Lemaa Opublikowano 25 Listopada 2018 Opublikowano 25 Listopada 2018 (edytowane) Witam, w VCDS jak coś wybrałem A4 B6, B7 nie było. proszę o sprawdzenie logów: Cytat VCDS-Lite Version: Release 1.2 Sunday, 25 November 2018, 21:25:56:0 Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 8E0 909 518 AQ Component: 1.8L R4/5VT G 0010 Coding: 0011501 Shop #: WSC 06325 VCID: 7F7180FF6EE5 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.LBL Controller: 8E0 820 043 BK Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 VCID: 6BA944AF0A9D 1 Fault Found: 01232 - A/C Compressor Regulator Valve (N280) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Controller: 8E0 907 279 L Component: int. Lastmodul ECE 0704 Coding: 10001 Shop #: WSC 06325 VCID: 3B09B4EF3A7D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Controller: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 00042 Shop #: WSC 06325 VCID: 41F5C6075891 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Controller: 8E0 920 931 M Component: KOMBI+WFS 3 H14 0110 Coding: 0006001 Shop #: WSC 12000 VCID: 321799CBED37 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: None Controller: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0060 VCID: 351DA2D71C59 2 Faults Found: 00668 - Supply Voltage Terminal 30 00-00 - - 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8E0 959 433 CE Component: Komfortgerát T23 4035 Coding: 07008 Shop #: WSC 06325 VCID: 769F65DB41DF No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.LBL Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01011 Shop #: WSC 06325 VCID: 28237BA3DBEB No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 8E0-907-273.LBL Controller: 8E0 907 273 Component: Reifendruck 3 H04 0110 Coding: 0022222 Shop #: WSC 06325 VCID: E9A5BEA78061 2 Faults Found: 01833 - Antenna for Tire Pressure Monitoring; Rear (R96) 004 - No Signal/Communication 02214 - Tire Pressure Warning 000 - - End -------------------------------------------------------------------------------------------------- Wykonane na zgaszonym silniku i wyłączonej klimatyzacji. Pozdrawiam, Karol Edytowane 25 Listopada 2018 przez Lemaa
