Analiza błędów
Proszę bardzo o pomoc a mianowicie przeanalizowanie bledow pod katem czysto praktycznym (co z czym sie je, co doczego itd) nie o teorie kazdego bledu, tego pelno w necie. Poprostu zobaczyc co dzieje sie z autek podaje kody:
l 09479
VCDS-Lite Version: Release 1.2
Saturday, 30 January 2021, 16:02:56:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: 06B-907-557-ALT.LBL
   Controller: 8E0 909 557 A
   Component: 2.0L R4/5VS      01 0003
   Coding: 0011581
   Shop #: WSC 63351
   VCID: 311596C7E831
3 Faults Found:
18080 -  Coolant Fan Control 1: Open or Short to Ground
            P1672 - 004 -  No Signal/Communication - Intermittent
17887 -  Brake Boost Vacuum System: Mechanical Failure
            P1479 - 008 -  Implausible Signal - Intermittent
16486 -  Mass Air Flow Sensor (G70): Signal too Low
            P0102 - 002 -  Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans       Labels: 01J-927-156.LBL
   Controller: 01J 927 156 CR
   Component: V30 01J 2.0l 5V RdW 2010
   Coding: 00001
   Shop #: WSC 63351
   VCID: 7E8F7DFB69EF
6 Faults Found:
18194 -  Back-Up Lamp Signal: Open Circuit
            P1786 - 35-00 -   -
18132 -  Starter Interlock Signal: Short to Ground
            P1724 - 35-10 -   - - Intermittent
18195 -  Back-Up Lamp Signal: Short to Ground
            P1787 - 35-10 -   - - Intermittent
18158 -  Supply Voltage: too Low
            P1750 - 35-10 -   - - Intermittent
18259 -  Powertrain Data Bus: Missing Message from ABS Controller
            P1851 - 35-10 -   - - Intermittent
18265 -  Load Signal: Error Message from ECU
            P1857 - 35-10 -   - - Intermittent
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04179
   Shop #: WSC 00011
   VCID: E5BDB2976C79
3 Faults Found:
18256 -  Please check DTC Memory of Engine Controller
            P1848 - 35-10 -   - - Intermittent
00778 -  Steering Angle Sensor (G85)
            27-10 -  Implausible Signal - Intermittent
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: DECF9D7B492F
3 Faults Found:
01274 -  Air Flow Flap Positioning Motor (V71)
            41-10 -  Blocked or No Voltage - Intermittent
00604 -  Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-10 -  Open or Short to Plus - Intermittent
00819 -  High Pressure Sensor (G65)
            30-00 -  Open or Short to Plus
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0204
   Coding: 00001
   Shop #: WSC 63351
   VCID: 341B9FD31723
No fault code found.
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655
   Component: Airbag 8.4E         3001
   Coding: 0010602
   Shop #: WSC 63351
   VCID: F49BDFD3D7A3
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00012
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 H
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 00000
   Shop #: WSC 00186
   VCID: 29257EA7C0E1
   WAUZZZ8E32A097108     AUZ6Z0A0214986
3 Faults Found:
00668 -  Supply Voltage Terminal 30
            53-10 -  Supply Voltage Too Low - Intermittent
01316 -  ABS Control Module
            49-10 -  No Communications - Intermittent
01320 -  Control Module for Climatronic (J255)
Address 46: Central Conv.       Labels: 8E0-959-433-MAX.LBL
   Controller: 8E0 959 433 AF
   Component: Komfortgerát T03    0315
   Coding: 06976
   Shop #: WSC 00032
   VCID: 759D62D75CD9
6 Faults Found:
01332 -  Door Control Module; Passenger Side (J387)
01561 -  Left Rear Door
            61-10 -  Won't De-Safe - Intermittent
01813 -  Supply Voltage for Door Controller; Rear Left (J388)
            37-10 -  Faulty - Intermittent
01562 -  Right Rear Door
            58-10 -  Can't Lock - Intermittent
01814 -  Supply Voltage for Door Controller; Rear Right (J389)
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 186
   Component: concert II  GRO    0006
   Coding: 00001
   Shop #: WSC 63351
   VCID: E4BBAF936743
End   --------------------------------------------------------------------------------------------------
