Przełozenia skrzyń 6biegowych
Identyfikacja skrzyni biegów
Litery kodowe, przyporządkowanie jednostek mechanicznych, współczynniki transmisji, pojemności
Manual gearbox
6-speed 01E Four-wheel drive
Code letters
DQT
DSY
EDU
Manufactured
from
07.97
05.97
07.99
to
12.98
12.98
10.00
Assignment
Model
Audi A4 1995 >
Audi A4 1995 >
Audi A4 1995 >
Engine
2.5 l - 110 kW - TDI
2.7l - 195 kW - S4
2.7 l - 184 kW - S4
Transmission ratio
Final drive
37 : 9 = 4.111
37 : 9 = 4.111
37 : 9 = 4.111
Z2 :Z1=i
1st gear
28 : 8 = 3.500
28 : 8 = 3.500
28 : 8 = 3.500
2nd gear
34 : 18 = 1.889
34 : 18 = 1.889
34 : 18 = 1.889
3rd gear
32 : 26 = 1.231
32 : 26 = 1.231
32 : 26 = 1.231
4th gear
27 : 31 = 0.871
29 : 30 = 0.967
29 : 30 = 0.967
5th gear
26 : 39 = 0.667
29 : 36 = 0.806
29 : 36 = 0.806
6th gear
23 : 41 = 0.561
26 : 38 = 0.684
26 : 38 = 0.684
Reverse gear
38 : 11 = 3.455
38 : 11 = 3.455
38 : 11 = 3.455
Code letters
DQT
DSY
EDU
Speedometer
Electronic
Capacity
2.5 litres 1)
3.4 litres 1)2)
2.5 litres 1)
Specification
Gear oil G 052 911 A SAE 75 W 90 (synthetic)
Clutch mechanism
Hydraulic
Clutch plate ø
240 mm 3)
Drive shaft flange ø
130 mm 4)
108 mm
108 mm
itot in top gear
2.306
2.813
2.813
Rear final drive assignment
Code letters
DAK
DQA
DQA
1)    Reduced oil quantity
2)    Oil quantity includes 0.3 l for gear oil cooler and oil pipe. Oil cooler and oil pipe must be completely drained on replacing gearbox.
3)    With dual-mass flywheel
4)    For triple roller joint/drive shaft with centring diameter 130 mm
Manual gearbox
Code letters
EHW
FDP
FRQ
Manufactured
from
01.00
11.00
04.01
to
04.01
04.01
09.01
Assignment
Model
Audi A4 1995 >
Audi A4 1995 >
Audi A4 1995 >
Engine
1.9 l - 85 kW - TDI
2.7l - 280 kW - RS4
2.7l - 195 kW - S4
Transmission ratio
Final drive
37 : 9 = 4.111
37 : 9 = 4.111
37 : 9 = 4.111
Z2 :Z1=i
1st gear
28 : 8 = 3.500
28 : 8 = 3.500
28 : 8 = 3.500
2nd gear
34 : 18 = 1.889
34 : 18 = 1.889
34 : 18 = 1.889
3rd gear
32 : 26 = 1.231
33 : 25 = 1.320
32 : 26 = 1.231
4th gear
28 : 30 = 0.933
30 : 29 = 1.034
29 : 30 = 0.967
5th gear
27 : 38 = 0.711
29 : 36 = 0.806
29 : 36 = 0.806
6th gear
24 : 40 = 0.600
26 : 38 = 0.684
26 : 38 = 0.684
Reverse gear
38 : 11 = 3.455
38 : 11 = 3.455
38 : 11 = 3.455
Code letters
EHW
FDP
FRQ
Speedometer
Electronic
Capacity
2.5 litres 1)
3.4 litres 1)2)
3.4 litres 1)2)
Specification
Clutch mechanism
Hydraulic
Clutch plate ø
240 mm 3)
130 mm 4)
108 mm
108 mm
itot in top gear
2.467
2.813
2.813
Code letters
DAK
DQA
DQA
Manual gearbox
Code letters
FTF
FTG
FTK
Manufactured
from
04.01
04.01
04.01
to
09.01
09.01
09.01
Assignment
Model
Audi A4 1995 >
Audi A4 1995 >
Audi A4 1995 >
Engine
2.7 l - 184 kW - S4
1.9 l - 85 kW - TDI
Transmission ratio
Final drive
37 : 9 = 4.111
37 : 9 = 4.111
37 : 9 = 4.111
Z2 :Z1=i
1st gear
28 : 8 = 3.500
28 : 8 = 3.500
28 : 8 = 3.500
2nd gear
34 : 18 = 1.889
34 : 18 = 1.889
34 : 18 = 1.889
3rd gear
32 : 26 = 1.231
32 : 26 = 1.231
32 : 26 = 1.231
4th gear
27 : 31 = 0.871
29 : 30 = 0.967
28 : 30 = 0.933
5th gear
26 : 39 = 0.667
29 : 36 = 0.806
27 : 37 = 0.730
6th gear
23 : 41 = 0.561
26 : 38 = 0.684
24 : 40 = 0.600
Reverse gear
38 : 11 = 3.455
38 : 11 = 3.455
38 : 11 = 3.455
Code letters
FTF
FTG
FTK
Speedometer
Electronic
Capacity
2.5 litres 1)
2.5 litres 1)
2.5 litres 1)
Specification
Clutch mechanism
Hydraulic
Clutch plate ø
240 mm 3)
130 mm 4)
108 mm
130 mm 4)
itot in top gear
2.306
2.813
2.467
Code letters
DAK
DQA
DAK
Manual gearbox
Code letters
FTU
FZV 5)
FZW 5)
Manufactured
from
04.01
01.02
01.02
to
09.01
Assignment
Model
Audi A4 1995 >
Audi A4 1995 >
Audi A4 1995 >
Engine
2.7 l - 280 kW - RS4
2.7 l - 195 kW - S4
Transmission ratio
Final drive
37 : 9 = 4.111
37 : 9 = 4.111
37 : 9 = 4.111
Z2 :Z1=i
1st gear
28 : 8 = 3.500
28 : 8 = 3.500
28 : 8 = 3.500
2nd gear
34 : 18 = 1.889
34 : 18 = 1.889
34 : 18 = 1.889
3rd gear
33 : 25 = 1.320
32 : 26 = 1.231
33 : 25 = 1.320
4th gear
30 : 29 = 1.034
29 : 30 = 0.967
30 : 29 = 1.034
5th gear
29 : 36 = 0.806
29 : 36 = 0.806
29 : 36 = 0.806
6th gear
26 : 38 = 0.684
26 : 38 = 0.684
26 : 38 = 0.684
Reverse gear
38 : 11 = 3.455
38 : 11 = 3.455
38 : 11 = 3.455
5)    Service gearbox for S4 and RS4; modified synchro-rings for 1st and 2nd gear (with carbon coating) and modified locking collar/synchro-hub for 1st/2nd gear
Code letters
FTU
FZV 5)
FZW 5)
Speedometer
Electronic
Capacity
3.4 litres 1)2)
3.4 litres 1)2)
3.4 litres 1)2)
Specification
Clutch mechanism
Hydraulic
Clutch plate ø
240 mm 3)
108 mm
108 mm
108 mm
itot in top gear
2.813
2.813
2.813
Code letters
DQA
DQA
DQA
Manual gearbox
Code letters
FZY 5)
Manufactured
from
01.02
to
Assignment
Model
Audi A4 1995 >
Engine
2.7 l - 184 kW - S4
Transmission ratio
Final drive
37 : 9 = 4.111
Z2 :Z1=i
1st gear
28 : 8 = 3.500
2nd gear
34 : 18 = 1.889
3rd gear
32 : 26 = 1.231
4th gear
29 : 30 = 0.967
5th gear
29 : 36 = 0.806
6th gear
26 : 38 = 0.684
Reverse gear
38 : 11 = 3.455
Code letters
FZY 5)
Speedometer
Electronic
Capacity
2.5 litres 1)
Specification
Clutch mechanism
Hydraulic
Clutch plate ø
240 mm 3)
108 mm
itot in top gear
2.813
Code letters
DQA
Compiled as CODE : | FINAL DRIVE:
B3/B4 AUDI S2:
B4 AUDI RS2:
B5 VW PASSAT 1.9 TDI:
GETRAG# : 815 000 0734
AUDI PART# : 01E 300 048 K
FTS | 4.11
B5 A4 1.9 TDI:
GETRAG # :
EHW | 4.11
FTK | 4.11
B5 A4 2.5 TDI
GETRAG # :
DQT | 4.11
FTF | 4.11
B5 S4 2.7TT:
GETRAG # :
DSY | 4.11
EDU | 4.11
FRQ | 4.11
FTG | 4.11
FZV | 4.11
FZY | 4.11
B5 RS4 2.7TT:
GETRAG # :
FDP | 4.11
FTU | 4.11
FZW | 4.11
B6 A4 1.8T 20V: (never seen a 6-speed B6 with a 01E aside from the 3.0 V6 N/A here in North America)
GDZ | 4.375
HER | 4.375
B6 A4 1.9 TDI:
FTT | 4.11
FYT | 4.11
GBC | 4.11
FPP | 4.11
B6 A4 2.5 TDI (These have the Gearbox Oil Cooler lines):
GETRAG # : 815 007 0803
ENV | 3.89
FTM | 3.89
GBB | 3.89
B6 A4 3.0:
FRE | 4.38
FYF | 4.11
GBD | 4.38
GBE | 4.11
C4 S4/URS4/URS6 2.2 TURBO:
C4 A6 2.5 TDI:
C5 A6 2.5 TDI:
CYT | 4.11
Edytowane przez Kowi87
@Kowi87A tu troche łatwiej, wpisujesz kod skrzyni i pokazuje Ci jakie predkosci na danych obrotach, dodatkowo można porównac kilka
WWW.KOLHOSNIKI.RU
Dobór PPC VAG po parametrach
Tu np. porównanie skrzyni z 2.5 TDI Q do 3.0 TDI Q
Edytowane przez golden87
  • Pomoc techniczna 3
Zarąbista stronka, nie znałem
Bomba:)
