Logi po wypadku A4 B7 2.0 TDI BLB
Witam, logi zrobione po wypadku, błędów trochę jest, byłby ktoś tak uprzejmy przejrzeć i podpowiedzieć co może mieć awarie? Z góry dziękuję za pomoc!
Friday,07,September,2018,17:37:51:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WAUZZZ8E15A442575   License Plate:
Mileage: 365150km-226893mi   Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: WAUZZZ8E15A442575   Mileage: 365150km-226893miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 GN    HW: 028 101 211 3
   Component: R4 2,0L EDC G200SG  9618
   Revision: 12345678    Serial number:
   Coding: 0000072
   Shop #: WSC 48259 141 00419
   VCID: 75E63A961C5A76E9CA-8020
1 Fault Found:
18107 - Powertrain Data Bus
            P1699 - 000 - Missing Message from Steering Wheel Electronics
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 50.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.01 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0004401
   Shop #: WSC 06325 000 00000
   VCID: 26442DDA917C4D71B3-8072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x0202
                    Hex Value: 0x00FF
                    Hex Value: 0xFF8F
                    Hex Value: 0x00FF
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   Shop #: WSC 00000
   VCID: 6DD612F6270ABE2932-513C
2 Faults Found:
00819 - High Pressure Sensor (G65)
            07-10 - Signal too Low - Intermittent
01206 - Signal for Duration of Ignition Off Time
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  NDL 0304
   Coding: 10012
   Shop #: WSC 06325
   VCID: 3B72ECAE29FEE099FC-4B18
3 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
            30-00 - Open or Short to Plus
01500 - Bulb for Fog-Lamps; Right (L23)
01519 - Bulb for Back-Up Lights; Right (M17)
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M00137KJ
   Coding: 0030622
   VCID: 3B72ECAE7AFEE099FC-806E
   Subsystem 1 - Serial number: 6332DRB40110490B9
   Subsystem 2 - Serial number: 6342DRB4010913143
   Subsystem 3 - Serial number: 6352ARB4003D7E82T
   Subsystem 4 - Serial number: 6362ARB4003D7F16S
   Subsystem 5 - Serial number: 63729RB400397376I
   Subsystem 6 - Serial number: 63829RB40039727FR
No fault code found.
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 00012
   Shop #: WSC 06325
   VCID: 4382944E510E9859B4-4B18
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 931 D    HW: 8E0 920 931 D
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0004041
   Shop #: WSC 47890 564 45725
   VCID: 295E26E6836262099E-515A
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0004041
Address 46: Central Conv.        Labels: 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 BG
   Component: Komfortgerát T85    2431
   Coding: 07024
   Shop #: WSC 06325
   VCID: 77FA309E555604F9D8-4B18
   Subsystem 1 - Part No: 8E1959801B
   Component: Tőrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802B
   Component: Tőrsteuer.BF BRM 0205
1 Fault Found:
00956 - Key 2
            35-10 -  -  - Intermittent
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8P0 862 335 D    HW: 8P0 862 335 D
   Component: FSE_255x BT     H18 0050
   Revision: 00000001    Serial number: 00000000153424
   Coding: 0000511
   VCID: 377AF09E45D6C4F918-515A
End-------------------------(Elapsed Time: 06:29)--------------------------
Silnik:
1. Brak połączenia ze sterownikiem w kolumnie kierowniczej
ABS:
1.  Błąd niskiego napięcia pojawia się po odłączeniu akumulatora, po wyczyszczeniu pamięci usterek powinien zniknąć.
Klima:
1. Błąd sporadyczny czujnika ciśnienia klimy, umieszczonego na skraplaczu, po skasowaniu błędów powinien już nie wrócić.
2.
Moduł świateł (centralnej elektryki):
Masz coś namieszane w kablach idących do przednich lamp, naprawę powypadkową ogarniał blacharz, lakiernik i elektryk w jednym czy fachowiec od elektryki samochodowej? Może nie są polutowane porządnie tylko poskręcane ze sobą... :facepalm:
Moduł komfortu:
Błąd powinien zniknąć po wyczyszczeniu pamięci usterek.
