E1D4D3E38-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0094 Revision: 4GB20042 Serial number: 4200G0882285EB Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 46826E84F1A7EC76EB-8012 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 Serial number: 180405FD260808 1 Fault Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 31 Mileage: 217900 km Time Indication: 0 Date: 2018.08.29 Time: 20:47:52 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000007738181 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H80 0141 Revision: 00002001 Serial number: 0114310145 Coding: 011B062200390040002001 Shop #: WSC 06325 000 00000 VCID: 306E285C632352C621-8064 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 3 Faults Found: 03177 - Relay for Power Outlets (J807) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 31 Mileage: 217900 km Time Indication: 0 Date: 2018.08.29 Time: 20:47:48 00832 - A/C Control Head (E87) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 31 Mileage: 217900 km Time Indication: 0 Date: 2018.08.29 Time: 20:47:48 01120 - Camshaft Adjustment 1 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 31 Mileage: 217900 km Time Indication: 0 Date: 2018.08.29 Time: 20:47:52 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000007741740 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 3F8C7B60AE7DBDBEA8-806A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 E HW: 8K0 907 801 E Component: EPB Audi B8 H05 0060 Revision: 00000003 Serial number: 10000000095399 Shop #: WSC 00000 000 00000 VCID: 31682D5868295BCE2E-8064 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-152-56.clb Part No SW: 8T2 035 152 A HW: 8T2 035 152 A Component: Chorus3 H03 0031 Revision: 00000001 Serial number: AUZ1Z2H2876103 Coding: 00000480040108000159070000 Shop #: WSC 06325 000 00000 VCID: 2F6C2B207E1D4D3E38-807A Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603 Component: Display H09 X017 Serial number: AUZ1Z2H5097072 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000007704018 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 408E789CD383C246D1-8014 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000007683933 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 3F8C7B60AE7DBDBEA8-806A No fault code found. End-------------------------(Elapsed Time: 02:40)--------------------------
